FFMD-25-D-06.00-01-L 数据手册
F-218
FFMD–20–T–02.00–01–N–R
TIGER
IDC
EYE
(1.27 mm) .050"
FFMD–10–S–10.00–01
FFMD SERIES
TIGER EYE FLAT IDC WIRE CABLES
Mates with:
FLE*, SFMC*,
Transfer End Option
Mates with: FTS, FTSH,
EHF, SHF, ESHF
TYPE
STRIP
END
OPTION
NO. PINS
PER ROW
OVERALL
LENGTH
SPECIFICATIONS
01
–“XX.XX”
For complete specifications
see www.samtec.com?FFMD
Leave blank for –S
and –D End Options.
= Assembled Length
Insulator Material:
Black Glass Filled Polyester
Terminal:
Phosphor Bronze
Contact:
BeCu (-T)
Plating:
Sn over 50 µ" (1.27 µm) Ni
Wire:
30 AWG
Current Rating:
2.5 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
Voltage Rating:
215 VAC
304 VDC
RoHS Compliant:
Yes
–N
Assembled Length
in INCHES (± .130")
2 inches minimum
–04, –05, –08, –10,
–13, –17, –20, –25
= Notch Polarization
on socket (-T end only)
(Not available
with -04 position)
(Standard sizes)
–S = Single End
RECOGNITIONS
–T = Transfer End
–D = Double End
Reverse
Daisy
–RW = Wiring
–D “XX” = Chain
For complete scope of
recognitions see
www.samtec.com/quality
(50.8 mm)
2.00
min.
–R = Reverse
Outside
–O = Reverse
± 1/8"
3
01
(MOQ Required)
• Other sizes
Contact Samtec.
3
(101.60 mm) 4.00 min.
Red wire opposite
position #1.
1
2
Requires –DXX
Not available with
–O, –M, –R or –DXX
3
• Strain relief option
FFMD = Terminal Strip
01
(3.05)
.120
No. of positions x
(1.27) .050 + (4.19) .165
(5.08)
.200
*Note: Standard FFMD callout
will not mate with FLE, SFMC.
Must use gold plated callouts.
(See drawing on web.)
When mated with a socket,
Wire 1 mates with Pin 2;
Wire 2 mates with Pin 1, etc.
Note: This Series is
non-standard, non-returnable.
No. of positions x
(1.27) .050 + (8.00) .315
Requires –DXX
Middle
–M = Reverse
ALSO AVAILABLE
Strain
–SR = Relief
(Mates only with
ESHF Series)
“XX”
FILE NO. E111594
02
OTHER
OPTION
TRANSFER
OPTION
(3.07)
.121
(0.41) .016 SQ
(1.27)
.050
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
FFMD-25-D-06.00-01-L 价格&库存
很抱歉,暂时无法提供与“FFMD-25-D-06.00-01-L”相匹配的价格&库存,您可以联系我们找货
