J11DF-06V-KY
J11DF-06V-KY
    JST
    J11DF-06V-KY
J11DF-06V-KY 数据手册
JFA CONNECTOR J1000 SERIES 2.2mm pitcth/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ––––––––––––––––––– •Current rating: Refer to the following matrix table. •Voltage rating: 125V AC, DC •Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) •Applicable wire: AWG #28 to #18 (0.08 to 0.82mm2) •Applicable wire: (Tin-plated annealed copper wire [stranded wire]) •Applicable wire: (Insulation O.D./0.85 to 2.1mm) •Applicable PC board thickness: 1.6mm *Contact JST for details. *Compliant with RoHS. It is a high reliability connector corresponding to demand of the miniaturization of electronic equipment and the wire size of AWG#18. • Double-spring construction • Housing lance • Clear "click feeling" 430 Current rating Circuits 1 (Note) 3 6 8 12 20 #18 6.8 6.2 5.5 5.5 4.7 3.9 Unit: A #20 5.9 5.2 4.6 4.6 3.9 3.3 Wire size (AWG) #24 #22 4.2 5.0 3.6 4.6 3.0 4.0 3.0 4.0 2.6 3.4 2.2 2.9 #26 3.2 3.1 2.5 2.4 2.1 1.8 Note: Current rating value when applying only to 1-circuit of 3-circuit connector. #28 2.5 2.5 2.1 2.0 1.7 1.6 JFA CONNECTOR/J1000 SERIES Receptacle contact Tin-plated Strip contact Model No. SF1F-002 (*) -P0.6 SF1F-21 (*) -P0.6 Nominal Applicable wire mm2 AWG# Insulation O.D. Q’ty / reel (mm) M 0.08∼0.22 28∼24 0.85∼1.43 − L 0.30∼0.82 22∼18 1.60∼2.10 5,000 Material and Finish (12.8) Copper alloy, tin-plated, gold-plated (7) (4.3) RoHS compliance Note: Finish(*):T ......Tin-plated GC ...Gold-plated (2) J 1 L Series name Wire range mark Gold-plated (12.8) (7) (4.3) (2) J 1 L Series name Wire range mark Tab contact Strip contact Model No. SF1M-002 (*) -M0.6A SF1M-21 (*) -M0.6A Nominal Applicable wire mm2 AWG# Insulation O.D. Q’ty / reel (mm) M 0.08∼0.22 28∼24 0.85∼1.43 − L 0.30∼0.82 22∼18 1.60∼2.10 5,000 Material and Finish Copper alloy, tin-plated, gold-plated RoHS compliance Note: Finish(*):T ......Tin-plated GC ...Gold-plated (20.9) (4.3) (2) (10.8) J 1 L Series name Wire range mark Crimping machine, Applicator Strip contact Model No. Crimping machine SF1F-002 (*) -P0.6 AP-K2N SF1M-002 (*) -M0.6A SF1F-21 (*) -P0.6 AP-K2N SF1M-21 (*) -M0.6A Crimp applicator MKS-L − MKS-L − Dies Crimp applicator Hand crimp tools with dies MK/SF1F/M002-06 APLMK SF1F/M002-06 − − MK/SF1F/M21-06 APLMK SF1F/M21-06 − − Refer to page 576, 577. Refer to page 576, 577. • Extraction tool for J1000 series: EJ-JFAJ1100 • Hand crimp tool uses the YRK series and refer to page 576, 577 for details Note 1. Contact JST for fully automatic crimping applicator. 2. Finish(*):T ......Tin-plated GC ...Gold-plated 431 J1000 SERIES/J1100 Receptacle housing Single-row type Circuits 3 Keying Model No. X J11SF-03V-KX J11SF-03V-KY Y Dimensions (mm) A B Q’ty / box 4.4 7.4 1,200 4.4 7.4 1,200 Material B Keying No. 16.7 Glass-filled PBT, UL94V-0, black A 9.6 6.6 X (11.3) RoHS compliance U-A Line No. 2.2 A Tab housing 3 2 Single-row type Circuits 1 X Circuit No. Keying Model No. X J11SFM-03V-KX J11SFM-03V-KY Keying No. 3 Y Q’ty / box 4.4 9.2 500 4.4 9.2 500 Material J-1100 Series name Dimensions (mm) A B Glass-filled PBT, UL94V-0, black RoHS compliance B A 29.3 2.2 A 8.4 Line No. Single-row type 1±0.1 2±0.05 Keying No. Circuits (8.4) Circuit No. 2.7±0.05 Header Top entry type (Center locking type) 3 3 A±0.05 X B03B-J11SK-(*)XR B03B-J11SK-(*)YR Y 2 1 J-1100 Line No. PC board layout (viewed from component side) 3.2 Dimensions (mm) A B Q’ty / box 4.4 9.2 625 4.4 9.2 625 Material and Finish 3-φ1±0.05 (B) Post: Copper alloy, tin-plated, gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, tin-plated RoHS compliance Gold-plated product displays (LF) on a label. Note: Finish(*):T .......Tin-plated GW ...Gold-plated 2.7 A 8.4 Model No. (2.5) 2.2±0.05 X Series name Keying 2.2 19.5 A 3.6 B Header Side entry type (Center locking type) 2 ±0.05 Single-row type Circuits 1 ±0.1 (19) 3 2 3 X 8 ±0.05 1 Series name J-1100 (0.6) 2.2±0.05 A±0.05 (B) N-φ1±0.05 B PC board layout (viewed from component side) 19 A 2.2 3.3 3.1 8.4 Line No. 9.6 Model No. X S03B-J11SK-(*)XR S03B-J11SK-(*)YR Keying No. Circuit No. A 8 432 Keying (0.6) Y Dimensions (mm) A B Q’ty / box 4.4 9.2 600 4.4 9.2 600 Material and Finish Post: Copper alloy, tin-plated, gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, tin-plated RoHS compliance Gold-plated product displays (LF) on a label. Note: Finish(*):T .......Tin-plated GW ...Gold-plated J1000 SERIES/J1100 Receptacle housing Double-row type Circuits Keying 6 8 16.7 B Keying No. 12 U-A 10.5 X B (15.2) 3.9 20 22 A 2.2 Line No. A 26 30 X Y X Y X Y X Y X Y X Y X Y Model No. J11DF-06V-KX J11DF-06V-KY J11DF-08V-KX J11DF-08V-KY J11DF-12V-KX J11DF-12V-KY J11DF-20V-KX J11DF-20V-KY J11DF-22V-KX J11DF-22V-KY J11DF-26V-KX J11DF-26V-KY J11DF-30V-KX J11DF-30V-KY Dimensions (mm) A B Q’ty / box 4.4 8.0 800 4.4 8.0 800 6.6 10.2 500 6.6 10.2 500 11.0 14.6 400 11.0 14.6 400 19.8 23.4 250 19.8 23.4 250 22.0 25.6 — 22.0 25.6 — 26.4 30.0 — 26.4 30.0 — 30.8 34.4 — 30.8 34.4 — Material Glass-filled PBT, UL94V-0, black RoHS compliance Tab housing Circuits Keying 10 9 8 7 6 5 4 3 2 1 Circuit No. Model No. X Keying No. Series name 6 X 8 X 12 X 20 X J11DFM-06V-KX J11DFM-08V-KX J11DFM-12V-KX J11DFM-20V-KX Dimensions (mm) A B Q’ty / box 4.4 9.2 400 6.6 11.4 300 11.0 15.8 200 19.8 24.6 150 J-1100 Material B A Glass-filled PBT, UL94V-0, black 29.3 Line No. B RoHS compliance A 3.9 12.3 2.2 433 J1000 SERIES/J1100 Header Top entry type (Center locking type) 6 1 ±0.1 9 8 7 6 5 4 3 2 1 X 3.2 N-φ1±0.05 12 PC board layout (viewed from component side) 3.9 20 B 22 X Y X Y X Y X Y X Y 3.9 A 12.3 2.7 Line No. (2.5) 3.9 ±0.05 J-1100 B C 8 ±0.05 2.2 A±0.05 (B) 2.2 19.5 A Model No. ±0.05 (12.3) Keying No. 2 10 Series name 2.7 ±0.05 Circuit No. Circuits Keying C±0.05 26 3.6 30 X Y X Y B06B-J11DK-(*)XR B06B-J11DK-(*)YR B08B-J11DK-(*)XR B08B-J11DK-(*)YR B12B-J11DK-(*)XR B12B-J11DK-(*)YR B20B-J11DK-(*)XR B20B-J11DK-(*)YR B22B-J11DK-(*)XR B22B-J11DK-(*)YR B26B-J11DK-(*)XR B26B-J11DK-(*)YR B30B-J11DK-(*)XR B30B-J11DK-(*)YR Dimensions (mm) A C B Q’ty / box 4.4 9.2 — 500 4.4 9.2 — 500 6.6 11.4 4.4 400 6.6 11.4 4.4 400 11.0 15.8 8.8 280 11.0 15.8 8.8 280 19.8 24.6 17.6 180 19.8 24.6 17.6 180 22.0 26.8 19.8 — 22.0 26.8 19.8 — 26.4 31.2 24.2 — 26.4 31.2 24.2 — 30.8 35.6 28.6 — 30.8 35.6 28.6 — Material and Finish Post: Copper alloy, tin-plated, gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, tin-plated RoHS compliance Gold-plated product displays (LF) on a label. Note: Finish(*):T .......Tin-plated GW ...Gold-plated Header Side entry type (Center locking type) C±0.05 Keying No. N-φ1±0.05 9 8 7 6 5 4 3 2 1 X Series name 2 ±0.05 (21.2) 10 Circuit No. Circuits Keying 1 ±0.1 8 ±0.05 J-1100 2.2 ±0.05 (0.6) 2.2±0.05 A±0.05 (B) B A 21.2 13.5 12.3 3.9 2.2 Line No. PC board layout (viewed from component side) 6 8 12 20 X Y X Y X Y X Y Model No. S06B-J11DK-(*)XR S06B-J11DK-(*)YR S08B-J11DK-(*)XR S08B-J11DK-(*)YR S12B-J11DK-(*)XR S12B-J11DK-(*)YR S20B-J11DK-(*)XR S20B-J11DK-(*)YR Dimensions (mm) A C B 9.2 — 375 4.4 9.2 — 375 6.6 11.4 — 300 6.6 11.4 — 300 11.0 15.8 8.8 225 11.0 15.8 8.8 225 19.8 24.6 17.6 135 19.8 24.6 17.6 135 C 3.3 3.1 B A 8 (0.6) 2.2 Material and Finish Post: Copper alloy, tin-plated, gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, tin-plated RoHS compliance Gold-plated product displays (LF) on a label. Note: Finish(*):T .......Tin-plated GW ...Gold-plated 434 Q’ty / box 4.4 JFA CONNECTOR/J1000 SERIES Model number identification Receptacle contact Tab contact S F1 F - 21 S F1 M - 21 T - P 0.6 Form: S…Strip form Form: S…Strip form Series name Series name Kind of terminal: F…Receptacle contact Kind of terminal: M…Tab contact Applicable wire: 002…AWG#28 ∼ AWG#24 21…AWG# 22 ∼ AWG#18 Applicable wire: 002…AWG # 28 ∼ AWG# 24 21…AWG # 22 ∼ AWG#18 Surface finish: T…Tin-plated, GC…Gold-plated Surface finish: T…Tin-plated, GC…Gold-plated Material: P…Copper alloy Material: M…Copper alloy Terminal size Terminal size T - M 0.6 A Auxiliary mark Receptacle housing Tab housing J11 DF - 06 V - K X J11 DFM - 06 V - K X Series name Series name Type of connector: SF…Single-row type DF…Double-row type Type of connector: SFM…Single-row type DFM…Double-row type No. of circuits: 3, 6, 8, 12, 20 No. of circuits: 3, 6, 8, 12, 20 Flammability: V…UL94V-0 Flammability: V…UL94V- 0 Color indication: K…Black Color indication: K…Black Keying: X…X-Keying, Y…Y-Keying Keying: X…X-Keying Header B 06 B - J11 D K - T X R PC board mounting direction: B…Top entry type, S…Side entry type No. of circuits: 3, 6, 8, 12, 20 Product name: Header Series name Rows: S…Single-row, D…Double-row Color indication: K…Black Surface finish: T…Tin-plated, GW…Gold-plated Keying: X…X-Keying, Y…Y-Keying Packaging form: R…Tray, M…Magazine stick 435
J11DF-06V-KY 价格&库存
很抱歉,暂时无法提供与“J11DF-06V-KY”相匹配的价格&库存,您可以联系我们找货
J11DF-06V-KY
    库存:4419
    J11DF-06V-KY
    • 220+4.00561220+0.51856
    • 250+3.84530250+0.49781
    • 500+3.70651500+0.47984
    库存:788
