TMS-131-58-G-D
TMS-131-58-G-D
    SAMTEC(申泰)
    针座连接器 通孔 62 位置 0.050"(1.27mm)
TMS-131-58-G-D 数据手册
F-218 HTMS–110–03–L–D–RA HTMS–107–01–G–S TMS–110–02–G–D TMS–132–51–G–S (1.27 mm) .050" TMS, HTMS, SNM SERIES THROUGH-HOLE MICRO HEADER Mates with: SMS, SLM, RSM SPECIFICATIONS For complete specifications see www.samtec.com?TMS, www.samtec.com?HTMS or www.samtec.com?SNM MICRO SHUNT Insulator Material (TMS): Black Liquid Crystal Polymer Insulator Material (SNM): Black Glass Filled Polyester Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 5 A per pin (2 pins powered) TMS mated with SMS Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Lead Size accepted (SNM): (0.46 mm) .018" SQ Insertion Depth (SNM): (3.43 mm) .135" minimum Max Processing Temp (SNM): Not recommended for IR/VP RoHS Compliant: Yes SNM SERIES Choice of through-hole and right-angle. See FTR Series for surface mount (1.27) .050 (2.54) .100 (3.30) .130 Part No. Plating SNM–100–BK–T Tin Thirteen terminal styles 10 µ" SNM–100–BK–G (0.25 µm) Gold TYPE STRIP Important Note: Style -02 does not mate with SMS Series. PROCESSING 1 (1.27 mm x 2.54 mm) .050" x .100" pitch NO. PINS PER ROW LEAD STYLE 01 thru 50 Specify LEAD STYLE from chart TMS Lead-Free Solderable: Yes = Standard HTMS RECOGNITIONS = High Temp T/H LEAD STYLE –01 –02 –21 –51 –52 –53 –54 –55 –56 –57 –58 –59 –60 For complete scope of recognitions see www.samtec.com/quality (1.27) .050 x No. of Positions 50 FILE NO. E111594 01 (2.48) .098 (1.27) .050 TYP 02 100 (2.54) .100 (4.98) .196 ALSO AVAILABLE 99 (MOQ Required) 01 • Other platings Contact Samtec. A B (11.43) .450 (5.84) .230 (8.13) .320 (2.54) .100 C (3.05) .120 (12.83) .505 (5.84) .230 (4.45) .175 (10.41) .410 (4.83) .190 –“XXX” –G = Polarized Position (Specify position of omitted pin) = 10 µ" (0.25 µm) Gold on post, Gold flash on tail RA LEAD STYLE –01 (3.05) .120 –02 (17.91) .705 (12.32) .485 –03 (19.18) .755 (13.59) .535 B (5.84) .230 (2.54) .100 (3.18) .125 (20.96) .825 (15.37) .605 (3.56) .140 B A C (3.56) .140 B (1.52) .060 C (0.51) .020 DIA SINGLE ROW –D = Double Row (16.51) .650 (10.92) .430 A (0.51) .020 = Rightangle (14.10) .555 (8.51) .335 (15.88) .625 (10.29) .405 –RA –S (12.83) .505 (7.24) .285 (15.49) .610 (9.91) .390 OPTION = Single Row (10.80) .425 (5.21) .205 B Note: Some lengths, styles and options are non-standard, non-returnable. –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (0.46) .018 SQ (2.54) .100 ROW OPTION PLATING OPTION DOUBLE ROW HTMS –D Body Design (1.52) .060 (0.51) .020 DIA (2.54) .100 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. B
TMS-131-58-G-D 价格&库存
很抱歉,暂时无法提供与“TMS-131-58-G-D”相匹配的价格&库存,您可以联系我们找货
TMS-131-58-G-D
  • 1+96.252811+12.51052
  • 10+89.0183810+11.57022
  • 25+84.6077425+10.99695
库存:100
