MTMS-117-51-T-S-125-001
    SAMTEC(申泰)
    CONN HDR .050" 17POS
MTMS-117-51-T-S-125-001 数据手册
F-224 WEB MTMS–130–02–G–D–100 MTMS–110–02–G–D–100 MTMS–125–51–G–S–200 (1.27 mm) .050" MTMS, HMTMS SERIES MODIFIED MICRO TERMINAL SPECIFICATIONS For complete specifications see www.samtec.com?MTMS or www.samtec.com?HMTMS Mates with: SMS, SLM, RSM Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin -55 °C to +125 °C with Gold RoHS Compliant: Yes Position anywhere in the body with (3.05 mm) .120" minimum tail PROCESSING Lead-Free Solderable: Yes Ideal for board stacking applications Single row and double row RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TYPE STRIP 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION 01 thru 50 Specify LEAD STYLE from chart –L ROW OPTION POST HEIGHT OPTION –S –“XXX” –“XXX” FILE NO. E111594 ALSO AVAILABLE (MOQ Required) • Other platings MTMS = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –G = Modified Standard = 10 µ" (0.25 µm) Gold on post, Gold flash on tail HMTMS = Modified High Temp (1.27) .050 x No. of Positions (2.48) .098 50 01 02 100 (2.54) .100 HMTMS –D BODY DESIGN 99 (1.27) .050 TYP (0.46) .018 SQ B (0.00) .000 MIN (2.54) .100 OAL (3.05) C .120 MIN* (0.51) .020 (0.51) .020 DIA SINGLE ROW Note: This Series is non-standard, non-returnable. –D = Double Row DOUBLE ROW Tail DIA is .020" (0.51 mm) for min .120" (3.05 mm). Balance of tail is .018" (0.46 mm) SQ. = “B” Dimension (Specify Post Height in inches (0.13 mm) .005" increments) LEAD STYLE OAL –01 = Polarized Position (Specify position of omitted pin) B (Maximum when C = (3.05 mm) .120") (11.43) .450 (5.84) .230 –02 (8.13) .320 (2.54) .100 (8.38) .330 (3.18) .125 –51 (10.41) .410 (4.83) .190 –52 (10.80) .425 (5.21) .205 –53 (12.83) .505 (7.24) .285 –54 (14.10) .555 (8.51) .335 –55 (15.49) .610 (9.91) .390 –56 (15.88) .625 (10.29) .405 –57 (16.51) .650 (10.92) .430 –58 (17.91) .705 (12.32) .485 –59 (19.18) .755 (13.59) .535 –60 (20.96) .825 (15.37) .605 –25* (4.98) .196 01 = Single Row *Style -25 tail C = (1.02 mm) .040" min is available. WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MTMS-117-51-T-S-125-001 价格&库存
很抱歉,暂时无法提供与“MTMS-117-51-T-S-125-001”相匹配的价格&库存,您可以联系我们找货
