QTH–060–01–F–D–RA–PGP
F-219
QTH–060–01–F–D–DP–RA–K
(0.50 mm) .0197"
QTH-RA SERIES
QTH–030–01–L–D–RA
RIGHT-ANGLE GROUND PLANE HEADER
Right-angle
SPECIFICATIONS
Board Mates:
QSH
For complete specifications and
recommended PCB layouts see
www.samtec.com?QTH-RA or
www.samtec.com?QTH-DP-RA
Insulator Material:
Black Liquid Crystal
Polymer
Terminal Material:
Phosphor Bronze
Weld Tab:
Phosphor Bronze
Ground Plane:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2.2 A per pin
(2 pins powered)
Ground Plane:
21.8 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
220 VAC
RoHS Compliant:
Yes
Integral metal
plane for
power or
ground
Guide
Post
PINS PER ROW
NO. OF PAIRS
QTH
01
PLATING
OPTION
OTHER
OPTION
RA
TYPE
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (020-090)
–F
= Gold Flash
on contact,
Matte Tin on tails
–030, –060, –090
–D = (60 total pins per bank)
–L
–020, –040, –060
A (with option -PGP)
B (without option -PGP)
NO. OF PINS PER
PAIRS
ROW
(7.98)
.314
02
(2.03)
.080
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(0.38)
.015
(0.20)
.008
–020
–030
–040
–060
–060
–090
A
B
C
(30.80)
1.213
(50.80)
2.000
(70.80)
2.788
(25.72)
1.013
(45.72)
1.800
(65.72)
2.588
(25.72)
1.013
(45.72)
1.800
(65.72)
2.588
(8.85)
.348
(0.64)
.025
SQ
–PGP OPTION SHOWN
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
–K
= (7.00 mm) .275"
DIA Polyimide
film Pick
& Place Pad
= Differential
Pair
C
01
= Plastic Guide
Post
–D–DP
= 10 µ" (0.25 µm)
Gold contact,
Matte Tin on tails
–D–DP = (20 pairs per bank)
–PGP
–D
= SingleEnded
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
很抱歉,暂时无法提供与“QTH-090-07-F-D”相匹配的价格&库存,您可以联系我们找货
