Data sheet
Item no.:
282-128
Product description: 2-conductor fuse terminal block WITHOUT INDICATOR for glass
cartridge type fuses 1/4 X 1 1/4
Packing unit 40 pieces
Product group
Cross section [mm
²]
Cross section [AWG]
Connection method
Measured voltage EN
Measured shock voltage
Pollution degree
Current intensity EN
Weight
Color
Wiring type
No. of connection Points
No. of potentials
Height
Height
Width
Width
Depth
Depth
Strip length from
Strip length to
Strip length
Mounting
© WAGO Kontakttechnik GmbH & Co. KG
Specifications are subject to changes and errors may be expected
1 (Rail Mounted Terminal Blocks)
0.2 - 6 mm²
24 - 10 AWG
CAGE CLAMP® CONNECTION
500 V
6 kV
3
10 A
23.191 g
gray
Side-entry
2
2
56.5 mm
2.224 in
13 mm
0.512 in
62 mm
2.44 in
12 mm
13 mm
0.49 in
TS 35
很抱歉,暂时无法提供与“282-128”相匹配的价格&库存,您可以联系我们找货
