QSH-090-01-L-D-RA
QSH-090-01-L-D-RA
    SAMTEC(申泰)
    CONN RCPT 180POS R/A SMD GOLD
QSH-090-01-L-D-RA 数据手册
F-217 QSH–060–01–L–D–DP–A QSH–060–01–L–D–A–K ® QSH–030–01–F–D–A (0.50 mm) .0197" QSH SERIES HIGH-SPEED GROUND PLANE SOCKET SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?QSH Insulator Material: Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: Contact: 2 A per pin (1 pin powered per row) Ground Plane: 25 A per ground plane (1 ground plane powered) Operating Temp Range: -55 °C to +125 °C Voltage Rating: 175 VAC (5 mm Stack Height) Max Cycles: 100 RoHS Compliant: Yes Blade & Beam Design Board Mates: QTH Cable Mates: HQCD, HQDP (See Also Available Note) Integral metal plane for power or ground Standoffs: SO HIGH-SPEED CHANNEL PERFORMANCE QTH/QSH @ 5 mm Mated Stack Height Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com 25 10 YEAR MFG WITH 50 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES G b p s PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (020-060) Board Stacking: For applications requiring more than two connectors per board contact ipg@samtec.com PINS PER ROW NO. OF PAIRS QSH 01 –F RECOGNITIONS FILE NO. E111594 (60 total pins per bank = –D) –020, –040, –060 –L (20 pairs per bank = –D–DP) FILE NO: 090871_0_000 PROTOCOLS = Gold Flash on Signal Pins and Ground Plane, Matte Tin on tails –030, –060, –090 For complete scope of recognitions see www.samtec.com/quality • 100 GbE • Hypertransport™ • XAUI • PCI Express® • InfiniBand™ ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. –DP = (No. of Pairs per Row/20) x (20.00) .7875 + (1.27) .050 (20.00) .7875 01 (0.50) .0197 (0.15) .006 (3.25) .128 (3.05) .120 = Electro-Polished Selective 50 µ" (1.27 µm) min Au over 150 µ" (3.81 µm) Ni on Signal Pins in contact area, 10 µ" (0.25 µm) min Au over 50 µ" (1.27 µm) Ni on Ground Plane in contact area, Matte Tin over 50 µ" (1.27 µm) min Ni on all solder tails *Note: –C Plating passes 10 year MFG testing (7.24) .285 (0.76) .030 (0.89) .035 DIA –L A TYPE –D = SingleEnded –D–DP = Differential Pair (–01 only) –C* (7.49) .295 (MOQ Required) • 15 mm, 22 mm and 30 mm stack height • 30 µ" (0.76 µm) Gold (Specify -H plating for Data Rate cable mating applications.) • Edge Mount & Guide Posts • 80 (-DP), 120, 150 positions per row • Retention Option Contact Samtec. = 10 µ" (0.25 µm) Gold on Signal Pins and Ground Plane, Matte Tin on tails –D = (No. of Pins per Row/30) x (20.00) .7875 + (1.27) .050 02 PLATING OPTION (0.64) .025 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. OTHER OPTION –K = (8.25 mm) .325" DIA Polyimide Film Pick & Place Pad –TR = Tape & Reel (–090 positions maximum) –L = Latching Option (Not available on –060 (–D–DP) & –090 positions) QTH MATED HEIGHT LEAD STYLE WITH QSH* –01 –02 –03 –04 –05 –07 –09 (5.00) .197 (8.00) .315 (11.00) .433 (16.00) .630 (19.00) .748 (25.00) .984 (14.00) .551 *Processing conditions will affect mated height. See SO Series for board space tolerances
QSH-090-01-L-D-RA 价格&库存
很抱歉,暂时无法提供与“QSH-090-01-L-D-RA”相匹配的价格&库存,您可以联系我们找货
