ZSS-117-07-S-D-1140-LL 数据手册
ZSS–113–03–L–D–0735
F-218 (Rev 10OCT17)
HTSS–125–01–L–DV
(2.54 mm) .100"
TSS, HTSS, ZSS SERIES
SHROUDED .025" SQ POST HEADERS
Mates with:
SSW, SSQ, ESW, ESQ,
SSM, BCS
1
TYPE
STRIP
NO. PINS
PER ROW
LEAD
STYLE
PLATING
OPTION
03
Specify
LEAD
STYLE
from
chart.
= Gold flash on post,
Matte Tin on tail
(Not available on -DV)
SPECIFICATIONS
For complete specifications
see www.samtec.com?TSS,
www.samtec.com?HTSS or
www.samtec.com?ZSS
TSS
(TSS only)
= Connector Strip
Insulator Material:
TSS, ZSS: Black Glass
Filled Polyester
HTSS: Natural PCT
Insulation Resistance:
5000 MΩ min
Terminal Material:
Phosphor Bronze
Plating: Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C with Gold
-55 °C to +105 °C with Tin
Flammability Rating:
UL 94V-O
Withstanding Voltage:
1000 VRMS
RoHS Compliant: Yes
05, 07, 08, 10,
12, 13, 15, 17,
20, 25, 32, 36
HTSS
= High Temp
Connector Strip
LEAD
STYLE
–01
–02
–03
(2.92)
.115
(4.19)
.165
(14.35)
.565
PROCESSING
A
–D
RECOGNITIONS
ZSS
For complete scope of
recognitions see
www.samtec.com/quality
(0.38)
.015
–DV
(HTSS ONLY)
NO. PINS
PER ROW
(2.54) .100 x No. of Positions + (3.81) .150
(2.54) .100 x No. of Positions + (1.27) .050
02
• Other sizes
• Other platings
• Alignment Pins
• Single Row
• Locking Leads
• Polarized
Contact Samtec.
Note: Some lengths, styles
and options are non-standard,
non-returnable. ZSS is
non-standard, non-returnable.
LEAD
STYLE
PLATING
OPTION
Specify
LEAD
STYLE
from
chart.
Matte Tin on tail
(2.54)
.100
–T
(2.54)
.100
(6.35)
.250
(8.89)
.350
(2.29)
.090
MIN
(0.64) .025 SQ TYP
(2.54)
.100
–D–RA
–“XXXX”
= Body Height
BODY
HEIGHT
C
(OAL)
LEAD
STYLE
–01
–02
–03
–04
–05
–06
–07
–08
–09
C
(OAL)
MAX BODY
HEIGHT
(16.00) .630
(13.72) .540
(18.54) .730
(16.26) .640
(21.08) .830
(18.80) .740
(23.62) .930
(21.34) .840
(26.16) 1.030 (23.88) .940
(28.70) 1.130 (26.42) 1.040
(31.24) 1.230 (28.96) 1.140
(33.78) 1.330 (31.50) 1.240
(36.32) 1.430 (34.04) 1.340
Note: For added mechanical stability, Samtec
recommends mechanical board spacers be
used in applications with gold or selective
gold plated connectors. Contact ipg@
samtec.com for more information.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
BODY
HEIGHT
D
–L
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
= Matte Tin
(0.38)
.015
(5.08)
.020
–F
(9.27)
.365
01
= Double Row
Right-angle
(lead style –04
& –05 only)
(11.18) .440
(Standard sizes)
ALSO AVAILABLE
B
(6.35)
.250
(10.16)
.400
(0.64) .025 SQ TYP
1
–D–RA
LEAD RIGHT
STYLE ANGLE
(B)
–04 (3.30) .130
–05 (5.84) .230
(2.54)
.100
03, 05, 07, 08, 10, 12,
13, 15, 17, 20, 25, 32, 36
• Shrouded IDC headers and
stackers to mate with IDSD,
SMSD Series.See TST,
HTST and ZST Series.
(MOQ Required)
–T
(9.27)
.365
01
–DV
= Double Row
Surface Mount
(lead style
–01 only)
(HTSS only)
= Matte Tin
(2.54)
.100
FILE NO. E111594
OTHER
SOLUTIONS
–L
02
–D
= Double Row
Through-hole
(lead style –01,
–02 & –03 only)
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
(8.89)
.350
Lead–Free Solderable:
HTSS: Yes
TSS, ZSS: Wave Only
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
–F
(Standard sizes)
T/H
(A)
ROW
OPTION
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ZSS-117-07-S-D-1140-LL 价格&库存
很抱歉,暂时无法提供与“ZSS-117-07-S-D-1140-LL”相匹配的价格&库存,您可以联系我们找货
