Data sheet | Item number: 2002-2201
Double-deck terminal block; Through/through terminal block; L/L; without
marker carrier; suitable for Ex e II applications; for DIN-rail 35 x 15 and 35 x
7.5; 2.5 mm²; Push-in CAGE CLAMP®; 2,50 mm²; gray
www.wago.com/2002-2201
Color:
Data
Electrical data
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/20
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
500 V
Rated impulse voltage (III / 3)
6 kV
Rated current
24 A
Rated current (2)
28 A
Legend (ratings)
(III / 3) ≙ Overvoltage category III / Pollution degree 3
Approvals per UL 1059
Rated voltage UL (Use Group B)
300 V
Rated current UL (Use Group B)
20 A
Rated voltage UL (Use Group C)
300 V
Rated current UL (Use Group C)
20 A
Rated voltage UL (Use Group D)
600 V
Rated current UL (Use Group D)
5 A
Approvals per CSA
Rated voltage CSA (Use Group B)
600 V
Rated current CSA (Use Group B)
20 A
Rated voltage CSA (Use Group C)
600 V
Rated current CSA (Use Group C)
20 A
Approvals Ex
Rated voltage EN (Ex e II)
440 V
Rated current (Ex e II)
20 A
Rated current (Ex e II) with jumper
18 A
Connection data
Connection technology
Push-in CAGE CLAMP®
Number of connection points (connection type)
2
Actuation type
Push-in
Open Tool Slot
Connectable conductor materials
Copper
Nominal cross section
2.5 mm²
Solid conductor
0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination
0.75 … 4 mm² / 18 … 12 AWG
Fine-stranded conductor
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/20
Fine-stranded conductor with ferrule with plastic collar
1 … 2.5 mm² / 18 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from
Strip length
10 … 12 mm / 0.39 … 0.47 inch
2
Total number of connection points
4
Total number of potentials
2
Number of levels
2
Type of wiring
Front-entry wiring
Note (conductor cross-section)
Depending on the conductor characteristic, a conductor with a
smaller cross section can also be inserted via push-in termination.
Geometrical Data
Width
5.2 mm / 0.205 inch
Height from upper-edge of DIN-35 rail
51.7 mm / 2.035 inch
Depth
69.7 mm / 2.744 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Potential marking
L/L
Marking level
Center/side marking
Material Data
Color
gray
Insulating material
Polyamide 66 (PA 66)
Fire load
0.204 MJ
Weight
10.2 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
BOX
Country of origin
DE
GTIN
4044918753517
Customs Tariff No.
85369010000
Approvals / Certificates
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/20
Ex-Approvals
Logo
Certificate
name
Approval
Additional Approval Text
AEx
Underwriters Laboratories Inc.
UL 60079
20190704E185892
ATEx
Physikalisch Technische Bundesanstalt (PTB)
EN 60079
PTB 03
ATEX
1162 U (II
2 G/D Ex e
II bzw. I M
2 Ex e I)
IECEx
IEC 60079
IECEx PTB
03.0004U
(Ex eb IIC
Gb or Ex
eb I Mb)
Country specific Approvals
Logo
Approval
Certificate
name
CSA
DEKRA Certification B.V.
C22.2 No. 158
1536069
KEMA/KEUR
EN 60947
71107687
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
EN 60947
14HG1293677PDA
BV
Bureau Veritas S.A.
EN 60947
38586/A0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/20
LR
Lloyds Register
EN 60947
91/20112
(E9)
UL-Approvals
Logo
Approval
UR
EN 60947
Certificate
name
NTR NL
7730
Compatible products
check
Item no.: 2002-611
TOPJOB®S L-type test plug module; modular; 1-pole; 2,50 mm²; gray
www.wago.com/2002-611
Item no.: 2002-649
TOPJOB®S L-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray
www.wago.com/2002-649
Item no.: 2009-174
Test plug adapter; for 4 mm Ø test plugs; for testing TOPJOB®S rail-mounted terminal blocks; gray
www.wago.com/2009-174
Item no.: 2009-182
Testing tap; for max. 2.5 mm²; tool-free connection for individual test wires 0.08 - 2.5 mm; gray
www.wago.com/2009-182
General accessories
Item no.: 2002-880/1000-411
Component plug; 2-pole; with diode 1N4007; 10.4 mm wide; Operating temperature 85°C max.; gray
www.wago.com/2002-880
/1000-411
Item no.: 2002-880/1000-541
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/20
Component plug; 2-pole; LED (red); 10.4 mm wide; Operating temperature 85°C max.; gray
/1000-541
Item no.: 2002-880/1000-542
LED module; with red LED; 10.4 mm wide; 30 - 65 V; Operating temperature 85°C max.
/1000-542
Item no.: 2002-880/1000-836
/1000-836
Item no.: 210-658
Operating tool; Blade: 3.5 x 0.5 mm; with a partially insulated shaft; angled; short
www.wago.com/210-658
Item no.: 210-720
www.wago.com/210-720
Item no.: 2002-171
Insulation stop; 0.25 - 0.5 mm²; 5 pieces/strip; light gray
www.wago.com/2002-171
Item no.: 2002-172
Insulation stop; 0.75 - 1 mm²; 5 pieces/strip; dark gray
www.wago.com/2002-172
tools
Insulation stop
Protective Warning Marker
Item no.: 2002-115
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/2002-115
Item no.: 2002-2291
End and intermediate plate; 0.8 mm thick; gray
www.wago.com/2002-2291
Item no.: 2002-2292
End and intermediate plate; 0.8 mm thick; orange
www.wago.com/2002-2292
Item no.: 2002-2295
Separator plate; oversized upper deck; snap-fit type; 2 mm thick; gray
www.wago.com/2002-2295
Item no.: 2002-2296
Separator plate; oversized upper deck; snap-fit type; 2 mm thick; orange
www.wago.com/2002-2296
Item no.: 209-192
Separator for Ex e/Ex i applications; 3 mm thick; 125.5 mm wide; orange
www.wago.com/209-192
Item no.: 2002-400
Adjacent jumper for continuous commoning; insulated; 2-way; Nominal current 25 A; light gray
www.wago.com/2002-400
Item no.: 2002-402
Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; light gray
www.wago.com/2002-402
End plate
Jumper
Item no.: 2002-402/000-005
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/20
Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; red
/000-005
Item no.: 2002-402/000-006
Push-in type jumper bar; insulated; 2-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-403
Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; light gray
www.wago.com/2002-403
Item no.: 2002-403/000-005
Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; red
/000-005
Item no.: 2002-403/000-006
Push-in type jumper bar; insulated; 3-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-404
Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; light gray
www.wago.com/2002-404
Item no.: 2002-404/000-005
Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; red
/000-005
Item no.: 2002-404/000-006
Push-in type jumper bar; insulated; 4-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-405
Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; light gray
www.wago.com/2002-405
Item no.: 2002-405/000-005
Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; red
/000-005
Item no.: 2002-405/000-006
Push-in type jumper bar; insulated; 5-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-405/011-000
Star point jumper; insulated; 3-way (1-3-5); IN = IN terminal block; light gray
/011-000
Item no.: 2002-406
Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; light gray
www.wago.com/2002-406
Item no.: 2002-406/000-005
Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; red
/000-005
Item no.: 2002-406/000-006
Push-in type jumper bar; insulated; 6-way; Nominal current 25 A; blue
/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/20
/000-006
Item no.: 2002-406/020-000
Delta jumper; insulated; 1-2 3-4 5-6; IN = IN terminal block; light gray
/020-000
Item no.: 2002-407
Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; light gray
www.wago.com/2002-407
Item no.: 2002-407/000-005
Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; red
/000-005
Item no.: 2002-407/000-006
Push-in type jumper bar; insulated; 7-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-408
Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; light gray
www.wago.com/2002-408
Item no.: 2002-408/000-005
Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; red
/000-005
Item no.: 2002-408/000-006
Push-in type jumper bar; insulated; 8-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-409
Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; light gray
www.wago.com/2002-409
Item no.: 2002-409/000-005
Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; red
/000-005
Item no.: 2002-409/000-006
Push-in type jumper bar; insulated; 9-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-410
Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; light gray
www.wago.com/2002-410
Item no.: 2002-410/000-005
Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; red
/000-005
Item no.: 2002-410/000-006
Push-in type jumper bar; insulated; 10-way; Nominal current 25 A; blue
/000-006
Item no.: 2002-423
Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; light gray
www.wago.com/2002-423
Item no.: 2002-423/000-005
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 8/20
Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; red
/000-005
Item no.: 2002-423/000-006
Adjacent jumper for continuous commoning; insulated; from 1 to 3; Nominal current 25 A; blue
/000-006
Item no.: 2002-433
Push-in type jumper bar; insulated; from 1 to 3; Nominal current 25 A; light gray
www.wago.com/2002-433
Item no.: 2002-434
Push-in type jumper bar; insulated; from 1 to 4; Nominal current 25 A; light gray
www.wago.com/2002-434
Item no.: 2002-435
Push-in type jumper bar; insulated; from 1 to 5; Nominal current 25 A; light gray
www.wago.com/2002-435
Item no.: 2002-436
Push-in type jumper bar; insulated; from 1 to 6; Nominal current 25 A; light gray
www.wago.com/2002-436
Item no.: 2002-437
Push-in type jumper bar; insulated; from 1 to 7; Nominal current 25 A; light gray
www.wago.com/2002-437
Item no.: 2002-438
Push-in type jumper bar; insulated; from 1 to 8; Nominal current 25 A; light gray
www.wago.com/2002-438
Item no.: 2002-439
Push-in type jumper bar; insulated; from 1 to 9; Nominal current 25 A; light gray
www.wago.com/2002-439
Item no.: 2002-440
Push-in type jumper bar; insulated; from 1 to 10; Nominal current 25 A; light gray
www.wago.com/2002-440
Item no.: 2002-472
Staggered jumper; insulated; 2-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-472
Item no.: 2002-473
Staggered jumper; insulated; 3-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-473
Item no.: 2002-473/011-000
Ready-made staggered jumper; insulated; 2-way (1-3); Nominal current 25 A; with contact lugs
broken off at the factory and circuit marking; light gray
/011-000
Item no.: 2002-474
Staggered jumper; insulated; 4-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-474
Item no.: 2002-475
Staggered jumper; insulated; 5-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-475
Item no.: 2002-475/011-000
Ready-made staggered jumper; insulated; 3-way (1-3-5); Nominal current 25 A; with contact lugs
/011-000
Item no.: 2002-476
Staggered jumper; insulated; 6-way; Nominal current 25 A; suitable for 2002 and 2003 Series railSubject to changes.
Hansastr. 27
32423 Minden
www.wago.com/2002-476
29.12.2019 Page 9/20
Staggered jumper; insulated; 6-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
Item no.: 2002-477
Staggered jumper; insulated; 7-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-477
Item no.: 2002-477/011-000
Ready-made staggered jumper; insulated; 1-3-5-7; Nominal current 25 A; with contact lugs broken
/011-000
Item no.: 2002-478
Staggered jumper; insulated; 8-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-478
Item no.: 2002-479
Staggered jumper; insulated; 9-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-479
Item no.: 2002-479/011-000
Ready-made staggered jumper; insulated; 1-3-5-7-9; Nominal current 25 A; with contact lugs broken
/011-000
Item no.: 2002-480
Staggered jumper; insulated; 10-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-480
Item no.: 2002-481
Staggered jumper; insulated; 11-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-481
Item no.: 2002-481/011-000
Ready-made staggered jumper; insulated; 1-3-5-7-9-11; Nominal current 25 A; with contact lugs
/011-000
Item no.: 2002-482
Staggered jumper; insulated; 12-way; Nominal current 25 A; suitable for 2002 and 2003 Series railmounted terminal blocks; light gray
www.wago.com/2002-482
Item no.: 2002-492
Double-deck vertical jumper; insulated; light gray
www.wago.com/2002-492
Item no.: 2002-492/000-012
Double-deck vertical jumper; insulated; orange
/000-012
Item no.: 2009-412
Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 1.5 mm²; suitable
for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; black
www.wago.com/2009-412
Item no.: 2009-414
Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 1.5 mm²; suitable
www.wago.com/2009-414
Item no.: 2009-414/000-005
for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; red
/000-005
Item no.: 2009-414/000-006
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/20
for 2001, 2002, 2003 and 2022 Series rail-mounted terminal blocks; blue
/000-006
Item no.: 2009-416
Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 1.5 mm²; suitable
www.wago.com/2009-416
Item no.: 210-103
Wire commoning chain; insulated; 50 connections; black
www.wago.com/210-103
Item no.: 210-123
www.wago.com/210-123
Marking accessories
Item no.: 2002-121
Adaptor
www.wago.com/2002-121
Item no.: 2002-161
Adaptor
www.wago.com/2002-161
Item no.: 2009-110
Marking strips; on reel; not stretchable; plain; snap-on type; white
www.wago.com/2009-110
Item no.: 2009-115
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-115
Item no.: 2009-115/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-115/000-005
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-115/000-006
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-115/000-007
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-115/000-012
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-115/000-017
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 2009-115/000-023
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/20
Item no.: 2009-115/000-024
WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-145
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white
www.wago.com/2009-145
Item no.: 2009-145/000-002
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-145/000-005
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-145/000-006
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-145/000-007
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 2009-145/000-012
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-145/000-023
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-145/000-024
Mini-WSB Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 2009-191
Group marker carrier
www.wago.com/2009-191
Item no.: 2009-192
www.wago.com/2009-192
Item no.: 2009-193
www.wago.com/2009-193
Item no.: 2009-198
Adaptor
www.wago.com/2009-198
Item no.: 248-501
Miniature WSB Quick marking system; plain; Marker width 5 mm; 10 strips with 10 markers per card
www.wago.com/248-501
Item no.: 248-501/000-002
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 248-501/000-005
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/20
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 248-501/000-006
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 248-501/000-007
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 248-501/000-012
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 248-501/000-017
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Item no.: 248-501/000-023
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 248-501/000-024
Mini-WSB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-501
WMB marking card; as card; not stretchable; plain; snap-on type; white
www.wago.com/793-501
Item no.: 793-501/000-002
WMB marking card; as card; not stretchable; plain; snap-on type; yellow
/000-002
Item no.: 793-501/000-005
WMB marking card; as card; not stretchable; plain; snap-on type; red
/000-005
Item no.: 793-501/000-006
WMB marking card; as card; not stretchable; plain; snap-on type; blue
/000-006
Item no.: 793-501/000-007
WMB marking card; as card; not stretchable; plain; snap-on type; gray
/000-007
Item no.: 793-501/000-012
WMB marking card; as card; not stretchable; plain; snap-on type; orange
/000-012
Item no.: 793-501/000-017
WMB marking card; as card; not stretchable; plain; snap-on type; light green
/000-017
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 13/20
Item no.: 793-501/000-023
WMB marking card; as card; not stretchable; plain; snap-on type; green
/000-023
Item no.: 793-501/000-024
WMB marking card; as card; not stretchable; plain; snap-on type; violet
/000-024
Item no.: 793-5501
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501
on type; white
Item no.: 793-5501/000-002
WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002
on type; yellow
Item no.: 793-5501/000-005
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-5501/000-006
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-5501/000-007
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-5501/000-012
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-5501/000-014
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown
/000-014
Item no.: 793-5501/000-017
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-5501/000-023
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-5501/000-024
WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet
/000-024
Item no.: 210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25
mm
www.wago.com/210-112
Carrier rail
Item no.: 210-113
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/210-113
29.12.2019 Page 14/20
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18
mm
www.wago.com/210-115
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored
www.wago.com/210-196
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Item no.: 2002-880
Empty component plug housing; 10.4 mm wide; 2-pole; Type 4; gray
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; white
www.wago.com/216-241
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; gray
www.wago.com/216-242
Item no.: 216-243
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; red
www.wago.com/216-243
Item no.: 216-244
Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight
crimped; acc. to DIN 46228, Part 4/09.90; black
www.wago.com/216-244
plug
ferrule
Item no.: 216-246
Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/216-246
29.12.2019 Page 15/20
crimped; acc. to DIN 46228, Part 4/09.90; blue
Item no.: 216-262
www.wago.com/216-262
Item no.: 216-263
www.wago.com/216-263
Item no.: 216-264
www.wago.com/216-264
Item no.: 216-266
www.wago.com/216-266
Downloads
Documentation
Bid Text
2002-2201
Apr 23, 2019
docx
15.4 kB
Download
Apr 23, 2019
xml
4.3 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
docx - Datei
2002-2201
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 2002-2201
CAE data
EPLAN Data Portal 2002-2201
Download
WSCAD Universe 2002-2201
Download
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 16/20
Installation Notes
Inserting a conductor
All conductor types at a glance
Terminating solid and ferruled conductors
via push-in connection.
Inserting conductors via push-in
termination.
Solid conductors with cross-sections from
either one size above, or up to two sizes
below, the rated cross-section can be simply
pushed in – no tools needed.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 17/20
Inserting a conductor via operating tool.
Conductor termination – Insulation stop.
Connecting fine-stranded conductors
without ferrules, or small cross-sectional
conductors that cannot be pushed in, is
performed similarly to the original CAGE
CLAMP® – just use an operating tool.
The smart feature:
To open the clamp, the operating tool is
inserted vertically. The conductor entry is
less than 15 degrees for easier wiring.
Jumpered
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 18/20
Removing a push-in type jumper bar.
Insert the operating tool between the jumper
and and partition wall of the dual jumper
slots, then lift up the jumper.
Place the operating tool in the center of
jumpers up to five contacts (see above), or
alternately on both sides for jumpers with
more than five contacts.
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Jumpered
Commoning two levels via double-deck
vertical jumper (2002‑492).
Marking
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 19/20
Snapping WMB Inline markers into marker
slots.
Double-Deck Terminal Blocks double-deck
marker carrier (2002-121) can be retrofitted
to double-deck terminal blocks without a
marker carrier.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 20/20
很抱歉,暂时无法提供与“2002-2201”相匹配的价格&库存,您可以联系我们找货
