SFM-125-L1-S-D-LC
SFM-125-L1-S-D-LC
    SAMTEC(申泰)
    插件,P=1.27mm
    排母 间距:1.27mm 2x25P 直插
SFM-125-L1-S-D-LC 数据手册
F-215 (Rev 24JUL15) SFM–110–02–L–D–A SFML–125–T2–L–D–LC ™ SFML–115–T2–L–D–LC SYSTEM SFM–125–02–L–SH (1.27 mm) .050" ™ SMT & THROUGH-HOLE TIGER EYE SOCKET ™ SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SFM or www.samtec.com?SFML Insulator Material: Black Liquid Crystal Polymer Plating: Au or Sn over 50µ" (1.27 µm) Ni Current Rating (SFM/TFM): 3.2 A per pin (1 pin powered per row) Voltage Rating: 250 VAC mated with TFM Operating Temp Range: -55°C to +125°C Contact Resistance: 15 mΩ Insertion Depth: (3.05 mm) .120" to (4.06 mm) .160" Wiping Distance: (0.38 mm) .015" Normal Force: Standard= 132 g (1.29 N) avg.; LIF= 90 g (0.88 N) avg. Insertion Force (SFM): (Single contact only) Standard= 2.5 oz (0.69 N) avg.; LITE= 2.0 oz (0.56 N) avg.; LIF= 1.4 oz (0.39 N) avg. Withdrawal Force (SFM): (Single contact only) Standard= 2.0 oz (0.56 N) avg.; LITE= 1.5 oz (0.42 N) avg.; LIF= 1.0 oz (0.28 N) avg. Max Cycles: 10,000 with 30µ" (0.76 µm) Au (Call Samtec for E.L.P.™ plating option) RoHS Compliant: Yes Processing: Low insertion force Tiger Eye™ contacts available SFM Mates with: TFM, TFSD, TFSS (1.27 mm x 1.27 mm) .050" x .050" micro pitch SFML Mates with: TFML • Passes 10 Year MFG Locking feature increases unmating force (SFML) • Locking option • Locking clip option • Screw Down option Choice of SMT or through-hole tails TYPE STRIP NO. PINS PER ROW 1 LEAD STYLE (Surface Mount) 03, 04, 06, 08 (SFM only) SFM = Standard SFML 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Locking (Standard sizes) Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-25) (0.15 mm) .006" max (30-50) (1.27) .050 x No. of Positions + (0.38) .015 02 (2.41) .095 RECOGNITIONS 01 For complete scope of recognitions see www.samtec.com/quality (3.68) .145 –01, –03 = Tiger Eye™ Contact (BeCu) –L2 –L1, –L3 = Low Insertion Force Tiger Eye™ Contact (BeCu) = Low Insertion Force Tiger Eye™ Contact (BeCu) –T2 –T1 = Tiger Eye™ LITE Contact (Phosphor Bronze) = Tiger Eye™ LITE Contact (Phosphor Bronze) (1.78) .070 (3.37) .133 (2.26) .089 –SH (–02 only) 01 DOUBLE ROW (2.41) .095 (9.78) .385 (1.27) .050 (3.05) .120 (1.27) .050 TYP (4.70) .185 (3.18) .125 –02 = Tiger Eye™ Contact (BeCu) (1.27) .050 TYP SINGLE ROW (1.27) .050 x No. of Positions + (3.94) .155 except for alignment pin option: (1.27) .050 x No. of Positions + (3.17) .125 (2.03) .080 02 FILE NO: 090871_0_000 (1.78) .070 (Through-hole) (0.58) .023 (3.68) .145 (2.79) .110 (0.51) .020 (9.78) .385 (0.13) .005 TYP (4.19) .165 Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (3.05) .120 (4.64) .183 (2.26) .089 –DH (–02 only) SFM–120–L3–L–D SFM–110–01–L–D–A SFM–110–02–L–D–DS SFM–105–L3–L–D SFML–115–T1–L–D–LC SFM–115–02–L–DH SFM, SFML SERIES Mates with TFM for coplanar and perpendicular mating Screw down option High reliability Tiger Eye™ contacts Surface mount or Through-hole tails ALSO AVAILABLE (1.27 mm x 1.27 mm) .050" x .050" micro pitch (MOQ Required) • Solder nail option • Other sizes • Other platings Contact Samtec. OTHER SOLUTIONS • Lower cost plating options. See SFC Series. ROW OPTION PLATING OPTION OPTION –S –L Specify only –A, –LC or –DS (Not available with –DH, –SH) = Single Row (SFM only) = 10µ" (0.25 µm) Gold on contact, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) –A = Alignment Pin (Available with all Lead Styles) –D = Double Row LEAD STYLE A B –01, –L1, –T1 (3.05) .120 (0.51) .020 (1.91) .075 (0.41) .016 –03, –L3 (2.41) .095 (1.27) .050 TYP (1.27) .050 x No. of Positions + (3.94) .155 except for alignment pin option: (1.27) .050 x No. of Positions + (3.17) .125 (2.03) .080 02 (3.68) .145 (1.27) .050 (3.68) .145 01 (8.50) .335 –K = Polyimide film Pick & Place Pad (Not available with –DH, –SH) –P = Plastic Pick & Place Pad (Not available with –DH, –SH) Specify –TR last (Lead styles –02, –L2, –T2 only) –TR = Tape & Reel (Required callout for –DH, –SH) (1.78) .070 DOUBLE ROW (2.41) .095 (0.13) .005 TYP = Dual Screw Down for (1.60 mm) .062" PCB (05 thru 40 positions only) (Lead styles –01, –02 & –03 only) (Requires –D row option) (Not available with SFML) (Mates with TFM-DS option) (Not available with –A, –LC, –K, –P, –TR) = Double Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) (3.05) .120 (3.68) .145 (4.57) .180 –DS –DH SINGLE ROW (1.27) .050 TYP = Locking Clip (Available with all lead styles) (Manual placement required) = Single Horizontal (05 thru 30 positions only) (SFM only) (Lead style –02 only) (1.78) .070 (1.27) .050 x No. of Positions + (0.38) .015 01 –LC –SH Specify only –K or –P (Lead styles –02, –L2, –T2 only) –DS (–D, –01 –02 & –03) (1.65) .065 (1.27) .050 (2.79) .110 A B (1.27) .050 DIA (1.59) .063 –A WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (1.41) x (0.25) .056 .010 –LC
SFM-125-L1-S-D-LC 价格&库存
很抱歉,暂时无法提供与“SFM-125-L1-S-D-LC”相匹配的价格&库存,您可以联系我们找货
