F-214
TMM–116–02–F–S
TMM–108–01–T–D
TMM–108–03–F–Q
TM
TMM–112–01–L–D–RA
(2,00 mm) .0787"
TMM SERIES
LOW PROFILE THROUGH-HOLE HEADER
SPECIFICATIONS
For complete specifications
see www.samtec.com?TMM
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1,27 µm) Ni
Current Rating (SMM/TMM):
3.2 A per row
(1 pin powered per row)
Operating Temp Range:
-55°C to +105°C with Tin;
-55°C to +125°C with Gold
Voltage Rating:
500 VAC mated with SQW
450 VAC mated with SQT
RoHS Compliant: Yes
Lead–Free Solderable: Yes
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
FILE NO: 090871_0_000
Single, double
and quad row
Mates with:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS, TCSD
Ultra-low profile
(1,50 mm) .059"
APPLICATION
Choice
of five
lead styles
APPLICATIONS
SQT TMM
Retention Clip Option (–RC)
Note: Some lengths, styles
and options are non-standard,
non-returnable.
TMM
1
(2,00 mm)
.0787" pitch
(2,00 mm)
.0787"
NO. PINS
PER ROW
HORIZONTAL
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart
below.
= Gold flash
on post,
Matte Tin on tail
ROW
OPTION
OTHER
OPTION
–S
–RA &
–RE
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
01 thru 50
Other Solutions
(1,97)
.078
No. of positions x
(2,00) .0787
Press Fit
See PTT Series.
LEAD
STYLE
Elevated
02
–02
100
– 03
(3,94)
.155
High
Density
C
– 04
01
99
– 05
04
200
– 06
Shrouded
Four Row
Vertical &
Right Angle
= Double Row
–Q
= Four Row
–RC
–S
= 30µ" (0,76 µm)
Gold on post,
Matte Tin on tail
–T
= Matte Tin
(3,05)
.120
(3,20)
.126
(1,27)
.050
(8,00)
.315
01
–RC
197
(0,50) .020 SQ
(1,50)
.059
See TMMS Series.
(2,00).0787
–Q –RA
(3,05)
.120
(2,00) .0787
D
C
(2,00) .0787
–S
–“XXX”
= Polarized
Position
(Specify position
of omitted pin)
(3,05) .120
(3,20)
.126
B
A
Paste In Hole (PIH) processing.
Contact Samtec ASP Group for
part customization.
= Retention Clip
(Mates with
TCSD)
(Double row only,
4 positions
minimum, only
available –06
lead style)
(2,00)
.0787
See TMMH Series.
(6,00)
.236
= Right Angle
(Lead Style
–01 only)
(2 positions
minimum, –Q
row)
–D
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
(8,20)
01
See TW Series.
B
= Single Row
–L
(3,20) (3,50)
.126 .138
(3,70) (3,00)
.323 .146 .118
(4,00) (2,70)
.158 .106
(5,69) (1,91)
.224 .075 (2,29)
(5,43) (1,65) .090
.214 .065
(9,58) (3,20) (4,88)
.377 .126 .192
– 01
50
A
–F
–D
WWW.SAMTEC.COM
–Q
OPTION
(2,00)
.0787
– RA
–RE
–RA & –RE
D
(1,27)
.050
(3,56)
.140
