RCU-G-01.00-AMS-AM
RCU-G-01.00-AMS-AM
    SAMTEC(申泰)
    Cable Assembly USB 1m 20AWG/25AWG USB Type A to USB Type A 4 to 4 POS PL-PL Bulk
RCU-G-01.00-AMS-AM 数据手册
F-224 SUPPLEMENT RCU–G–02.00–AMS–AM RCU SERIES IP68 SEALED USB CABLE PLUG SPECIFICATIONS For complete specifications see www.samtec.com?RCU Insulator Material: Glass Filled Thermoplastic Contact Material: Phosphor Bronze Current Rating: 4.2 A per pin (1 pin powered) Operating Temp Range: -20 °C to +80 °C Shield Material: Phosphor Bronze Wire: 20 AWG (Power) 25 AWG (Signal) 28 AWG (Drain) Double ended Mates with: RPCU, RPBU Metal squeeze latch DUST CAPS USB-A and USB-B type sealed or non sealed end options –AMS = DCA-RCU-01-01-A –BMS = DCA-RCU-01-01-B ALSO AVAILABLE (MOQ REQUIRED) RCU • Other wire lengths • End option 2 with –AMS, –BMS or –BM PLATING –G = 30 µ" (0.76 µm) Gold on contact, Nickel on shell WIRE LENGTH –01.00 = (1 m) 40" Cable –02.00 = (2 m) 79" Cable Standard lengths END 1 OPTION –AMS = USB A Type, Sealed –BMS END 2 OPTION –AM = USB A Type, Not Sealed –BC = USB B Type, Sealed = Blunt Cut Cable Length + (35.6) 1.40 (15.90) .626 (26.09) 1.027 –AM –AMS WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
RCU-G-01.00-AMS-AM 价格&库存
很抱歉,暂时无法提供与“RCU-G-01.00-AMS-AM”相匹配的价格&库存,您可以联系我们找货
RCU-G-01.00-AMS-AM
    • 1+227.731071+29.46049
