SEM-145-02-03.0-H-D
SEM-145-02-03.0-H-D
    SAMTEC(申泰)
    .8MM TIGER EYE MICRO SOCKET
SEM-145-02-03.0-H-D 数据手册
F-215 SEML–145–02–03.0–H–D–WT SEMS–125–02–03.0–H–D ™ SYSTEM SEM–110–02–03.0–H–D–WT SEM–130–02–03.0–H–D–WT (0,80 mm) .0315" SEM, SEMS, SEML SERIES ™ MICRO TIGER EYE SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SEM, www.samtec.com?SEMS or www.samtec.com?SEML Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C Current Rating (SEM/TEM): 2.6 A per pin (1 pin powered per row) RoHS Compliant: Yes Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max SEM, SEML Mates with: TEM SEMS Mates with: TEMS High reliability Tiger Eye™ contacts Choice of mated heights ™ • Passes 10 year MFG • Locking clip option • Weld tab option TEM/SEM Rated @ 3dB Insertion Loss* 6 mm Stack Height Single-Ended Signaling 12 GHz / 24 Gbps Differential Pair Signaling 17 GHz / 34 Gbps *Test board losses de-embedded from performance data. Complete test data available at www.samtec.com?SEM or contact sig@samtec.com ALSO AVAILABLE (MOQ Required) • Other sizes • Other platings Contact Samtec. Weld tab RECOGNITIONS TYPE STRIP For complete scope of recognitions see www.samtec.com/quality 1 NO. PINS PER ROW 02 STACK HEIGHT PLATING OPTION –03.0 = Gold Flash D –FG OTHER SOLUTIONS • Board Stacking: See SFM, TFM Series • Cable Assemblies: See SFSD, TFSD Series SEM 05, 10, 15, 20, 25 = Tiger Eye™ Strip 30, 35, 40, 45, 50 SEMS (SEM/SEML only) (Standard sizes) = Tiger Eye™ Slim Strip SEML Contact Samtec. = Tiger Eye™ Friction Lock = 6 mm, 7 mm or 10 mm Stack Height when mated with TEM/TEMS Series (SEML only available with 6 mm Stack Height) 02 MATED HEIGHT SEM MATED HEIGHT TEM (3,20) .126 TEM LEAD MATED STYLE HEIGHT* 6 mm –03.0 7 mm –04.0 10 mm –07.0 *Processing conditions will affect mated height. –H 01 (4,50) .177 (3,30) .130 (0,80) .0315 SEM (No. of Positions x (0,80) .0315) + (1,60) .063 SEMS Leave blank for SEMS –G = 10µ" (0,25 µm) Gold on contact, Gold Flash on tail = 30µ" (0,76 µm) Gold on contact, Gold Flash on tail (No. of Positions x (0,80) .0315) + (4,50) .177 OPTION (3,50) .138 (3,75) .148 –A = Alignment Pin (Not available with –LC or –WT) –LC = Locking Clip (Not available with –A or –WT) (Manual placement required) –WT = Weld Tab (Not available with –A or –LC) (Required callout for SEML) SEML (1,89) .074 (No. of Positions x (0,80) .0315) + (3,00) .118 –WT OPTION Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (0,30) .012 OTHER OPTION –K = (3,50 mm) .138" DIA Polyimide film Pick & Place Pad (Required for SEMS) –TR = Tape & Reel (Required for SEMS)
SEM-145-02-03.0-H-D 价格&库存
很抱歉,暂时无法提供与“SEM-145-02-03.0-H-D”相匹配的价格&库存,您可以联系我们找货
SEM-145-02-03.0-H-D
  • 68+174.4337068+22.38182
