TD-115-T-AA
TD-115-T-AA
    SAMTEC(申泰)
TD-115-T-AA 数据手册
F-224 WEB TD–108–G–AA HTS–115–T–C–2 TS–119–G–A–1 (2.54 mm) .100" TS, TD, HTS SERIES PRECISION MACHINED TERMINAL STRIPS SPECIFICATIONS For complete specifications see www.samtec.com?TS, www.samtec.com?TD or www.samtec.com?HTS Insulator Material: Black G.F. Polyester (TS, TD) Black Liquid Crystal Polymer (HTS) Terminal Material: Brass, except Style G is Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni or Sn over 100 µ" (2.54 µm) Cu or 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead-Free Solderable: HTS: Yes TS, TD: No, Lead Wave Only Mates with: SS, SD, HSS, SL, SDL, ESS, ESD TYPE STRIP PLATING OPTION NO. PINS PER ROW TS = Single Row Terminal Strip HTS = Single Row High Temp Terminal Strip = 20 µ" (0.51 µm Gold Except –J & –L are 10 µ" (0.25 µm) Gold (2.54) .100 x No. of Positions (2.54) .100 —T (2.54) .100 TYP = Tin (2.54) .100 01 thru 32 =TS Series (2.54) .100 x No. of Positions (5.08) .200 TD = Double Row Terminal Strip 01 thru 36 (2.54) .100 = HTS & TD Series (2.54) .100 TYP (2.54) .100 Note: Some lengths, styles and options are non-standard, non-returnable. FILE NO. E111594 —AA (0.46) .018 DIA (1.78) .070 DIA (0.46) .018 DIA (4.22) .166 —A, —A—1, —A–2 (0.64) .025 DIA (1.32) .052 (1.32) .052 Component No. = T-1R5- Y X (1.78) .070 DIA (0.51) .020 (1.32) .052 DIA (0.46) .018 DIA (4.75) .187 Component No. = T-1R5- (1.83) .072 DIA Y (DIA) (±.015) —A —A–1 (0.64) .025 (5.33) (0.89) .210 .035 (3.18) .125 ± .010 —C X X Y (DIA) (±.015) (0.46) (3.96) .018 .156 —C—1 (0.64) .025 (5.33) .210 —C—2 (0.89) .035 Y -C Component No. =T-1R2-C-X Component No. =T-1R9- —L–1, —L—2, —L–3 (1.07) .042 DIA (3.81) .150 (7.62) .300 ± .015 LEAD STYLE (2.54) .100 —J (1.83) .072 DIA (0.89) .035 (3.99) .157 -A Component No. =T-1R0-A-X Component No. =T-1R7 (4.47) .176 (12.90) (1.02) .508 .040 ± .015 X —C, —C—1, —C–2 (0.46) (3.96) .018 .156 —A–2 —G—1 (0.51) .020 DIA LEAD STYLE (4.22) .166 (1.78) .070 DIA (3.96) .156 ±.015 LEAD STYLE —G RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality 1 (1.32) .052 DIA (0.51) .020 DIA Component No. = S-1P1- (1.07) .042 (1.83) .072 DIA (0.76) .030 (1.32) .052 DIA (0.64) .025 SQ Z Y LEAD STYLE X Y (DIA) (±.015) —L—1 (12.95) .510 (17.86) .703 —L–—2 (9.14) .360 (14.05) .553 —L—3 (6.60) .260 (11.51) .453 Component No. = S-1W1 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TD-115-T-AA 价格&库存
很抱歉,暂时无法提供与“TD-115-T-AA”相匹配的价格&库存,您可以联系我们找货
