FLEXIBLE
SMT HEADER
(2.00 mm) .0787" PITCH • TMMH SERIES
TMMH
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
TMMH
-1
NO. PINS
PER ROW
03
thru
50
SPECIFICATIONS
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over 50 µ" (1.27 µm) Ni
Current Rating (TMMH/ESQT):
4.5 A per pin
(2 pins powered)
Current Rating (TMMH/SQT):
5.1 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
281 VAC mated with SQW;
250 VAC mated with SQT
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
- DV -
–F
All Flex Shroud options
require 9 pins/row minimum
(For board-to-board
interfaces. Will not
mate with TCSD)
= Gold flash
on post,
Matte Tin
on tail
–ES
–L
= End Shroud
(For best cost also
see TSH Series)
= 10 µ"
(0.25 µm)
Gold on
post,
Matte Tin
on tail
–EC
= End Shroud
with Locking Clip
(For best cost also
see TSH Series)
(Manual placement
required)
–T
= Matte Tin
PROCESSING
OPTION
Z
–ES
(2.92) .115
–EC
FLEX SHROUD
OPTIONS
OTHER
OPTIONS
–“XXX”
= Polarized Position.
Specify position of
omitted pin
–A
= Alignment Pin
(3 positions minimum)
(Not available with –LC)
–LC
= Locking Clip
(5 positions minimum)
(Not available with –A)
(Manual placement
required)
–M
–EP
(4.70) .185
= End Shroud
with Guide Post
= Pick & Place Pad
–EP & –EPC
(6.10) .240
–EL
–EL & –EBC
(4.45) .175
= Tape & Reel Packaging
(36 positions maximum)
(Flex Shroud options
not available except
–ES, –EP & –EL)
–EBC
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
–ES, –EP & –EL)
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
= End Shroud
with Board Lock
(Boards are positively
locked and cannot be
unmated)
1RRISRVLWLRQV[=
= End Shroud
with Board Lock
and Locking Clip
locked and cannot
be unmated)
–EPC
= End Shroud
with Guide Post
and Locking Clip
(Manual placement
required)
1RRISRVLWLRQV[
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
–TR
–FR
HIGH MATING
CYCLES
LEAD
STYLE
ALSO AVAILABLE
Other Platings
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
F-224
MATES WITH
(3.20) .126
SQT, SQW, ESQT,
TLE, SMM, MMS, TCSD
–04
(1.91) .075
CLT
–05
(1.65) .065
–01
MOQ Required
A
(Shrouded options removed for clarity)
—EL
—ES
—EP
—EPC
—EC
—EBC
—LC
—A
samtec.com?TMMH
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
—M
TMMH-113-01-G-DV-EP 价格&库存
很抱歉,暂时无法提供与“TMMH-113-01-G-DV-EP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 18+35.6540118+4.62724
