F-219
HPF–18–01–T–S
HPF–10–02–T–S
(5.08 mm) .200"
HPF SERIES
POWER SOCKETS
Surface Mount
or
Through-hole
Mates with:
HPM, HPW
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?HPF
Insulator Material:
Black LCP
Contact Material:
BeCu
Plating:
Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C
Voltage Rating:
850 VAC/1200 VDC
Insertion Depth:
(3.68 mm) .145" to (8.26 mm)
.325" (.368" (9.35 mm) plus
board thickness minimum for
bottom entry)
Wiping Distance:
(0.38 mm) .015"
Standard Creepage:
(2.82 mm) .111" (without -LC)
(1.38 mm) .054" (with -LC)
Standard Clearance:
(2.5 mm) .098" (without -LC)
(1.05 mm) .041" (with -LC)
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max (02-10)*
(0.20 mm) .008" max (11-20)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
RoHS Compliant:
Yes
PINS
1
2
3
4
HPF/HPM
CURRENT RATING
(PER CONTACT)
16.6 A
14.4 A
13.2 A
12.7 A
8.9 A
(5.08 mm)
.200" pitch
• Three-finger
Power Eye contact
• Locking clip option
NO. PINS
PER ROW
HPF
LEAD
STYLE
PLATING
OPTION
OTHER
OPTIONS
S
–01
02 thru 20
RECOGNITIONS
= Through-hole
–02
–LC
= Locking Clip
(Manual
placement
required)
(Style –02 only)
–T
= Matte Tin
= Surface Mount
For complete scope
of recognitions see
www.samtec.com/quality
–K
= (6.50 mm) .256"
DIA Polyimide
Film Pick &
Place Pad
FILE NO. E111594
No. of Positions x (5.08) .200
CREEPAGE
AND CLEARANCE
–TR
(5.08)
.200
= Tape & Reel
Packaging
(14 positions
maximum)
(Style –02 only)
(5.08)
.200
Selectively loading
contacts achieves customer
specific creepage and
clearance requirements.
Contact asp@samtec.com
(2.59)
.102
(8.89)
.350
(0.46)
.018
(2.46)
.097
(9.35)
.368
(1.14)
.045
–01
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
(7.11)
.280
–02
很抱歉,暂时无法提供与“HPF-03-02-T-S-LC”相匹配的价格&库存,您可以联系我们找货
