TSW-106-07-G-S-002
TSW-106-07-G-S-002
    SAMTEC(申泰)
    .025'' SQ. TERMINAL STRIPS
TSW-106-07-G-S-002 数据手册
REVISION DP DO NOT SCALE FROM THIS PRINT TSW-XXX-XX-XXX-X-XX-XXX OPTION #2 -POLARIZING SPECIFICATION XXX INDICATES POS. TO BE OMITTED (SEE FIG 3) OPTION #1 -BLANK= STRAIGHT -RA= RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5) -RE= EXTENDED RIGHT ANGLE (SEE TABLE 3 & 5, FIG 5)(SINGLE ROW ONLY) -NA= RA OPTION WITH STRAIGHT OPTION BODY -NE= RE OPTION WITH STRAIGHT OPTION BODY -LC= LOCKING CLIP (USE LTC-01 FOR -S ROW AND LTC-02 FOR -D ROW)(STYLES 08 THRU 13 & 22 ONLY) (SEE FIG 2) (N/A IN -RA OR -RE OPTION AND/OR LESS THAN 4 POSITIONS) (N/A IN -T OR -Q) -LA= -RA OPTION WITH -LL OPTION (SEE FIG 5) -LL= LOCKING LEAD (SEE FIG 4) (N/A WITH -RE OR -NE OPTION) (N/A IN SINGLE ROW, 1 OR 2 POSITIONS) TERMINAL SPACE SPEC. (SEE ASSEMBLY INSTRUCTIONS) -1=.100[2.54] FILL EVERY POSITION -2= .200[5.08] FILL EVERY OTHER POS. STARTING W/ 1ST & ENDING W/ LAST POS. IN BODY) BODY LENGTH SPEC. EXPRESSED IN # OF POS -1: -01 THRU -50 (-S, -D, -T) "A" = NO. OF POS. x .100[2.54] -2: -02 THRU -25 (-S, -D, -T) "A" = NO OF POS. x .200[5.08] - .100[2.54] TERMINAL SPECIFICATION SEE TABLE 1 ROW SPECIFICATION (SEE TABLE 2) PLATING SPECIFICATION -S: SINGLE -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -D: DOUBLE -T: MATTE TIN CONTACT AND TAIL -T: TRIPLE -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -Q: TRIPLE ROW, FILL OUTER ROWS ONLY -H: 30µ" HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL (-07, -08, -09, -13, -14, -15, -16, -20, -21 ONLY) -TL: TIN/LEAD (90/10 +/-5%) CONTACT AND TAIL (AVAILABLE ONLY ON LEAD STYLES -07, -08 & -09) -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10 +/-5%) TAIL (AVAILABLE ONLY ON LEAD STYLES -07, -08, -10, -15, -16, -17, -21, -23 & -24 THROUGH HOLE ONLY) -TM: MATTE TIN CONTACT AND TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SS: 30µ" STRIPE SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (SEE NOTE 13) NOTES: 1. C REPRESENTS CRITICAL DIMENSION. 2. MINIMUM TERMINAL PUSHOUT: 3 LBS. 3. MAXIMUM HEIGHT VARIATION: .005[0.13](-RA TAIL N/A). 4. ASSEMBLE GOLD PLATE END AS SHOWN. 5. STYLE -26: ROUND END TO APPEAR ON BOTTOM. 6. 'C'± .005[0.13] .008[0.20] FOR STYLE -08, OPTION -LA & -RA ONLY. 7. TOW & SWAY SPEC. OF 2° APPLIES TO ALL POSITIONS, POST & TAIL, IN ALL DIRECTIONS. 8. ALL DIMENSIONS TO BE ABOUT CL WITHIN ±.005[0.13]. 9. MEASURE FROM THE BEND RADIUS OF THE TERMINALS . 10. TSW-50-D BODY CAN BE USED IF RTSW-50-D IS UNAVAILABLE C 11. ORIENTATE PINS TO PREVENT BANDOLIER MARKS FROM SHOWING IN THE POST AREA. (SEE TABLE 7) 12. MAXIMUM CUT FLASH: .020[0.50] 13. -SS OPTION ONLY AVAILABLE IN STRAIGHT LEAD STYLES -07, -08 & -09, -RA STYLE -08 ONLY. CAN ONLY MATE WITH SSW, SSQ, SSM, ESW, ESQ AND BCS. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 BODIES: DUPONT PBT, UL 94 VO, COLOR: BLACK TERMINALS: PHOS BRONZE F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 1 OF 6 REVISION DP C SEE TABLE 8 (SEE CALLOUT) -1XX=.100[2.54] -2XX=.200[5.08] 2 MAX SWAY (EITHER DIRECTION) C "C"±.008[0.20] (SEE TABLE 1, SHT 6) (SEE NOTE 3 AND 6) .100 2.54 .200 5.08 .200 5.08 .200 5.08 REF .300 7.62 REF .300 7.62 REF -D -T 2 MAX SWAY (EITHER DIRECTION) .100 2.54 "L" (SEE TABLE 4, SHT 5) .100 2.54 REF .100 2.54 REF SEE NOTE 5 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) FIG 1 (TSW-1XX-XX-XX-S SHOWN) -S -Q "G" REF .596 15.15 REF * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. "F" DO NOT SCALE DRAWING FIG 2 (TSW-1XX-XX-XX-S-LC SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 2 OF 6 REVISION DP 50 FIG 3 -1: .100[2.54] TERMINAL SPACING (SAME AS FIG 1, DIFFERENT AS SHOWN) 01 02 01 03 01 01 01 01 03 CL CL 01 01 02 99 01 SINGLES 100 148 DOUBLES 25 01 150 148 02 01 03 150 SINGLES 03 04 01 DOUBLES TRIPLES SINGLES 01 03 EVEN POSITIONS 01 01 50 73 DOUBLES SINGLES 01 04 CL 49 TRIPLES STRAIGHT VERSION ODD POSITIONS 02 01 DOUBLES STRAIGHT VERSION -Q: (FILL OUTER ROWS ONLY) TRIPLES 01 75 73 75 -Q: (FILL OUTER ROWS ONLY) TRIPLES CL 01 01 SINGLES DOUBLES TRIPLES SINGLES TRIPLES RIGHT ANGLE VERSION RIGHT ANGLE VERSION -2: .200[5.08] TERMINAL SPACING DOUBLES EVEN POSITIONS ODD POSITIONS LOCKING LEAD = CRIMP LOCATION TWO CENTER MOST PINS TO BE CRIMPED. ODD POSITIONS, CRIMP CENTER POSITION AND POSITION CLOSEST TO PIN ONE. IF CRIMP POSITION IS POLARIZED, MOVE ONE POSITION TOWARDS PIN ONE. FIG 4 LOCKING LEAD (NOTE: END VIEWS SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) LTC-01 LTC-02 SEE CRIMP DETAIL .017 0.43 C MIN .04 1.0 SINGLE -LC-LL DOUBLE -LC-LL SINGLE STRAIGHT -LL DOUBLE STRAIGHT -LL TRIPLE STRAIGHT -LL .0080 0.203 C (TYP) CRIMP DETAIL SCALE: 4:1 (TYP ALL CRIMPS) F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 3 OF 6 FIG 5 REVISION DP (RIGHT ANGLE) (-LA OPTION IS SHOWN ON ALL RIGHT ANGLES FOR DIMENSIONAL AND LOCATION PURPOSES.) (SEE CRIMP DETAIL VIEW, SHT 3) (SAME AS FIG 1, DIFFERENT AS SHOWN) PIN #3 PIN #2 PIN #2 PIN #1 PIN #1 PIN #1 .119 3.02 REF .04 1.0 .219 5.56 REF .04 1.0 .04 1.0 C 90° C 90° C 90° .320 8.13 REF .06 1.5 .06 1.5 C .100 2.54 (SEE NOTE 9) "E" REF (SEE TABLE 5) "D" (SEE TABLE 3) -S C .100 2.54 C .200 5.08 (SEE NOTE 9) "E" REF (SEE TABLE 5) "E" REF (SEE TABLE 5) -D -T * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 4 OF 6 REVISION DP POST AREA BANDOLIER (REF) TAIL AREA IN PROCESS 1 (SAME AS FIG 1, DIFFERENT AS SHOWN) -T PLATING ONLY C (SEE NOTE 11) (SEE TABLE 7) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 5 OF 6 REVISION DP .025 0.64 SQ REF (TYP) .018 0.46 REF (TYP) FIG 6 (-26 LEAD STYLE) (SAME AS FIG. 1, DIFFERENT AS SHOWN) (1) .230[5.84] POST FOR -RA OR -RE OPTION (2) OMIT WITH -Q ROW SPECIFICATION (3) NOT AVAILABLE IN -RA OR -RE OPTION (4) NOT AVAILABLE IN -RE OPTION (5) AVAILABLE IN -LL OPTION (6) AVAILABLE IN -LA OPTION .005[0.13] (7) ON STYLE -08 -LA, RA: "C" = .230[5.84]± .008[0.20] (8) 1.220[30.99] POST FOR STRAIGHT PIN VERSION * SQUARE END OF PIN (T-1RS7-01-XXX-2 SHOULD BE LOCATED AT "C" DIMENSION DURING FILL PROCESS. (SEE FIG. 6) * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 3:1 F:\DWG\MISC\MKTG\TSW-XXX-XX-XXX-X-XX-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .025[0.64] SQ. POST TERMINAL STRIP ASSEMBLY DWG. NO. TSW-XXX-XX-XXX-X-XX-XXX BY: KOLB 08/24/1988 SHEET 6 OF 6
TSW-106-07-G-S-002 价格&库存
很抱歉,暂时无法提供与“TSW-106-07-G-S-002”相匹配的价格&库存,您可以联系我们找货
TSW-106-07-G-S-002
  • 1+10.809941+1.40497
TSW-106-07-G-S-002
    • 19+11.82500
    • 50+9.09244
    • 100+7.37552
    • 500+6.34778
    • 1000+5.32004
    • 2000+4.96941
    • 5000+4.11094
    • 10000+3.25248
    库存:3
