MMS-138-01-L-SV
MMS-138-01-L-SV
    SAMTEC(申泰)
    插件,P=2mm
    排母 间距:2mm 插件
MMS-138-01-L-SV 数据手册
F-215 MMS–112–02–F–SH MMS–112–01–L–DH MMS–116–02–L–DV MMS–108–01–L–SV (2,00 mm) .0787" MMS SERIES ™ TIGER CLAW SOCKET STRIP Mates with: TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM, TCMD, TSH MMS NO. PINS PER ROW 1 ROW OPTION PLATING OPTION 01 SPECIFICATIONS For complete specifications see www.samtec.com?MMS Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27 µm) Ni Current Rating (MMS/TMM): 3.9 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ Insertion Depth: DH = (2,13 mm) .084" to (2,79 mm) .110", SH = (2,13 mm) .084" minimum or pass-through Top Entry DV/SV = (2,13 mm) .084" to (4,32 mm) .170" Bottom Entry DV/SV = (4,27 mm) .168" minimum (Plus board) Insertion Force: (Single contact only) 3.7 oz (1,03 N) avg. Withdrawal Force: (Single contact only) 2.2 oz (0,61 N) avg. RoHS Compliant: Yes –F 02 thru 40 (2,00) .0787 (2,00) .0787 01 –SV –SH 80 –SH –L = Single Horizontal –DV = Double Vertical –DH (2,00) .0787 (4,00) .157 –DV –“XX” = Polarized Position = Gold flash on contact, Matte Tin on tail 02 79 –SV = Single Vertical = 10µ" (0,25 µm) Gold contact, Matte Tin on tail 40 OTHER OPTION = Double Horizontal 01 –DH No. of positions x (2,00) .0787 + (0,56) .022 (4,45) .175 (3,05) .120 –SH –DH (2,92) .115 –SV MMS (4,70) .185 1 (2,92) .115 (2,00) .079 –SH NO. PINS PER ROW –DH –DV –SV –DV ROW OPTION PLATING OPTION 02 (3,05) .120 (4,70) .185 OTHER OPTION Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,15 mm) .006" max –F 02 thru 40 = Gold flash on contact, Matte Tin on tail RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (2,00) .0787 (2,16) .085 01 –SV –SH 40 –S Row (3,81) .150 x (7,62) .300 FILE NO: 090871_0_000 80 02 ALSO AVAILABLE (MOQ Required) • Alignment Pin (–DV only) • Locking clips and Through-hole passthrough options • Other platings Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. (2,00) (4,17) .0787 .164 (4,00) .157 79 (1,22) .048 –P –SH –DV = Double Vertical –DH = Double Horizontal (5,08) .200 x (5,71) .225 –DH No. of positions x (2,00) .0787 + (0,56) .022 = 10µ" (0,25 µm) Gold contact, Matte Tin on tail –D Row (5,71) .225 x (10,01).394 01 –DV –“XX” = Polarized Position = Single Horizontal –L (2,00) .0787 –SV = Single Vertical –M (1,39) .055 (1,39) .055 (4,50) .177 –M = Metal Pick & Place Pad (4 positions min.) (–DV only) –P (4,70) .185 (1,22) .048 –K = (5,50 mm) .217" DIA Polyimide Film Pick & Place Pad (–SV & –DV only) (–SV= 3 positions min.) (–DV= 4 positions min.) = Plastic Pick & Place Pad (4 pos. min., –SV only) (5 pos. min., –DV only) –TR = Tape & Reel Packaging –SV –SH –DV –DH WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
MMS-138-01-L-SV 价格&库存
很抱歉,暂时无法提供与“MMS-138-01-L-SV”相匹配的价格&库存,您可以联系我们找货
