SS-108-T-38
SS-108-T-38
    SAMTEC(申泰)
    插件,P=2.54mm
    排母 间距:2.54mm 插件
SS-108-T-38 数据手册
F-217 SS–132–G–2 ESD–115–TT–05 (2.54 mm) .100" SS, SD, ESD, ESS, HSS SERIES PRECISION MACHINED SOCKET STRIPS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS TYPE STRIP NO. PINS PER ROW 1 PLATING OPTION LEAD STYLE OTHER OPTION OPTION SPECIFICATIONS For complete specifications see www.samtec.com?SS, www.samtec.com?ESS, www.samtec.com?SD, www.samtec.com?ESD or www.samtec.com?HSS Insulator Material: SS, SD, ESS, ESD= Black G.F. Polyester HSS= Black Liquid Crystal Polymer Contact: BeCu Shell: Brass except Style 5A Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C Contact Resistance: 10 mW Lead Size Range: (0.38 mm to 0.56 mm) .015" to .022" DIA and most IC leads RoHS Compliant: Yes Lead-Free Solderable: Wave only 01 thru 32 01 thru 36 = 30 µ" (0.76 µm) Gold contact, Tin shell SS = Standard = High Temp Single Row Socket Single Row Socket = 30 µ" (0.76 µm) Gold contact, 10 µ" (0.25 µm) Gold shell (2.54) .100 x No. of Positions –1A, –1B or –1C (4.90) .193 (1.32) .052 DIA (2.54) .100 ESD (2.54) (2.54) .100 x No. of Positions .100 TYP = (2.54) Standard Double (5.08) .100 .200 Row Socket (2.54) .100 For LIF specify –23 (ESS, ESD) (0.76) .030 Y = Elevated Double (2.54) Row Socket .100 LEAD STYLE Y –1A or –21A (9.14) .360 (12.95) .510 (6.60) .260 –1B or –21B (0.64) .025 SQ Style –(2.54) 5A not available. TYP& –05 socket Styles.100 –5A heads not countersunk. –1C or –21C (0.76) .030 B A C (0.64) .025 SQ –2, –22*,–5A, or –38* *For LIF specify –22 or –38 (SS, HSS, SD) (2.54) .100 x No. of Positions (2.54) .100 (5.08) .200 –03, –04, –05 (1.83) .072 DIA (2.54) .100 SD (1.83) .072 DIA (2.54) .100 TYP (0.76) .030 (2.54) .100 (1.32) .052 DIA Note: Some lengths, styles and options are non-standard, non-returnable. • Locking lead option on ESS and ESD series Contact Samtec. For LIF specify –21A, –21B or –21C (SS, HSS, SD) (2.54) .100 TYP N/A Style –5A (MOQ Required) Styles – 5A & –05 socket heads not countersunk. (2.54) .100 (0.76) .030 REF ALSO AVAILABLE = Tin contact and shell (Styles 1, 2, 4, and 05 except LIF N/A) = Elevated Single Row Socket = Non Flush Requires -T Plating Option –TT ESS –N Locking Socket (7.62) .300 (3.43) .135 –G HSS = Add –L suffix for locking lead socket in end positions. Requires Style -2 or -22 and .035" ± .003 DIA board hole. –T = HSS, SD & ESD Series (2.54) .100 x No. of Positions FILE NO. E111594 –L = 10 µ" (0.25 µm) Gold contact, Tin shell (Styles 2 & 22 only) = SS, ESS Series RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –S X LIF= Low Insertion Force LEAD STYLE –2 or –22 Z –38 –5A Y X DIA Y Z (0.51) (3.18) (7.62) .020 .125 .300 (0.51) (4.57) (8.89) .020 .180 .350 (0.89) (12.95) (17.86) .035 .510 .703 Locking lead available. See OPTION. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. LEAD STYLE A B C –05 (17.86) (13.46) (4.39) .703 .530 .173 –03 or –23 (11.51) (8.38) (3.12) .453 .330 .123 –04 (14.05) (10.92) (3.12) .553 .430 .123
SS-108-T-38 价格&库存
很抱歉,暂时无法提供与“SS-108-T-38”相匹配的价格&库存,您可以联系我们找货
SS-108-T-38
    • 75+16.66564
    • 1000+12.47066
    • 2000+11.75246
    • 5000+9.71211
    • 13900+7.55749
    • 37400+7.19839
    库存:3
