PCI EXPRESS® EDGE CARD SOCKETS
(1.00 mm) .0394" PITCH
FEATURES & BENEFITS
• 1.00 mm pitch
• Supports 1, 4, 8 and 16 PCI Express® links
• PCIE® 3.0 Solution (PCIE)
11 mm
8 mm
• PCIE® 4.0 Solution with low profile design for space savings (PCIE-LP)
• PCIE® 4.0 with slim body design (PCIE-G4)
• PCIE® 5.0 Solution with differential pair signaling (PCIE-G5)
• Vertical, right-angle and edge mount
PCIE
• Mates with .062" (1.60 mm) thick cards
PCIE -LP
PCIE® 3.0 & 4.0
Edge Card
connectors
• Alignment pin and weld tab options
PCIE® 4.0 slim body
socket with Edge Rate®
contacts (PCIE-G4)
KEY SPECIFICATIONS
SERIES
TOTAL PINS
(LANES)
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
PCIE®
COMPATIBILITY
PCIE
36 (x1), 64 (x4),
98 (x8), 164 (x16)
-TH = Black Nylon
-EMS2 & -TH = LCP
Phosphor Bronze
-55 °C to +125 °C
2.4 A (2 pins)
215 VAC
3.0
PCIE-LP
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Phosphor Bronze
-55 °C to +125 °C
2.1 A (2 pins)
215 VAC
4.0
PCIE-G4
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Copper Alloy
-55 °C to +125 °C
2.2 A (2 pins)
300 VAC
4.0
PCIE-G5
36 (x1), 64 (x4),
98 (x8), 164 (x16)
LCP
Copper Alloy
-55 °C to +125 °C
3.2 A (2 pins)
235 VAC
5.0
F-224
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
3.0 & 4.0 SOLUTIONS
(1.00 mm) .0394" PITCH • PCI EXPRESS® CARD SOCKETS
PCIE
NUMBER OF POSITIONS
02
–036, –064, –098, –164
PLATING OPTION
D
TAIL OPTION
–F
–EMS2
=Gold flash on contact,
Tin on tail
= Edge Mount
–TH
=Through-hole
–RA
=Right-angle
A
PCIE
Card Mates:
(1.60 mm)
.062" card
Cable Mates:
PCIEC
(8.61)
.339
(7.30)
.287
(11.05)
.435
(15.40)
.606
POSITIONS
A
–036 (x1)
(25.00) .984
–064 (x4)
(39.00) 1.535
–098 (x8)
(56.00) 2.205
–164 (x16)
(89.00) 3.504
-TH
-EMS2
A
(9.45)
.372
-RA
View complete specifications at: samtec.com?PCIE
PCIE
LP
NUMBER OF
LANES
–01, –04,
–08, –16
01
PLATING
OPTION
DV
A
–F
–WT
= Gold Flash on
contact, Matte
Tin on tail
= Weld Tab
–K
= Polyimide film
Pick & Place Pad
–S
= 30 µ" (0.75 µm)
Gold on contact,
Matte Tin on tail
PCIE-LP
Card Mates:
(1.60 mm)
.062" card
Cable Mates:
PCIEC
OPTION
NUMBER OF
LANES
A
–01
(26.60) 1.047
–04
(40.60) 1.598
–08
(57.60) 2.268
–16
(90.60) 3.567
(7.50)
.295
PACKAGING
(For -16 lanes
only leave blank for
Tray Packaging)
–TR
= Tape & Reel
(“X”R required with
–01, –04, –08 lanes)
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(“X”R required with
A
PCI-SIG®, PCI Express® and
the PCIe® design marks are
registered trademarks and/or
service marks of PCI-SIG.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(7.80)
.307
(7.98)
.314
View complete specifications at: samtec.com?PCIE-LP
samtec.com/EdgeCard
F-224
很抱歉,暂时无法提供与“PCIE-036-02-S-D-RA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+51.08400
- 10+49.80960
- 30+48.95640
