X2510WR-15SP-N0SN
X2510WR-15SP-N0SN
    XKB(中国星坤)
    弯插,P=2.54mm
    线对板针座 1x15P 弯插 间距:2.54mm
X2510WR-15SP-N0SN 数据手册
02 3.4[0.134±0.2] 6.55[0.258]±0.2 01 X2510 W R X- XX SP- N0SN XX ① ②③④ ⑤ ⑥ ⑦ ⑧ ⑨ ①Series No. ②Category: W-wafer W-wafer ③Welding Board Angle: 。 R-90° R-90 ④Welding Welding Way: Way: Blank-DIP Blank-DIP ⑤Row Row No.-Pin No.-Pin No. No. XX-Single row row XX-Single ⑥Special Special NO. NO. SP-Short SP-Short back back Material: ⑦Material: NO-PA66 94V-0 N0-PA66 94V-0 ⑧ PlantingCategory: Category: ⑧Planting V**:All Gold-Plated V:All Gold-Plated *01-Gold Flash ; *02-2U" ; *03-3U" ; *05-5U" 01-Gold Flash 02-2U 03-3U 05-5U *10-10U" ;*15-15U" ; *30-30U" ; *50-50U" 10-10U 15-15U 30-30U 50-50U SN-Bright tin plating 70-120U" SN-Bright tin plating 70-120U SN-Bright SN-Brighttintinplating plating120U"Min. 120U Min; SW-Fog SW-FogTin Tinplating plating Poles ⑨9 Color: Color: Blank-natural color 2 Blank-nbatural color B±0.3 05 08 3.2[0.126]±0.2 2.54[0.100]±0.1 07 8.25±0.2 04 A±0.2 XKB: 6.5[0.256]±0.2 03 Specifications: 规格: Voltage rating:250V AC/DC 额定电压:250V AC/DC Current rating: 3A AC / DC 额定电流: 3A AC / DC Withstanding voltage: 800V AC/minute 耐压电压:800V AC/minute Temperature range:-25℃~+85℃ 温度范围:-25℃~+85℃ Insulation resistance:≥1000MΩ 绝缘电阻:≥1000MΩ Contact resistance:≤10mΩ 接触电阻:≤10mΩ After environment testing: ≤20mΩ 环境试验后: ≤20mΩ 09 2.54[0.100]±0.1 Nylon 66 UL 94V-0 X2510WR-XXSP-N0SN X2510WR-XXSP-N0SN Nylon 66 UL94V-0 Recommand PCB Layout PART N0 X X X DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED ANGLAR L≤ 4 4
X2510WR-15SP-N0SN 价格&库存
很抱歉,暂时无法提供与“X2510WR-15SP-N0SN”相匹配的价格&库存,您可以联系我们找货
