ZST–113–03–F–D–0735
F-218 (Rev 10OCT17)
HTST–125–01–L–DV
(2.54 mm) .100"
TST, HTST, ZST SERIES
SHROUDED .025" SQ POST IDC HEADERS
Mates with:
IDSD, SMSD
SPECIFICATIONS
For complete specifications
www.samtec.com?TST,
www.samtec.com?HTST or
www.samtec.com?ZST
TST
= Cable Strip
Insulator Material:
TST, ZST: Black Glass
Filled Polyester
HTST: Natural LCP
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (IDSD/TST):
3.4 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Flammability Rating: UL 94V-O
Withstanding Voltage:
1000 VRMS
RoHS Compliant: Yes
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
Specify
LEAD
STYLE
from
chart.
= Gold flash on post,
Matte Tin on tail
(Not available on –DV)
(Standard sizes)
–F
–L
(2.92)
.115
(4.19)
.165
(14.35)
.565
–01
–02
–03
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(2.54) .100 x No. of Positions + (7.62) .300
(2.54) .100 x No. of Positions + (5.08) .200
LEAD T/H
STYLE (A)
–T
= Matte Tin
02
A
(2.54)
.100
(2.54)
.100
01
For complete scope of
recognitions see
www.samtec.com/quality
FILE NO. E111594
–DV
(HTST ONLY)
NO. PINS
PER ROW
05, 07, 08, 10, 12, 13,
15, 17, 20, 25, 32, 36
OTHER
SOLUTIONS
(Standard sizes)
• Shrouded board-to-board
headers and stackers to mate
with SSW, SSQ, ESW, ESQ,
SSM and BCS Series. See
TSS, HTSS and ZSS Series.
02
ALSO AVAILABLE
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart.
Matte Tin on tail
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
–T
(2.54)
.100
= Matte Tin
(2.54)
.100
(6.35)
.250
(8.89)
.350
(2.29)
.090
MIN
(0.38)
.015
(0.64) .025 SQ TYP
–D
Surface
Mount
(lead style
–01 only)
(HTST only)
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
–P
–DV
= Pick &
Place Pad
= Double Row
Surface Mount
(lead style
–01 only)
(HTST only)
–TR
= Tape
& Reel
Packaging
–D–RA
= Double Row
Right-angle
(lead style –04
& –05 only)
B
(5.08)
.200
(2.54)
.100
–D–RA
–“XXXX”
= Body Height
LEAD
STYLE
–01
–02
–03
–04
–05
–06
–07
–08
–09
C
(OAL)
MAX BODY
HEIGHT
(16.00) .630
(13.72) .540
(18.54) .730
(16.26) .640
(21.08) .830
(18.80) .740
(23.62) .930
(21.34) .840
(26.16) 1.030 (23.88) .940
(28.70) 1.130 (26.42) 1.040
(31.24) 1.230 (28.96) 1.140
(33.78) 1.330 (31.50) 1.240
(36.32) 1.430 (34.04) 1.340
BODY
HEIGHT
C
(OAL)
Note: For added mechanical stability, Samtec
recommends mechanical board spacers be
used in applications with gold or selective
gold plated connectors. Contact
ipg@samtec.com for more information.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
BODY
HEIGHT
D
–F
(9.27)
.365
01
OTHER
OPTION
(11.18) .440
(0.64) .025 SQ TYP
1
ZST
ROW
OPTION
(6.35)
.250
(10.16)
.400
(0.38)
.015
–D
LEAD RIGHTSTYLE ANGLE
(B)
–04 (3.30) .130
–05 (5.84) .230
(9.27)
.365
(8.89)
.350
RECOGNITIONS
Note: Some lengths, styles
and options are non-standard,
non-returnable. ZST is
non-standard, non-returnable.
PLATING
OPTION
= High Temp
Cable Strip
Lead–Free Solderable:
HTST: Yes
TST, ZST: Wave Only
SMT Lead Coplanarity:
(0.10 mm) .004" max (05-15)
(0.15 mm) .006" max (17-36)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
• Other platings & sizes
• Alignment Pins
• Single Row
• Locking Leads
• Polarized
Contact Samtec.
LEAD
STYLE
HTST
PROCESSING
(MOQ Required)
NO. PINS
PER ROW
1
TYPE
STRIP
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“TST-117-01-L-D-01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.234371+4.39125
