MTSW-122-10-T-S-480-NA-020 数据手册
MODIFIED .025" SQ
POST HEADERS
(2.54 mm) .100" PITCH • MTSW/HMTSW SERIES
MTSW/HMTSW
SERIES
Board Mates:
SSW, SSQ, ESW,
ESQ, BCS, BSW
CES, SLW, HLE, SSM
Cable Mates:
IDSD, IDSS
MTSW
HMTSW
Lead–Free Solderable:
MTSW: No, Lead Wave Only
HMTSW: Yes
(2.54) .100 x No. of Positions
(2.54)
.100
—D
(5.08)
.200
02 thru 25
= (5.08 mm) .200" Pitch
(Every other position filled)
PROCESSING
OAL
(2.48)
.098
C
LEAD STYLE
Specify
LEAD STYLE
from chart
= .100" (2.54 mm)
Center Version
–2
= Hi-Temp
Modified Strip
01 thru 50
= (2.54 mm) .100" Pitch
(All positions filled)
Insulator Material:
MTSW: Black Glass
Filled Polyester
HMTSW: Natural Liquid
Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
—S
NO. PINS PER ROW
–1
= Modified Strip
SPECIFICATIONS
PIN CENTERS
= .200" (5.08 mm)
Center Version
LEAD
STYLE
OAL
– 05
(8.51) .335
– 06
(7.62) .300
– 07
(10.92) .430
– 08
(13.46) .530
– 09
(18.54) .730
– 10
(21.08) .830
POST
(0.00)
.000
MIN
OVERALL
LENGTH
(OAL)
(2.54)
.100
– 11
(23.62) .930
– 12
(26.16) 1.030
– 13
(31.24) 1.230
– 21
(36.32) 1.430
– 22
(16.00) .630
– 23
(11.30) .445
– 24
(12.19) .480
– 27
(33.78) 1.330
– 28
(28.70) 1.130
TAIL
(0.00).000
MIN
A
OAL
(5.02)
.198
FOR ”A” = (2.29) .090
C
A
OAL
—T
(7.62)
.300
(7.56)
.298
C
A
OAL
—Q
(7.62)
.300
(7.56)
.298
MTSW
HMTSW
C
A
Straight Pin Versions: A=OAL–C– (2.54) .100"
LEAD
STYLE
OAL
C
MAXIMUM
STRAIGHT
– 05
(8.51) .335
(5.97) .235
– 06
(7.62) .300
(2.79) .110
– 07
(10.92) .430
(6.10) .240
– 08
(13.46) .530
(8.64) .340
– 09
(18.54) .730
(13.72) .540
– 10
(21.08) .830
(16.26) .640
– 11
(23.62) .930
(18.80) .740
– 12
(26.16) 1.030
(21.34) .840
– 13
(31.24) 1.230
(26.42) 1.040
– 21
(36.32) 1.430
(31.50) 1.240
(11.18) .440
– 22
(16.00) .630
– 23
(11.30) .445
(6.48) .255
– 24
(12.19) .480
(7.37) .290
– 27
(23.78) 1.330
(28.96) 1.140
– 28
(28.70) 1.130
(23.88) .940
Note:
These Series are
non-standard, non-returnable.
F-224 (Rev 08DEC23)
samtec.com?MTSW or samtec.com?HMTSW
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
PLATING OPTION
–F
ROW OPTION
–S
= Gold flash on post,
Matte Tin on tail
= Single Row
–L
= Double Row
POST HEIGHT
“XXXX”
–RA or –RE
–LL
–Q
= Double Row
.200" (5.08 mm)
row space
–T
–LA
= –RA option with –LL Option
(Maximum “C” = (13.46 mm) .530")
= Matte Tin
C
—S
(3.02)
.119
= Polarized
(Specify ‘XXX’ as position number)
= Locking Lead
(not available with –RE, not available
in single row 1 or 2 positions)
(Available on tails from (2.29 mm) .090"
to (10.16 mm) .400" only)
= Triple Row
= 10 µ" (0.25 µm)
Gold on post,
Gold flash on balance
POLARIZED OPTION
“XXX”
= Right-angle
(HMTSW –S &–D =
36 positions maximum)
–T
–G
OTHER OPTION
= “C” Dimension
(Specify post height in
INCHES
.005" (0.13 mm) increments)
–D
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
D
(3.09)
.122
–RX
OPTION
D
–RA
(1.52) .060
– RE
(4.06) .160
E
C
—D
(6.10)
.240
(5.56)
.219
FOR ”E” = (2.29) .090 MIN FOR –RA & –RE)
E
C
—T
(8.12)
.320
(8.10)
.319
E
C
—Q
(8.12)
.320
(8.10)
.319
MTSW
HMTSW
E
LEAD
STYLE
OAL
C
MAXIMUM
with/–RA
C
MAXIMUM
with/–RE
– 05
(8.51) .335
Not Available
Not Available
– 06
(7.62) .300
Not Available
Not Available
Not Available
– 07
(10.92) .430
(3.30) .130
– 08
(13.46) .530
(5.84 .230
(3.30) .130
– 09
(18.54) .730
(10.92 .430
(8.38) .330
– 10
(21.08) .830
(13.46) .530
(10.92) .430
– 11
(23.62) .930
(16.00 .630
(13.46) .530
(16.00) .630
– 12
(26.16) 1.030
(18.54) .730
*– 13
(31.24) 1.230
(23.62) .930
(21.08) .830
*– 21
(36.32) 1.430
(28.70) 1.130
(26.16) 1.030
(5.84) .230
– 22
(16.00) .630
(8.38) .330
*– 23
(11.30) .445
(3.68) .145
*– 24
(12.19) .480
(4.57) .180
*– 27
(23.78) 1.330
(26.16) 1.030
(23.62) .930
*– 28
(28.70) 1.130
(21.08) .830
(18.54) .730
Not Available
* Styles –21, –23, –24, –27 not available with –D Right-angle
Styles –13, –21, –23, –24, –27, –28 not available with –T or –Q Right-angle
Right-Angle Versions (– RA Options): E=OAL–C– (5.33) .210"
Right-Angle Versions (– RE Options) Single Row Only: E=OAL–C– (7.87) .310"
F-224 (Rev 08DEC23)
MTSW-122-10-T-S-480-NA-020 价格&库存
很抱歉,暂时无法提供与“MTSW-122-10-T-S-480-NA-020”相匹配的价格&库存,您可以联系我们找货
