QFS-026-04.25-L-D-PC8 数据手册
F-219 SUPPLEMENT
QMS–078–05.75–L–D–RF1
QMS–052–06.75–L–D–PC4
(0.635 mm) .025"
QMS-PC, QMS-RF SERIES
HIGH-SPEED COMBO RF & POWER
Integral
metal plane
for power or
ground
Board Mates:
QFS-PC, QFS-RA-PC,
QFS-RF
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QMS
Insulator Material:
Liquid Crystal Polymer
Terminal & Ground
Plane Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
(Tin on Ground Plane Tail)
Current Rating:
Signal Contact:
2.6 A per pin
(2 pins powered)
Power Contact:
4.0 A per pin
(4 pins powered per end)
Ground Plane:
15.7 A per ground plane
(1 ground plane powered)
Voltage Rating:
300 VAC mated with QFS
Operating Temp:
-55 °C to +125 °C
RoHS Compliant:
Yes
Choice of Power
and RF options
APPLICATION
QFS
QMS
LEAD
STYLE
• Increased
insertion depth
QMS
NO. OF PINS
PER ROW
Specify
LEAD
STYLE
from
chart
–026, –052, –078
(52 total pins per bank)
RECOGNITIONS
LEAD
STYLE
A
–05.75
(5.38)
.212
–06.75
(6.35)
.250
FILE NO. E111594
(2.00)
.07874
ALSO AVAILABLE
PLATING
OPTION
LEAD
STYLE
For complete scope of
recognitions see
www.samtec.com/quality
Other platings
Differential Pairs
Retention Pins
8 Power Pins/End for
(1.60 mm) 0.62" thick board
• 4 or 8 Power Pins/End for
(2.36 mm) .093" thick board
• 2 RF Connectors/End
• Hot Pluggable
(10.00) .394
(11.00) .433
*Processing conditions
will affect mated height.
See SO Series for
board space tolerances.
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (026-078)
Board Stacking:
For applications requiring more
than two connectors per board,
contact ipg@samtec.com
MATED
HEIGHT*
–05.75
–06.75
• Integral guide post
PROCESSING
(MOQ Required)
MATED
HEIGHT
QMS
(2.29) .090
(21.35) .840
01
END
OPTION
D
–PC4
–L
= 10 µ" (0.25 µm) Gold on Signal Pins
and Ground Plane
(Tin on Signal Pin tails,
and Ground Plane tails)
= 4 Power
Pins per End for
(1.60 mm) .062"
thick Board
(N/A with
–RF1)
–RF1
= One RF
Plug per End
(–05.75 only,
not available
with –PC4)
(2.54)
.100
(2.31)
.091
OTHER
SOLUTIONS
(7.52)
.296
(0.635)
.025
02
(0.23)
.009
No. of Banks x (21.34) .840 + (13.21) .520
A
–PC4 OPTION
No. of Banks x (21.34) .840 + (14.86) .585
01
(1.78)
.070
(0.70)
.028
DIA
See SO Series for precision
machined standoffs.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–RF1 OPTION
02
(3.56)
.140
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
QFS-026-04.25-L-D-PC8 价格&库存
很抱歉,暂时无法提供与“QFS-026-04.25-L-D-PC8”相匹配的价格&库存,您可以联系我们找货
