CONTENTS
QUESTIONNAIRE
POWER
SEARCH
Rail-mounted terminal block systems
TOPJOB®S rail-mounted terminal blocks with CAGE
CLAMP®S
Front-entry rail-mounted terminal blocks
Pos.
Color:
COMPACT rail-mounted terminal blocks
Through terminal blocks
Series 870 (2,5 mm² / 4 mm²/AWG 12)
Ground conductor terminal blocks
Double potential through terminal blocks
Multilevel terminal blocks
MINI rail-mounted terminal blocks
topJob® terminal blocks
RoHS compliant
product may differ
Technical data:
Item no.
Color
Product description
11
870-901
2-CONDUCTOR THROUGH TERMINAL BLOCK
gray
12
870-902
orange
13
870-903
red
14
870-904
15
870-905
2-CONDUCTOR THROUGH TERMINAL BLOCK SUITABLE FOR EX I blue
APPLICATIONS
Webseite haben so zögern Sie nicht Kontakt mit uns aufzunehmen
Accessories
Downloads
Approvals
Rail-mounted terminal blocks with side-entry wiring
Function terminal blocks
FIT CLAMP rail-mounted terminal blocks with IDC
connection
X-COM®-SYSTEM
Modular terminal blocks and terminal strips for
surface mounting
Patching systems and busbar terminal blocks
shield connecting system
Screw terminal blocks
Accessories
PCB terminal blocks and connectors
Components for automation
Terminal blocks and connectors
Packing unit 100 pieces
RoHS compliant
Product group
Cross section [mm²]
Cross section [AWG]
Wiring method
Connection method
Cross section [mm²]
Cross section [AWG]
Wiring method
Connection method
Measured voltage EN
Measured shock voltage
Pollution degree
Current intensity EN
Weight
Color
Wiring type
No. of connection Points
No. of potentials
Height
Height
Width
Width
Depth
Depth
Strip length from
Strip length to
Strip length
Mounting
16 (RAIL MOUNTED TERMINAL BLOCK WITH CCC)
0.08 - 2.5 mm²
28 - 14 AWG
e+f
CAGE CLAMP® COMPACT CONNECTION
0.08 - 4 mm²
28 - 12 AWG
f
500 V
6 kV
3
24 A
4.3 g
gray
Front-entry
2
1
27.5 mm
1.08 in
5 mm
0.197 in
44.5 mm
1.75 in
6 mm
7 mm
0.26 in
TS 35
black
Counterparts
很抱歉,暂时无法提供与“870-901”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+31.827201+4.12274
