F-212
MTSW–118–08–G–D–200–RA
MTSW–125–24–L–T–225
(2,54mm) .100"
MTSW, HMTSW SERIES
MODIFIED .025" SQ POST HEADERS
Mates with:
SSW, SSQ, ESW, ESQ,
BCS, BSW, IDSS, IDSD,
CES, SLW, HLE, SSM,
SMSD, SMSS
TYPE
STRIP
(0,13) (0,13)
Samtec
.005
.005
offers the
greatest
stacking
flexibility
in the
industry.
The “M”
MTSW
stands for
Modified. You tell us the
post height you need
and we’ll deliver it.
= Modified Strip
LEAD STYLE
–2
= (2,54mm)
.100" Pitch
HMTSW
= (5,08mm)
.200" Pitch
(2,54)
.100
(5,08)
.200
= Hi-Temp
Modified Strip
(0,13)
.005
SPECIFICATIONS
For complete specifications
see www.samtec.com?MTSW
SPECIFY “LEAD STYLE”
FROM CHART
(2,54) .100 x No. of Positions
(2,54)
.100
50
Straight
Pin
Versions
02
Insulator Material:
Black Glass Filled
Polyester
Terminal Material:
Phosphor Bronze
Plating: Au or Sn
over 50µ" (1,27µm) Ni
Current Rating:
3 amp continuous
Operating Temp Range:
-55°C to +125°C with Gold
-55°C to +105°C with Tin
RoHS Compliant:
Yes
Lead–Free Solderable:
Wave Only
SPECIFICATIONS
see www.samtec.com?HMTSW
(2,54)
.100
–S
(2,54) (5,02)
.100 .198
–D
100
01
03
(7,62)
.300
(2,48)
.098
01
(5,08)
.200
99
150
(2,54)
.100
(5,08) (7,56)
.200 .298
01
03
MTSW
(5,08) (7,56)
.200 .298
01
–T
148
150
(7,62)
.300
MTSW
–Q
01
thru
50
= (2,54mm)
.100"
Center
Version
148
HMTSW
LEAD
STYLE OAL
(7,62)
– 06
.300
(10,92)
– 07
.430
(13,46)
– 08
.530
(18,54)
– 09
.730
– 10 (21,08)
.830
– 11 (23,62)
.930
– 12 (26,16)
1.030
(31,24)
– 13
1.230
– 21 (36,32)
1.430
– 22 (16,00)
.630
– 23 (11,30)
.445
(12,19)
– 24
.480
– 27 (33,78)
1.330
Right (3,02) (1,78)
.119
.070
Angle
Versions
(3,09)
(1,78) .120
.070
100
02
HMTSW
–S & –D (5,56)
.219
(1,78)
= 36
.070
positions
maximum
(8,12)
.320
–S
01
50
(2,54)
.100
(6,10)
.240
(1,78)
.070
01
99
03
150
(2,54)
.100
(5,08)
.200
(8,10)
.319
–D
–T
(1,78)
.070
(1,78)
.070
01
148
03
150
(5,08)
.200
Note:
These Series are
non-standard, non-returnable.
(8,10)
.319
= (5,08mm)
.200"
Center
Version
–Q
01
MTSW
HMTSW
148
WWW.SAMTEC.COM
(2,54)
.100
TAIL
(0,00).000
MIN
Board Stacking
BO AR D
SPA CE
OV ERA LL
PIN
(O AL )
(1,78)
.070
(1,78)
.070
OVERALL
LENGTH
(OAL)
02
thru
25
PO ST
TAI L
(8,12)
.320
POST
(0,00)
.000
MIN
(28,70)
1.130
– 28
HMTSW
Same as MTSW
except:
Insulator Material:
Natural Liquid Crystal
Polymer
Yes
–1
MTSW
Modified .025"
strips permit
custom post
heights.
NO. PINS
PER ROW
PIN PITCH
MA X
INS ERT ION
DE PTH
SO CK ET
PRO FIL E
BO DY
PRO FIL E
MTSW–126–09–L–S–430–RA
MTSW–203–11–T–T–740
MTSW–112–12–G–Q–730–RA
MTSW–110–27–G–D–990
MTSW–125–07–T–S–100
ROW
OPTION
PLATING OPTION
–F
POST
HEIGHT
OTHER
OPTION
POLARIZED
OPTION
–S
= Gold flash on post, Matte Tin on tail
–“XXX”
= Single
–L
= Polarized
(Specify ‘XXX’ as
position number)
–D
= 10µ" (0,25µm) Gold on post,
Matte Tin on tail
= Double
(4,19)
.165"
Contact
Area
–T
–G
–RA
= Triple
Gold flash on balance
or
–RE = Right Angle
Tail
–LL
–Q
–T
= Locking Lead
(N/A with –RE,
N/A in single row 1 or 2
positions. Available on
tails from (2,29) .090" to
(10,16) .400" only)
= Double Row
.200" (5,08mm)
row space
= Matte Tin
Note: Other Gold plating options available.
Contact Samtec.
Two leads per strip
crimped in opposite
directions on or near
centerline. See TSW
for availability.
–RA Option with –LL Option
–LA = (Maximum “C” = (13,46) .530)
–“XXXX”= “C” Dimension (Specify post height in INCHES – .005" (0,13mm) increments)
LEAD
STYLE
OAL
– 06
– 07
– 08
– 09
– 10
– 11
– 12
– 13
– 21
– 22
– 23
– 24
– 27
(7,62)
.300
(10,92)
.430
(13,46)
.530
(18,54)
.730
(21,08)
.830
(23,62)
.930
(26,16)
1.030
(31,24)
1.230
(36,32)
1.430
(16,00)
.630
(11,30)
.445
(12,19)
.480
(33,78)
1.330
(28,70)
1.130
* – 28
C
C
C
MAXIMUM MAXIMUM MAXIMUM
STRAIGHT
w/RA
w/RE
(2,79)
.110
(6,10)
.240
(8,64)
.340
(13,72)
.540
(16,26)
.640
(18,80)
.740
(21,34)
.840
(26,42)
1.040
(31,50)
1.240
(11,18)
.440
(6,48)
.255
(7,37)
.290
(28,96)
1.140
(23,88)
.940
N/A
N/A
(3,30)
.130
(5,84)
.230
(10,92)
.430
(13,46)
.530
(16,00)
.630
(18,54)
.730
(23,62)
.930
(28,70)
1.130
(8,38)
.330
(3,68)
.145
(4,57)
.180
(26,16)
1.030
(21,08)
.830
N/A
(3,30)
.130
(8,38)
.330
(10,92)
.430
(13,46)
.530
(16,00)
.630
(21,08)
.830
(26,16)
1.030
(5,84)
.230
–D
C
OAL
OAL
C
OAL
A
A
–Q
–T
(2,54)
.100
(2,54)
.100
C
OAL
C
(2,54)
.100
(2,54)
.100
A
A
(5,33) Styles –21, –23, –24, –27 N/A with –D
Right Angle Versions (– RA Options) A = OAL–C– .210 Styles –13, –21, –23, –24, –27, –28 N/A with –T or – Q
(1,78)
(1,78)
(1,78)
(1,78)
.070
.070
C
A
A
(1,52)
.060
(2,54)
.100
(1,52)
.060
.070
C
(2,54)
.100
A
(1,52)
.060
(2,54)
.100
(2,54)
.100
(2,54)
.100
(1,78)
.070
(23,62)
.930
(18,54)
.730
C
A
* Styles –21, –23, –24, –27
(4,06)
.160
(2,54)
.100
.070
C
(2,54)
.100
N/A
not available with –D Right Angle
not available with –T or – Q Right Angle
Straight Pin Versions A = OAL–C– (2,54)
.100
–S
FOR A = (2,29) .090
(– RE Options) Single Row Only
(7,87)
A = OAL–C– .310
WWW.SAMTEC.COM
C
(1,52)
.060
(5,08)
.200
A
(2,54)
.100
