PS4-6.35T(01)
PS4-6.35T(01)
    HRS(广濑)
    CONN VERT TYPE FOR 6MM BUSBAR
PS4-6.35T(01) 数据手册
High Current Connector for Busbar applications PS4 Series May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Floating Design ■Overview High Current Connector for Busbar applications Plug-in design reduces man-hours required for construction and maintenance while improving safety. ■Features 1. Allows a high current Supports 150A (Derating curve, ambient temp 25ç : 400A) and 300A (Derating curve, ambient temp 25ç : 430A). The current value differs with the thickness of the busbar. 2. Floating structure Floating design with ±2mm for easy mating in blind mating applications which do not allow for easy visual inspection. The connector itself floats when unmated and moves freely in the range of ±2mm. However, when the busbar is inserted, it is secured by the contact pressure and the contact is stabilized. When the busbar is inserted, contact pressure is applied in the arrow direction, and the contact is secured. PAT pending 3. Plug-in design Plug-in design reduces man-hours required for construction and maintenance while improving safety. 4. Small-size design Suitable for small-size design. Supports 1U rack size. ■Product Specifications Current Busbar thickness : 3.175T 150A(Note 1), 400A (Derating curve, ambient temp 25ç) Busbar thickness : 6.35T 300A(Note 1), 430A (Derating curve, ambient temp 25ç) Operating temperature range -40 to +105ç Voltage AC/DC 600V Storage temperature range -40 to +60ç Ratings Note 1 : UL, C-UL certifications have been obtained while changing conditions such as rated current and voltage multiple times. For details, see the "Conditions on Safety Standards (UL, C-UL)" on page 4. Items 1. Contact resistanc 2. Repeated operation 5. Temperature cycles Specifications 0.5mø or less 0.7mø or less No electrical discontinuity of 10µs or more No electrical discontinuity of 10µs or more 0.7mø or less 6. Brine spraying 0.7mø or less 3. Shock resistance 4. Vibration resistance Conditions Measured at 1A DC 50 times Acceleration : 490m/s2, duration : 11ms, 3-axis half-sine wave in both directions, 3 cycles for each 10 to 55Hz, half amplitude 0.75mm, 3-axis in both directions, 3 cycles for each Temperature -40 → +105°C Time 30 → 30 minutes Left in the environment of 5% brine water with temperature 35ç for 48 hours. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.7③ 1 PS4 Series●High Current Connector for Busbar applications ■Materials / Finish Component Materials Color/Finish Remarks Insulation case Contact Synthetic resin Black color UL94V-0 Copper alloy Silver plated Bracket Pressor plate Floating screw − Stainless steel Synthetic resin Steel − Black color Nickel plated − UL94V-0 − ■Product Number Structure May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. PS4 A − 6.35T ❶ ❷ ❸ ❶ Series name : PS4 ❷ Busbar insertion direction : No symbol : Vertial direction A : Horizontal direction ❸ Busbar thickness : 6.35T : 6 or 6.35 3.175T : 3 or 3.175 ■Functional Diagram Vertical derection Horizontal derection ■Connector 36 70 44.6 31.4 31 A Part No. PS4-6.35T PS4-6.35T (01) 2 HRS No. 236-1011-0 236-1011-0 01 A No.1/4-20UNC M6 Packaging 1pcs 1pcs PS4 Series●High Current Connector for Busbar applications 36 70 44.6 31.4 31 Part No. PS4-3.175T PS4-3.175T (01) HRS No. 236-1012-0 236-1012-0 01 A No.1/4-20UNC M6 Packaging 1pcs 1pcs 36 76.25 44.6 31.4 31 A Part No. PS4A-6.35T HRS No. 236-1018-0 PS4A-6.35T (01) 236-1018-0 01 A No.1/4-20UNC Packaging 1pcs M6 1pcs 36 76.25 31 44.6 31.4 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A A Part No. PS4A-3.175T PS4A-3.175T (01) HRS No. 236-1053-0 236-1053-0 01 A No.1/4-20UNC M6 Packaging 1pcs 1pcs 3 PS4 Series●High Current Connector for Busbar applications Busbar Dimensions in 5m . R0 Part No. PS4-6.35T PS4-6.35T (01) PS4A-6.35T PS4A-6.35T (01) PS4-3.175T PS4-3.175T (01) PS4A-3.175T PS4A-3.175T (01) May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 35min A *Use silver plated copper bars. HRS No. 236-1011-0 236-1011-0 01 236-1018-0 236-1018-0 01 236-1012-0 236-1012-0 01 236-1053-0 236-1053-0 01 A 5.88 to 6.45 2.92 to 3.275 Copper Bar Attachment Dimensions A B A-A 6.5∼7 Mounting surface C C 0. 5 D Copper bar A Part No. PS4-6.35T PS4-6.35T (01) PS4-3.175T PS4-3.175T (01) PS4A-6.35T PS4A-6.35T (01) PS4A-3.175T PS4A-3.175T (01) HRS No. 236-1011-0 236-1011-0 01 236-1012-0 236-1012-0 01 236-1018-0 236-1018-0 01 236-1053-0 236-1053-0 01 A *Use silver plated busbar. A B C 76min 50 42min 82.25min 56.25 43.5min D No.1/4-20UNC M6 No.1/4-20UNC M6 No.1/4-20UNC M6 No.1/4-20UNC M6 BSafety Standards Certifications (UL, C-UL) The PS4 series has received safety certifications from the UL, C-UL under the conditions provided in Table 1. Conditions for safety standards vary depending on submitted applications of current and voltage ratings. See Table 1. Table 1. Conditions for UL and C-UL Condition① Rated Voltage (AC/DC) Rated Current Busbar Copper Bar ® 4 Condition② 600V 150A Copper(Silver plated) Size:50mm×50mm Thickness : 3.175mm Copper(Silver plated) Size:125mm×40mm Thickness : 5.0mm 300A Copper(Silver plated) Size:50mm×50mm Thickness : 6.35mm Copper(Silver plated) Size:125mm×40mm Thickness : 5.0mm 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
PS4-6.35T(01) 价格&库存
很抱歉,暂时无法提供与“PS4-6.35T(01)”相匹配的价格&库存,您可以联系我们找货
PS4-6.35T(01)
