ISPC 16/ 2-STGF-10 16
    PHOENIXCONTACT(菲尼克斯)
ISPC 16/ 2-STGF-10 16 数据手册
https://www.phoenixcontact.com/us/products/1748707 Printed-circuit board connector - ISPC 16/ 2-STGF-10,16 - 1748707 Please be informed that the data shown in this PDF Document is generated from our Online Catalog. Please find the complete data in the user's documentation. Our General Terms of Use for Downloads are valid (http://phoenixcontact.com/download) Plug component, Nominal current: 76 A, Rated voltage (III/2): 1000 V, Number of positions: 2, Pitch: 10.16 mm, Connection method: Push-in spring connection, Color: green, Contact surface: Silver The illustration shows the 5-pos. version Product Features ■ ■ ■ ■ ■ Time saving push-in connection, tools not required Defined contact force ensures that contact remains stable over the long term Clamping space opened by means of fixed screwdriver enables convenient conductor connection Inverted connector with pin contacts for touch-proof device outputs or free-hanging cable/cable connections Screwable flange for superior mechanical stability Key Commercial Data Packing unit 1 pc Minimum order quantity 50 pc Weight per Piece (excluding packing) 21.9 g Custom tariff number 85366990 Country of origin Bulgaria Technical data Dimensions Pitch 10.16 mm Dimension a 10.16 mm General Range of articles ISPC 16/..-STGF Insulating material group I Rated surge voltage (III/3) 8 kV 04/06/2016   Page 1 / 5 https://www.phoenixcontact.com/us/products/1748707 Printed-circuit board connector - ISPC 16/ 2-STGF-10,16 - 1748707 Technical data General Rated surge voltage (III/2) 8 kV Rated surge voltage (II/2) 6 kV Rated voltage (III/3) 1000 V Rated voltage (III/2) 1000 V Rated voltage (II/2) 1000 V Connection in acc. with standard EN-VDE Nominal current IN 76 A Nominal cross section 16 mm² Maximum load current 76 A Insulating material PA Flammability rating according to UL 94 V0 Stripping length 18 mm Number of positions 2 Connection data Conductor cross section solid min. 0.75 mm² Conductor cross section solid max. 16 mm² Conductor cross section flexible min. 0.75 mm² Conductor cross section flexible max. 16 mm² Conductor cross section flexible, with ferrule without plastic sleeve min. 0.75 mm² Conductor cross section flexible, with ferrule without plastic sleeve max. 16 mm² Conductor cross section flexible, with ferrule with plastic sleeve min. 0.75 mm² Conductor cross section flexible, with ferrule with plastic sleeve max. 10 mm² Conductor cross section AWG min. 18 Conductor cross section AWG max. 4 2 conductors with same cross section, stranded, TWIN ferrules with plastic 0.75 mm² sleeve, min. 2 conductors with same cross section, stranded, TWIN ferrules with plastic 4 mm² sleeve, max. Minimum AWG according to UL/CUL 20 Maximum AWG according to UL/CUL 4 Standards and Regulations Connection in acc. with standard EN-VDE CUL Flammability rating according to UL 94 V0 04/06/2016   Page 2 / 5 https://www.phoenixcontact.com/us/products/1748707 Printed-circuit board connector - ISPC 16/ 2-STGF-10,16 - 1748707 Classifications eCl@ss eCl@ss 4.0 272607xx eCl@ss 4.1 27260701 eCl@ss 5.0 27260701 eCl@ss 5.1 27260701 eCl@ss 6.0 27260704 eCl@ss 7.0 27440402 eCl@ss 8.0 27440309 eCl@ss 9.0 27440309 ETIM ETIM 3.0 EC001121 ETIM 4.0 EC002638 ETIM 5.0 EC002638 UNSPSC UNSPSC 6.01 30211810 UNSPSC 7.0901 39121409 UNSPSC 11 39121409 UNSPSC 12.01 39121409 UNSPSC 13.2 39121409 Approvals Approvals Approvals UL Recognized / cUL Recognized / SEV / EAC / IECEE CB Scheme / EAC / cULus Recognized Ex Approvals Approvals submitted Approval details 04/06/2016   Page 3 / 5 https://www.phoenixcontact.com/us/products/1748707 Printed-circuit board connector - ISPC 16/ 2-STGF-10,16 - 1748707 Approvals UL Recognized    B C mm²/AWG/kcmil 20-4 20-4 Nominal current IN 66 A 66 A Nominal voltage UN 600 V 600 V   B C mm²/AWG/kcmil 20-4 20-4 Nominal current IN 66 A 66 A Nominal voltage UN 600 V 600 V cUL Recognized  SEV      mm²/AWG/kcmil 16 Nominal current IN 76 A Nominal voltage UN 1000 V EAC  IECEE CB Scheme      Nominal current IN 76 A Nominal voltage UN 1000 V EAC  cULus Recognized  Drawings 04/06/2016   Page 4 / 5 https://www.phoenixcontact.com/us/products/1748707 Printed-circuit board connector - ISPC 16/ 2-STGF-10,16 - 1748707 Dimensional drawing a+27,92 25,1 45,1 10,16 10,16 a Phoenix Contact 2016 © - all rights reserved http://www.phoenixcontact.com 04/06/2016   Page 5 / 5
ISPC 16/ 2-STGF-10 16 价格&库存
很抱歉,暂时无法提供与“ISPC 16/ 2-STGF-10 16”相匹配的价格&库存,您可以联系我们找货
