TMMH-113-04-G-DV-A
TMMH-113-04-G-DV-A
    SAMTEC(申泰)
    2MM LOW PROFILE STRIPS
TMMH-113-04-G-DV-A 数据手册
FLEXIBLE SMT HEADER (2.00 mm) .0787" PITCH • TMMH SERIES TMMH Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS Cable Mates: TCSD TMMH -1 NO. PINS PER ROW - 03 thru 50 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (TMMH/ESQT): 4.5 A per pin (2 pins powered) Current Rating (TMMH/SQT): 5.1 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 281 VAC mated with SQW; 250 VAC mated with SQT LEAD STYLE - Specify LEAD STYLE from chart PLATING OPTION - DV - –F All Flex Shroud options require 9 pins/row minimum (For board-to-board interfaces. Will not mate with TCSD) = Gold flash on post, Matte Tin on tail –ES –L = End Shroud (For best cost also see TSH Series) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –EC = End Shroud with Locking Clip (For best cost also see TSH Series) (Manual placement required) –T = Matte Tin PROCESSING OPTION Z –ES (2.92) .115 –EC - FLEX SHROUD OPTIONS OTHER OPTIONS –“XXX” = Polarized Position. Specify position of omitted pin –A = Alignment Pin (3 positions minimum) (Not available with –LC) –LC = Locking Clip (5 positions minimum) (Not available with –A) (Manual placement required) –M –EP (4.70) .185 = End Shroud with Guide Post = Pick & Place Pad (5 positions minimum) –EP & –EPC (6.10) .240 –EL –EL & –EBC (4.45) .175 = Tape & Reel Packaging (36 positions maximum) (Flex Shroud options not available except –ES, –EP & –EL) –EBC = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (36 positions maximum) (Flex Shroud options not available except –ES, –EP & –EL) Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) 1RRISRVLWLRQV[  = = End Shroud with Board Lock and Locking Clip (Boards are positively locked and cannot be unmated)   –EPC = End Shroud with Guide Post and Locking Clip (Manual placement required) 1RRISRVLWLRQV[   10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT –TR –FR HIGH MATING CYCLES LEAD STYLE ALSO AVAILABLE     Other Platings Note: Some lengths, styles and options are non-standard, non-returnable. F-224 MATES WITH (3.20) .126 SQT, SQW, ESQT, TLE, SMM, MMS, TCSD –04 (1.91) .075 CLT –05 (1.65) .065 –01 $ MOQ Required A (Shrouded options removed for clarity) —EL —ES —EP —EPC —EC —EBC —LC —A samtec.com?TMMH Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. —M
TMMH-113-04-G-DV-A 价格&库存
很抱歉,暂时无法提供与“TMMH-113-04-G-DV-A”相匹配的价格&库存,您可以联系我们找货
