FFSD-07-D-08.00-01-F-N 数据手册
TIGER
IDC
EYE
TIGER EYE™ FLAT
IDC WIRE CABLES
(1.27 mm) .050" PITCH • FFSD SERIES
FFSD
SERIES
Mates:
FTS, FTSH, EHF,
SHF, ESHF
SPECIFICATIONS
Insulator Material:
PBT
Contact:
BeCu
Plating:
10 µ" (0.25 µm) Au over 50 µ"
(1.27 µm) Ni on contact area;
Sn over 50 µ" (1.27 µm) Ni
on balance
Wire:
30 AWG
Current Rating (FFSD/FTSH):
2.3 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
Lead Size Accepted:
(0.41 mm) .016" SQ
Insertion Depth:
(2.64 mm) .104" to
(3.17 mm) .125"
FFSD
= Socket
Strip
NO. PINS
PER ROW
–04, –05,–06,
–08, –10, –11,
–12, –13, –15,
–17, –20, –25
(Standard sizes)
END
OPTION
–S
= Single End
OVERALL
LENGTH
- 01 -
–“XX.XX”
= Assembled
Length
–D
= Double End
N
–N
= Notch
Polarization
(Notch option
not available
with -04 position)
OTHER
OPTION
–RW
= Reverse Wiring
(Red wire opposite
position #1)
–D “XX”
= Daisy Chain
–SR
= Strain Relief
(Mates only with
ESHF Series)
(Not available with
–O, –M, –R or –DXX)
–R
01
= Reversed
(3.05)
.120
–M
= Middle Reversed
(Requires –DXX)
No. of positions x
(1.27) .050 + (4.19) .165
–O
= Outside Reversed
(Requires –DXX)
(5.08)
.200
ALSO AVAILABLE
MOQ Required
Other Sizes
Assembled Length
in INCHES (1/8")
1 inch minimum
01
02
Single End (—S)
Double End (—D)
Assembled Length (—“XX.XX”)
Reverse Wiring (—RW)
No. of positions x
(1.27) .050 + (8.00) .315
(50.8 mm)
2.00
min.
“XX”
± 1/8"
(101.60 mm) 4.00 min.
Daisy Chain (—D “XX”)
Strain Relief (—SR)
Reversed (—R)
Middle Reversed (—M)
Outside Reversed (—O)
Note:
This Series is non-standard,
non-returnable.
F-224
samtec.com?FFSD
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
FFSD-07-D-08.00-01-F-N 价格&库存
很抱歉,暂时无法提供与“FFSD-07-D-08.00-01-F-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+100.298471+12.93876
