TMMH-115-05-F-D
TMMH-115-05-F-D
    SAMTEC(申泰)
    插件,P=2mm
    排针 间距:2mm 插件
TMMH-115-05-F-D 数据手册
F-218 TMMH–116–04–L–6 TMMH–125–04–F–D–EP (2.00 mm) .0787" FLEXIBLE THROUGH-HOLE HEADER Choice of 2, 3, 4, 5 and 6 rows on (2.00 mm) .0787" pitch Board Mates: CLT, SQT, SQW, ESQT, TLE, SMM, MMS SPECIFICATIONS For complete specifications see www.samtec.com?TMMH Cable Mates: TCSD Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (TMMH/ESQT): 4.5 A per pin (2 pins powered) Current Rating (TMMH/SQT): 5.1 A per pin (2 pins powered) Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 281 VAC mated with SQW; 250 VAC mated with SQT RoHS Compliant: Yes Lead–Free Solderable: Yes (2.00 mm) .0787" 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES APPLICATION Through-hole ALSO AVAILABLE (2.00 mm) .0787" (MOQ Required) Retention Clip Option (–RC) • Other platings Contact Samtec. RECOGNITIONS Specify LEAD STYLE from chart FILE NO. E111594 Note: Some lengths, styles and options are non-standard, non-returnable. 03 thru 50 Other Solutions 06 See PTT Series. 300 No. of rows x (2.00) .0787 Surface Mount 01 See previous page. Low Profile (2.00) .0787 See TMM Series. 02 295 No. of positions x (2.00) .0787 + Z 01 See TMM Series. (2.92) .115 (4.70) –EC .185 –EP & –EPC (6.10) .240 –EL & –EBC (4.45) .175 – ES (2.00) .0787 100 (2.00) .0787 B (Shrouded option requires -D) –01 –04 (6.45) (1.91) (2.57) .254 .075 .101 –05 (5.94) (1.65) (2.29) .234 .065 .090 –06 (8.74) (3.20) (3.53) .344 .126 .139 (2.00) .0787 C 99 –T No. of positions x (2.00) .0787 (2.00) .0787 –Q (2.00) .0787 B A See TMMS Series. C Paste In Hole (PIH) processing. Contact Samtec ASP Group for part customization. (0.50) .020 SQ C (7.67) (3.20) (2.46) .302 .126 .097 A –D Shrouded Four Row Vertical & Right-angle A –F = Gold flash on post, Matte Tin on tail B (6.35) .250 Right-angle Four Row LEAD STYLE Z OPTION Press-fit PLATING OPTION LEAD STYLE NO. PINS PER ROW 1 TMMH For complete scope of recognitions see www.samtec.com/quality (2.00) .0787 –5 –6 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –T = Matte Tin TMMH–125–04–F–D–RA–ES TMMH–118–04–T–D–EL TMMH–110–04–L–D TMMH–109–01–L–D TMMH–120–01–L–D–RA Right-angle option TMMH SERIES FLEX SHROUD OPTIONS –EL OPTION –EBC OPTION –ES OPTION APPLICATIONS SQT TMMH Optional end shrouds –EP OPTION –EPC OPTION HORIZONTAL ROW OPTION –D FLEX SHROUD OPTIONS –RA Flex Shroud requires -D row & 9 pins/row minimum (For board-to-board interfaces. Will not mate with TCSD) = Right-angle (Double & Triple Row only) (–ES, –EP, –EL Double Row only) (–EC, –EBC and –EPC not available) (–06 Lead style not available) = Double Row (Required for Flex Shroud option) –T = Triple Row B –ES = End Shroud with Locking Clip (Manual placement required) –EP –5 (2.00) .0787 –D– RA –6 LEAD STYLE D –04 –05 (3.20) .126 –EL –T– RA (Lead style –01 only) = Six Row –01 = Retention Clip (Mates to TCSD) (Double row only, minimum position 4 and available only –06 lead style) = End Shroud with Guide Post (2.62) .103 = Five Row –01 E D –RC –EC = Four Row LEAD STYLE –“XXX” = Polarized Position (Specify position of omitted pin) = End Shroud (1.27) .050 –Q OTHER OPTIONS TAIL OPTION E –D– RA –ES (–RA also available with other flex shroud options) (2.34) (6.60) .092 .260 (1.17) (2.62) (5.26) .046 .103 .207 (3.12) (5.26) .123 .207 Y (5.84) (4.45) .230 .175 –EPC (4.00) .157 (1.91) .075 DIA Y (2.03) .080 (1.83) .072 X (1.41) .056 –D– EBC –RC = End Shroud with Guide Post and Locking Clip (Manual placement required) (2.29) .090 –D– EL –EBC = End Shroud with Board Lock and Locking Clip (Boards are positively locked and cannot be unmated) –04 & (4.50) (3.02) –05 .177 .119 (3.20) .126 (2.44) .096 X = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) –D– ES (1.83) .072 (1.41) .056 –D– EC (1.83) .072 (1.41) .056 –D– EPC Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. –D– EP Y
TMMH-115-05-F-D 价格&库存
很抱歉,暂时无法提供与“TMMH-115-05-F-D”相匹配的价格&库存,您可以联系我们找货
