TMM-107-01-L-S-SM-TR 数据手册
F-215
TMM–110–01–S–D–SM
TMM–112–01–F–S–SM
TMM–130–05–L–S–SM
(2,00 mm) .0787"
TMM SERIES
LOW PROFILE SMT HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TMM
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1,27 µm) Ni
Current Rating:
3.2 A per pin
(1 pin powered per row)
Operating Temp Range:
-55°C to +105°C with Tin;
-55°C to +125°C with Gold
Voltage Rating:
500 VAC mated with SQW
450 VAC mated with SQT
RoHS Compliant:
Yes
Mates with:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS, TCSD
(2,00 mm)
.0787" pitch
OTHER SOLUTIONS
ThroughHole
Available with optional
• Pick & Place Pads
• Alignment pins
• Tape & reel packaging
2 mm Shunt
Specify
2SN–BK–G
for 2 mm
shunt with
Gold plating.
Processing:
(2,77 mm)
.109" Low Profile
(4,45)
.175
(1,95)
.077
(2,00 mm)
.0787"
pitch
(3,99)
.157
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,15 mm) .006" max
RECOGNITIONS
TMM
1
LEAD
STYLE
NO. PINS
PER ROW
PLATING
OPTION
For complete scope
of recognitions see
www.samtec.com/quality
Specify
LEAD
STYLE
from
chart
below.
02 thru 40
FILE NO: 090871_0_000
ALSO AVAILABLE
LEAD
STYLE
(MOQ Required)
• Other platings
Contact Samtec.
(1,97)
.078
No. of positions x
(2,00) .0787
40
01
02
80
A
–F
= Gold flash on post,
Matte Tin on tail
–L
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
MATES
WITH
–01
SQT, SQW,
(3,20) ESQT, TLE,
.126 SMM, MMS,
TCSD
–04
(1,91)
.075
–05
(1,65)
.065
–06
(4,27)
.168
ROW
OPTION
–S
–A
= Single
Row
= Alignment Pin
(Metal or plastic at
Samtec’s discretion)
(5 positions minimum)
(–D only)
–D
= Double
Row
–“XXX”
= Polarized Position
(Specify position of
omitted pin)
–S
= 30µ" (0,76 µm)
Gold on post,
Matte Tin on tail
–M
= Metal Pick & Place Pad
(4 positions minimum)
(-T plating not available)
(–D only)
–T
CLT
= Matte Tin
CLT-BE
–P
= Pick & Place Pad
(3 positions minimum)
(3,94)
.155
01
–TR
79
(1,27)
.050 TYP
(0,50) .020 SQ
(1,50)
.059
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(2,00)
.0787
OTHER
OPTION
SM
A
(1,27)
.050
= Tape & Reel Packaging
(3 thru 36 positions only)
(1,27)
.050
TYP
(6,60)
.260
(4,83)
.190
–D
–S
(5,00)
.197
x
(8,00)
.315
(5,08)
.200
x
(10,16)
.400
–P
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
(5,72)
.225
x
(3,56)
.140
–M
