TCMD-25-T-02.50-01-R 数据手册
TIGER
IDC
EYE
HIGH-RELIABILITY
IDC HEADER CABLE
(2.00 mm) .0787" PITCH • TCMD SERIES
TCMD
Mates:
SMM*, MMS*, ESQT,
PTF, SQT, SQW, TLE
SPECIFICATIONS
Insulator Material:
Black Glass Filled Polyester
Terminal:
Phosphor Bronze
Plating:
Au or Sn over
50 μ" (1.27 μm) Ni
Wire:
28 AWG 7/36 Stranded, Tinned,
Copper with
Gray PVC Insulator
Current Rating:
2.6 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
SERIES
TCMD
NO. PINS
PER ROW
–04,–05, –07
–08, –10, –12,
–13, –15, –17,
–20, –22, –25
= Terminal
Strip
(Standard sizes)
END
OPTION
–S
OVERALL
LENGTH
- 01 -
–“XX.XX”
= Single End
= Assembled
Length
–D
= Double End
–T
= Transfer End
TRANSFER
OPTION
Leave blank for
–S and –D
End Options.
For –T End
Option Specify
“–N”
(Socket has notch
polarization)
OTHER
OPTION
–P “XX”
= Position
Polarization
(Specify “XX” as
position number.
Requires Transfer
End. Only Socket
is polarized.)
–B “XX”
= Breakout
(Specify “XX”
as number of
conductors to
be broken out)
–RW
= Reverse Wiring
(Blue or black
wire opposite
position #1)
01
(4.00)
.158
–D “XX”
ALSO AVAILABLE
MOQ Required
= Daisy Chain
No. of positions x (2.00) .0787
+ (4.00) .158
Other sizes
–SR
(5.08)
.200
= Strain Relief
(Not available
with –O, –M, –R,
–DXX or –BXX)
Assembled Length
in INCHES (±1/8")
2 inches minimum
–R
= Reversed
Assembled Length (–“XX.XX”)
Single End (—S)
–M
= Middle Reversed
(Requires –DXX)
–O
= Outside
Reversed
(Requires –DXX)
01
02
“XX”
Double End (—D)
Transfer End (—T)
Position Polarization (—P “XX”)
2"
min.
01
*Note:
Standard TCMD callout
will not mate with SMM, MMS.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates with Pin 1, etc.
Note:
TCMD Series assemblies are
non-standard, non-returnable.
02
4" minimum
“XX”
± 1/8"
Double
Row
Connectors
Outer
Most
(End of
assembly)
Reverse Wiring (—RW)
Daisy Chain (—D “XX”)
Reversed (—R)
Middle Reversed (—M)
5"max.
2"min.
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
Breakout (—B “XX”)
No. of positions x
(2.00) .0787 + (7.874) .3100
Strain Relief (—SR)
Outside Reversed (—O)
samtec.com?TCMD
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
TCMD-25-T-02.50-01-R 价格&库存
很抱歉,暂时无法提供与“TCMD-25-T-02.50-01-R”相匹配的价格&库存,您可以联系我们找货
