4
Modular Terminal Blocks and Terminal Strips with CAGE CLAMP®,
Series 260 to 262, Side-Entry
36
Assembly
Fixing
Assembly of modular terminal blocks
to terminal strips
Mounting of an end plate
Terminal strip with fixing flange,
screw fixing
CAGE CLAMP ® connection
Connection of conductors
Fixing
Connection of conductors,
with push buttons
screw fixing of mounting adapter 209-123
Marking
Fixing
Marking with self-adhesive marker strips
Marking by direct printing (on request)
Types
on DIN 35 rail
Commoning
Terminal strip with push buttons on one side
Terminal strip with marker receptacle
for miniature WSB Quick marking system
Commoning with jumper bar
fine-stranded
with crimped ferrule*
CAGE CLAMP® clamps the following copper wires:
solid
stranded
tip-bonded
* When using wires with ferrules, it is necessary to use a terminal block one size larger than the nominal cross section of the wire
with crimped pin terminal
4
Modular Terminal Blocks and Terminal Strips with Fixing Flange,
Colour
grey
light grey
blue
orange
green-yellow
Item No.
2-cond. 4-cond.
260-301 260-331
260-303 260-333
260-304 260-334
260-306 260-336
260-307 260-337
AWG 28 – 12
0.08 – 4 mm2
630 V/8 kV/3
300/600 V, 20/5 A U
24 A
300/600 V, 20/5 A 2
2-cond. terminal block width 7 mm/0.276 in
4-cond. terminal block width 12 mm/0.472 in
L 9 – 10 mm / 0.37 in
* U 2 Q s K CCA N D a J q : ; { [
Pack.-unit
pcs
300 (6 x 50)
300 (6 x 50)
300 (6 x 50)
300 (6 x 50)
300 (6 x 50)
mm /
* U 2 Q K CCA N S D a J q : ; { [
mm /
* U 2 Q K CCA N S D a J : ; { [
0.08 – 2.5 mm2 AWG 28 – 14
500 V/6 kV/3
300/600 V, 15/5 A U
24 A
300/600 V, 20/5 A 2
2-cond. terminal block width 6 mm/0.236 in
4-cond. terminal block width 10 mm/0.394 in
L 8 – 9 mm / 0.33 in
mm /
0.08 – 1.5 mm2
AWG 28 – 16
400 V/6 kV/3
300 V, 10 A U
18 A
300 V, 15 A 2
2-cond. terminal block width 5 mm/0.197 in
4-cond. terminal block width 8 mm/0.315 in
37
Colour
grey
light grey
blue
orange
green-yellow
Item No.
2-cond. 4-cond.
261-301 261-331
261-303 261-333
261-304 261-334
261-306 261-336
261-307 261-337
Pack.-unit
pcs
200 (4 x 50)
200 (4 x 50)
200 (4 x 50)
200 (4 x 50)
200 (4 x 50)
Colour
grey
light grey
blue
orange
green-yellow
4
Item No.
2-cond. 4-cond.
262-301 262-331
262-130 262-230
262-304 262-334
262-306 262-336
262-307 262-337
Pack.-unit
pcs
100 (2 x 50)
100 (2 x 50)
100 (2 x 50)
100 (2 x 50)
100 (2 x 50)
Versions with push buttons see bottom right
No. of
Item No.
Pack.-unit
poles
2-cond. 4-cond.
pcs
Terminal strips with fixing flange, grey
260-102 260-202
100
2
3
260-103 260-203
100
260-112 260-212
25
12
Accessories, Series 260/261/262
End plate with fixing flange, grey
for series 260
260-361
100 (2 x 50)
for series 261
261-361
100 (2 x 50)
for series 262
262-361
50
Comb type jumper bar, insulated, 2-way
series
IN
reduce wire to
Pack.-unit
260-402
10 A 1 mm2/AWG 18
25 pcs
261-402
16 A 1.5 mm2/AWG 16
25 pcs
262-402
16 A 2.5 mm2/AWG 14
25 pcs
Operating tool, insulated, 2-way,
for connecting the comb type
jumper bar
209-132
1
No. of
Item No.
Pack.-unit
poles
2-cond. 4-cond.
pcs
261-102 261-202
100
2
3
261-103 261-203
100
261-112 261-212
25
12
No. of
Item No.
Pack.-unit
poles
2-cond. 4-cond.
pcs
262-102 262-202
100
2
3
262-103 262-203
100
262-112 262-212
25
12
appropriate marking system see section 9
Mounting adapter with screw, 6 mm/0.236 in wide,
for terminal blocks with fixing
flange, for DIN 35 rail, grey
209-123
25
Test plug modules
100 (4 x 25)
series module width
260 5 mm/0.197 in
8 mm/0.315 in
261 6 mm/0.236 in
10 mm/0.394 in
262 7 mm/0.276 in
12 mm/0.472 in
locking device
with
without
260-404
249-135
260-405
249-138
261-404
249-136
261-405
249-139
249-137
249-140
Suitable for Ex i applications
4 Suitable for Ex e II applications
* You can find applications on the Internet at www.wago.com.
Please find the entire product range in our General Catalogue W4, Volume1.
Additional item numbers for terminal blocks and terminal
strips with fixing flanges, for series 261 only
2-cond.
261-.../331-000
4-cond.
261-.../332-000
with push buttons on both sides
2-cond.
261-.../341-000
4-cond.
261-.../342-000
Screwdriver, with partially insulated shaft
(3.5 x 0.5) mm
210-620
Technical explanations and abbreviations see page 10.2.
1
4
4
Series 264, Description and Handling
38
Assembly
Fixing
Mounting of an “end terminal block“
with fixing flange
screw fixing
Commoning
Testing
Marking
Testing with modular test plug adapters
- touch contact
Marking
with miniature WSB Quick marking system
fine-stranded
Assembly of modular terminal strips
Removal
Removal of a terminal block
solid
stranded
tip-bonded
* When using ferrules, the max. conductor cross section which can be accommodated is one size smaller than the max. rating of terminal block
Terminal Blocks for DIN 35 Rail,
Modular Terminal Blocks and Terminal Strips with Fixing Flanges,
Series 264
0.08 – 2.5 mm2
AWG 28 – 12**
800 V/8 kV/3
600 V, 20 A U
24 A
600 V, 20 A 2
* U 2 Q CCA N S D a J q : ; { [
.4
AWG 28 – 12**
0.08 – 2.5 mm2
800 V/8 kV/3
600 V, 20 A U
24 A
600 V, 25 A 2
.4
39
.4
24,5 mm / _>
很抱歉,暂时无法提供与“261-303”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.434611+2.50385
