2716-205
2716-205
    WAGO(万可电子)
    插件,P=15mm
    接线端子 间距:15.00mm 每排针脚数:5 排数:单排
2716-205 数据手册
Printview: PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot - Item No.: 2716-205 . PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot Item No.: 2716-205 . PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot . Marking . Business data Supplier WAGO Item no. 2716-205 GTIN / EAN 4045454739447 Content 1 Order amount 15 Customer item number . Notes High-current terminal strips with lever-actuated CAGE CLAMP®Tool-free opening and closing – fingers open/close leversSeveral clamping units can be held open simultaneously – convenient for terminating multi-core cablesFour solder pins per contact point for high mechanical stability600V UL for 12.5mm pin spacingPin and dimensions compatible to high-current, screw-type terminal blocks Technical data Miscellaneous No. of poles 5 Pin Spacing 15 mm (0.591 in %) Total number of connection points 5 Total number of potentials 5 Color gray Ratings according to 1 IEC/EN 60664-1 WAGO Kontakttechnik GmbH & Co. KG 1 Printview: PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot - Item No.: 2716-205 Technical data Overvoltage category EN 1 III Pollution degree (1) 2 Rated voltage EN (1) [V] 1000 [V] Rated surge voltage (1) [kV] 8 [kV] Nominal current [A] 76 [A] Overvoltage category EN 2 II Degree of pollution (2) 2 Rated voltage EN (2) [V] 1000 [V] Rated surge voltage (2) [kV] 8 [kV] Nominal current (2) [A] 76 [A] Overvoltage category EN 3 III Degree of pollution (3) 3 Rated voltage EN (3) [V] 800 [V] Rated surge voltage (3) [kV] 8 [kV] Nominal current (3) [A] 76 [A] Number of individual connection objects at the product 1 Connection technology (1) CAGE CLAMP® Solid sizes 1 1.5 … 16 mm² / 16 … 6 AWG Fine-stranded wires 1 1.5 … 6 mm² / 16 … 6 AWG Fine-stranded wires with insulated ferrule 1 1.5 … 10 mm² / … Fine-stranded wires with uninsulated ferrule 1 1.5 … 10 mm² / … Strip length 1 12 … 13 mm / 0.47 … 0.51 in Conductor entry angle to the PCB 1 [°] 30 [°] Solder pin arrangement in-line solder pin Solder pin length [mm] 4.5 [mm] Solder pin width A [mm] 0.95 [mm] Solder pin width B [mm] 1.2 [mm] Tolerance of drilled hole [mm] 1.6(+ 0.1) [mm] Material group I Insulating material Polyamide 66 (PA 66) Flammability rating per UL 94 V0 Limit temperature range -60 C … 105 C Clamping spring material Chrome-nickel spring steel (CrNi) Contact material Electrolytic copper (Ecu) WAGO Kontakttechnik GmbH & Co. KG 2 Printview: PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot - Item No.: 2716-205 Technical data Contact plating tin-plated Fire load [MJ] 1.01 [MJ] Weight [g] 55.014 [g] Width 71.5 mm / 2.815 in Height 33.3 mm / 1.311 in Height from the surface 28.8 mm / 1.134 in Length 30 mm / 1.181 in WAGO Kontakttechnik GmbH & Co. KG 3 Printview: PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot - Item No.: 2716-205 Images & drawings WAGO Kontakttechnik GmbH & Co. KG 4 Printview: PCB terminal strip; 4 solder pins/pole; 5-pole; pin spacing 15 mm / 0.591 in; with operating levers; without jumper slot - Item No.: 2716-205 . Address WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Telefon: 0571/887-0 Fax: 0571/887-169 http://www.wago.com © WAGO Kontakttechnik GmbH & Co. KG Technische Änderungen und Irrtümer vorbehalten. WAGO Kontakttechnik GmbH & Co. KG 5
2716-205 价格&库存
很抱歉,暂时无法提供与“2716-205”相匹配的价格&库存,您可以联系我们找货
  • 15+165.37278
库存:60
2716-205
