COST-EFFECTIVE
RUGGED SOCKETS
(2.00 mm) .0787" PITCH • SQW/SQT SERIES
SQW/SQT
Board Mates:
TMMH, TMMS, TMM,
MTMM, MMT, TW, TSH,
LTMM, ZLTMM, PTT
Cable Mates:
TCMD
SQW
NO. PINS
PER ROW
1
- 01 -
02 thru 50
–F
–D–VS
–T
–LC
–Q
= Locking Clip
(5 positions minimum)
(Not available with -A)
(Manual placement required)
= Four Row
–5
= Five Row
–K
–6
= (4.25 mm) .167" DIA
Polyimide Film Pick & Place Pad
(4 positions minimum)
= Six Row
–P
= Pick & Place Pad
(2.29)
.090
–TR
(1.27)
.050
(6.35)
.250
= Tape & Reel
(4–28 positions only)
–FR
= Full Reel Tape & Reel
(must order max. quantity per reel;
contact Samtec for quantity breaks)
(4.74)
.187
—D, —T, —Q,
—5, —6
—D—VS
1
NO. PINS
PER ROW
02 thru 50
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
G b p s
PLATING
OPTION
ROW
OPTION
–F
No. of
rows
x
(2.00)
.0787
–S
= Gold flash
on contact,
Matte Tin on tail
= Single Row
–D
= Double Row
–L
–T
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
No. of positions x (2.00) .0787 + (0.30) .012
= Triple Row
–Q
= Four Row
LEAD
STYLE
A
–01
(2.29) .090
–02
(15.24) .600
–03
(5.28) .208
–5
= Five Row
OTHER
OPTION
–RA
= Right-angle
(–Q, –5 & –6
Row not
available)
(Lead Style
–01 only)
–“XXX”
= Polarized
Position
(Indicate
position
number)
–6
= Six Row
(2.29)
.090
(6.35)
.250
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–A
= Alignment Pin
Metal or plastic at Samtec discretion.
(Not available with -LC)
= Triple Row
No. of
rows
x
(2.00)
.0787
4
–“XXX”
= Polarized Position
–D–VS only options:
= Double Row
Surface Mount
OPTION
–D
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
SQT
ROW
OPTION
= Double Row
–L
PROCESSING
SQW Lead–Free Solderable:
Yes, for -D & -D-VS
(Wave only for -T, -Q, -5 & -6)
SQT Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-10)
(0.15 mm) .006" max (11-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
= Gold flash
on contact,
Matte Tin
on tail
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
SQW Current Rating
(SQW/TMMH):
3.8 A per pin (2 pins powered)
SQT Current Rating
(TMMH/SQT):
5.1 A per pin (2 pins powered)
Voltage Rating:
281 VAC mated with TMM;
250 VAC mated with TMMH
Operating Temp Range:
-55 °C to +125 °C
SQW Insertion Depth:
(2.62 mm) .103" to
(5.03 mm) .198" with
(0.38 mm) .015" wipe
SQT Insertion Depth:
(2.62 mm) .103" to
(5.03 mm) .198"
Max Cycles:
100 with 10 µ" (0.25 µm) Au
PLATING
OPTION
A
—RA OPTION
(—Q, —5 & —6 not available)
samtec.com?SQW or samtec.com?SQT
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“SQT-105-03-L-D-010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 54+20.8318954+2.70360
