IPS1-118-01-S-D
IPS1-118-01-S-D
    SAMTEC(申泰)
    CONN SHROUDED PWR SOCKET 36POS
IPS1-118-01-S-D 数据手册
ISOLATED POWER SYSTEMS FEATURES & BENEFITS • Individually shrouded contacts for electrical and mechanical protection • .100" (2.54 mm) and .165" (4.19 mm) pitch • Surface mount or through-hole • Vertical and right-angle for parallel, perpendicular and coplanar applications • Locking clip, key polarization and guide post options • Discrete wire assemblies with 16-30 AWG PVC or Teflon™ fluoropolymer wire. • Metal or plastic rugged latching system *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec Selectively loading contacts achieves customer specific creepage and clearance requrements. CREEPAGE & CLEARANCE Flexible standard or high-power stacking systems with Power Eye three-finger BeCu contacts for reliable connection. For available series, visit samtec.com/flexiblestrips CREEPAGE CLEARANCE IPT1/IPS1 MMSS(T)/MMSD(T) 2.54 mm 1.91 mm IPBT/IPBS PMSS(T)/PMSD(T) 4.27 mm 3.05 mm Selectively loading contacts achieves customer specific creepage and clearance requirements. KEY SPECIFICATIONS SERIES PITCH INSULATOR MATERIAL CONTACT MATERIAL PLATING OPERATING TEMP RANGE CURRENT RATING IPT1/IPS1 .100" (2.54 mm) Black LCP Phosphor Bronze Sn or Au over 50 µ" (1.27 µm) Nickel -55 °C to +125 °C 5.9 A (2 pin powerd) 775 VAC Yes IPBT/IPBS .165" (4.19 mm) Black LCP High Copper Alloy (IPBT) Phospher Bronze (IPBS) Sn over 50 µ" (1.27 µm) Nickel -55 °C to +105 °C 10.3 A (2 pins powerd) 400 VAC Yes F-224 (Rev 26JUN24) VOLTAGE LEAD-FREE RATING SOLDERABLE samtec.com/minimate or samtec.com/powermate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 5.9 A m p s (2.54 mm) .100" PITCH • SHROUDED POWER CONNECTOR SET - IPT1 NO. PINS PER ROW 1 - 05 LEAD STYLE - 15 D - –L Specify LEAD STYLE from chart 10 - PLATING OPTION TAIL OPTION - OTHER OPTIONS –A Requires -01 Lead Style (Leave blank for Through-hole) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail = Alignment Pin (–VS only) (N/A with –LC) –LC –RA = Locking Clip (Manual placement required) (–VS only) (N/A with –A) = Right-angle 20 –VS 25 –K = Surface Mount (Standard Sizes) = (6.00 mm) .236" DIA Polyimide film Pick & Place Pad (–VS only) –TR = Tape & Reel (–VS only) IPT1 Board Mates: IPS1 $     Through-hole IPT1/IPS1 PINS CURRENT RATING (PER CONTACT) 2 4 6 8 50 5.9 A 4.8 A 4.1 A 3.6 A 2.3 A IPS1 - -VS Surface Mount    $ NO. PINS PER ROW - LEAD STYLE 01 05 PLATING OPTION - D - –L 15 B (2.16) .085 (11.05) .435 (6.35) .250 (13.59) .535 (6.35) .250 N/A –02 (14.00) .551 (9.30) .366 (2.64) .104 –03 (16.00) .630 (11.30) .445 (2.16) .085 –04 (17.00) .669 (12.30) .484 (2.69) .106 –05 (19.00) .748 (14.30) .563 (2.46) .097 –06 (20.00) .787 (15.30) .602 (2.35) .093 –07 (25.00) .984 (20.30) .799 (2.31) .091 –08 (30.00) 1.181 (25.30) .996 (2.39) .094 –09 (35.00) 1.378 (30.30) 1.193 (2.46) .097 - TAIL OPTION = Locking Clip (Manual placement required) (–VS only) –RA = Right-angle –VS 20 1RRISRVLWLRQV[      25 (Standard Sizes) –K = Surface Mount = (5.50 mm) .217" DIA Polyimide film Pick & Place Pad (–VS only)   IPS1 Board Mates: IPT1 Through-hole –TR = Tape & Reel (–VS only) Surface Mount     Note: Some lengths, styles and options are non-standard, non-returnable.   OTHER OPTIONS –LC Leave blank for Through-hole = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail 10 A –01 -RA - MATED HEIGHT -01-VS   % 1 –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-VS only)   1RRISRVLWLRQV[          -VS –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (-VS only) -RA View complete specifications at: samtec.com?IPT1 & samtec.com?IPS1 samtec.com/minimate F-224 (Rev 26JUN24) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IPS1-118-01-S-D 价格&库存
很抱歉,暂时无法提供与“IPS1-118-01-S-D”相匹配的价格&库存,您可以联系我们找货
IPS1-118-01-S-D
  • 1+52.431561+6.80466
