TMM-108-01-L-D-SM-A-P
    SAMTEC(申泰)
    2MM TERMINAL STRIP
TMM-108-01-L-D-SM-A-P 数据手册
LOW PROFILE SMT HEADER 8 G b p s (2.00 mm) .0787" PITCH • TMM SERIES TMM Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS Cable Mates: TCSD SPECIFICATIONS TMM -1 - NO. PINS PER ROW 02 thru 40 LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION - ROW OPTION –F –S = Gold flash on post, Matte Tin on tail = Alignment Pin (Metal or plastic at Samtec’s discretion) (5 positions minimum) (–D only) –D –L OTHER OPTION –A = Single Row = Double Row = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating: 3.2 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 281 VAC mated with SQW; 250 VAC mated with SQT - SM - –“XXX” –S = Polarized Position (Specify position of omitted pin) = 30 µ" (0.76 µm) Gold on post, Matte Tin on tail –T –P = Matte Tin = Pick & Place Pad (3 positions minimum) –TR = Tape & Reel (3 thru 36 positions only) PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) –FR 1RRISRVLWLRQV[   = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (3 thru 36 positions only)   ALSO AVAILABLE Other plating (MOQ Required) –P LEAD STYLE A MATES WITH –01 (3.20) .126 SQT, SQW, ESQT, TLE, SMM, MMS, TCSD   10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES Note: Some lengths, styles and options are non-standard, non-returnable.   –04 (1.91) .075 –05 (1.65) .065 –06 (4.27) .168 $ CLT CLT-BE       –D –S samtec.com?TMM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
TMM-108-01-L-D-SM-A-P 价格&库存
很抱歉,暂时无法提供与“TMM-108-01-L-D-SM-A-P”相匹配的价格&库存,您可以联系我们找货
