J21DPM-06V-KY
J21DPM-06V-KY
    JST
    P=2.5mm
    2X3P 2.5MM
J21DPM-06V-KY 数据手册
JFA CONNECTOR J2000 SERIES 2.5mm pitch/Disconnectable Crimp style connectors(Wire-to-board/Wire-to-wire) Specifications ––––––––––––––––––– • Current rating: 4.6 A max. AC, DC (3 circuits/AWG #20) • Voltage rating: 250 VAC, DC • Temperature range: -55°C to +105°C (including temperature rise in applying electrical current) • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #28 to #20 (0.08 to 0.75 mm2) • Applicable PC board thickness: 1.6 mm *In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). *Contact JST for details. *RoHS2 compliance. 2.5 mm pitch connector for miniaturization of electronic equipment. Center locking or side locking options can be used depending on the required application. Receptacle contacts are designed to be common with all JFA connector J2000 series. • Double-spring construction • 2 kinds of locking method • Housing lance • Clear "click feeling" 1 Current rating Circuits 3 4 6 8 10 12 16 20 Unit: A #20 4.6 4.5 4.3 4.1 3.9 3.6 3.2 2.9 #22 4.4 4.3 4.1 3.6 3.4 3.1 2.8 2.5 Wire size (AWG) #24 3.4 3.2 2.8 2.6 2.5 2.4 2.2 2.1 #26 3.0 2.8 2.6 2.3 2.2 2.0 1.8 1.7 #28 2.4 2.3 2.1 1.9 1.8 1.6 1.4 1.3 Standards –––––––––––––––––––––– 0 Recognized E60389 J 50209682 JFA CONNECTOR/J2000 SERIES List of J2000 series products 2.5mm pitch / Voltage rating 250V AC, DC Wire-to-board Type Wire-to-wire Top entry type Side entry type Panel mounting type 3, 4 3, 4 3, 4 J2100 Single-row type 5 4 3 2 3 2 1 1 100 J-2 100 J2100 Double-row type 4 Circuits 5 Center locking type J-2 J-21 00 5 4 3 2 1 Circuits 6, 8, 10, 12, 16, 20 6, 8, 10, 12, 16, 20 6, 8, 10, 12, 16, 20 J2800 Single-row type 4 Circuits 200 5 4 3 2 1 J2200 Double-row type J-2 1 2 3 4 5 10 S1 S2 P2 P1 0 S4 S5 S6 S7 S8 S3 S3 S4 Circuits S8 Output 10 / Input 24 6 5 4 2 3 1 500 J-2 Module type S2 J2300 J- 2 30 Common type for sensors S1 S5 P S6 Circuits S7 Side locking type J2500 6 Circuits J-25 00 5 4 3 2 1 12, 20 12, 20 20 2 JFA CONNECTOR/J2000 SERIES Receptacle contact Strip contact Model No. SJ2F-002GF-P1.0 SJ2F-01GF-P1.0 SJ2F-21GF-P1.0 12.5 (7) Nominal Q’ty/reel S 0.08∼0.20 28∼24 0.88∼1.43 6,000 0.20∼0.50 24∼20 1.11∼1.53 6,000 L 0.30∼0.75 — 1.30∼1.90 5,000 Material and Finish Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated S Series name Insulation O.D. (mm) M (4) J 2 Applicable wire mm2 AWG# RoHS2 compliance Wire range mark Tab contact • Standard Tab Strip contact Model No. Sort of plating 2 SJ2M-002GF-M1.0N S SJ2M-01GF-M1.0N M SJ2M-21GF-M1.0N L SJ2M-01GF-M1.0S Seqential 15.6 (4) Nominal (6.8) J 2 M Series name Applicable wire mm2 AWG# Insulation O.D. (mm) Q’ty/reel 0.08∼0.20 28∼24 0.88∼1.43 5,500 0.20∼0.50 24∼20 1.11∼1.53 5,500 0.30∼0.75 — 1.30∼1.90 5,000 0.20∼0.50 24∼20 1.11∼1.53 5,500 Material and Finish Wire range mark Copper alloy (superior conductivity), nickel-undercoated, selective gold-plated RoHS2 compliance • Sequential Tab Sort of plating 2 16.6 (7.8) J 2 M Series name Wire range mark Crimping machine, Applicator Crimping Crimp Strip contact Model No. machine applicator SJ2F-002GF-P1.0 AP-K2N SJ2M-002GF-M1.0N MKS-L SJ2F-21GF-P1.0 SJ2M-21GF-M1.0N MKS-L AP-K2N Dies Crimp applicator Hand tools with dies MK/SJ2F/M-002-10 APLMK SJ2F/M002-10 YRS-8851 — — — Crimping Crimp Strip contact Model No. machine applicator SJ2F-01GF-P1.0 SJ2M-01GF-M1.0N SJ2M-01GF-M1.0S MKS-L Crimp applicator Hand tools with dies Dies MK/SJ2F/M-01-10 APLMK SJ2F/M01-10 AP-K2N YRS-8861 *MKS-SC-J2 SC/SJ2F/M-01-10 APLSC SJ2F/M01-10 MK/SJ2F/M-21-10 APLMK SJ2F/M21-10 YRF-1120 *MKS-SC-J2 SC/SJ2F/M-21-10 APLSC SJ2F/M21-10 • Extraction tool for J2000 series: EJ-JFAJ2N • Refer to 'Hand tools' of this catalog categoly for details of YRK series. Note 1.*: Strip-crimp applicator 2. Contact JST for fully automatic crimping applicator. Keying plug Tab contact cutting tool Model No.: CT-JFAJ2 Model No.: J2KP-VY 2.2 16 64 28.5 21 Hex.nut M8(class 3) φ2.6 RoHS2 compliance 3 49.5 3.8 φ22 J2000 SERIES/J2100 Receptacle housing (Center locking type) Long keying type Circuits Circuit No. Single-row type Dimensions (mm) A B C Keying Model No. X J21SF-03V-KX-L J21SF-03V-KY-L J21SF-04V-KX-L J21SF-04V-KY-L 3 4 3 2 1 Y X 4 Y Key way Q’ty/bag 5.0 8.3 8.9 400 5.0 8.3 8.9 400 7.5 10.8 11.4 400 7.5 10.8 11.4 400 Material Glass-filled PBT, UL94V-0, black A 2.5 X (12) 8.45 RoHS2 compliance Keying No. 15.45 B C Tab housing (Panel mounting type) A Single-row type Circuits 2.5 Model No. X J21SPM-03V-KX J21SPM-03V-KY J21SPM-04V-KX J21SPM-04V-KY 5.2 12.9 10.5 5.6 3 Y X 4 Y X Keying No. Series name Dimensions (mm) (C) A B Keying Q’ty/bag 5.0 10.2 17.6 400 5.0 10.2 17.6 400 7.5 12.7 20.1 400 7.5 12.7 20.1 400 Material (C) Glass-filled PBT, UL94V-0, black J-2100 23.2 11.2 RoHS2 compliance Keying No. X 4 3 2 1 Circuit No. B Panel layout Single-row type D A Dimensions (mm) B C D 3 7.8 10.8 10.5 15.2 4 7.8 10.8 13.0 17.7 ±0.1 ±0.1 Circuits A B ±0.1 C ±0.1 4 J2000 SERIES/J2100 Receptacle housing (Center locking type) Circuits Circuit No. Long keying type Model No. X J21DF-06V-KX-L J21DF-06V-KY-L J21DF-08V-KX-L J21DF-08V-KY-L J21DF-10V-KX-L J21DF-10V-KY-L J21DF-12V-KX-L J21DF-12V-KY-L J21DF-16V-KX-L J21DF-16V-KY-L J21DF-20V-KX-L J21DF-20V-KY-L 5 4 3 2 1 Double-row type 6 Y X 8 Y Key way X 10 Y X 12 A Y 2.5 Line No. X 16 Y A 4 12.45 X 20 Y Q’ty/bag 5.0 8.3 8.9 300 5.0 8.3 8.9 300 7.5 10.8 11.4 300 7.5 10.8 11.4 300 10.0 13.3 13.9 200 10.0 13.3 13.9 200 12.5 15.8 16.4 200 12.5 15.8 16.4 200 17.5 20.8 21.4 200 17.5 20.8 21.4 200 22.5 25.8 26.4 100 22.5 25.8 26.4 100 B X (16) Dimensions (mm) A B C Keying Material Keying No. Glass-filled PBT, UL94V-0, black B 15.45 RoHS2 compliance C Tab housing (Panel mounting type) A Double-row type Circuits 2.5 Model No. X J21DPM-06V-KX J21DPM-06V-KY J21DPM-08V-KX J21DPM-08V-KY J21DPM-10V-KX J21DPM-10V-KY J21DPM-12V-KX J21DPM-12V-KY J21DPM-16V-KX J21DPM-16V-KY J21DPM-20V-KX J21DPM-20V-KY Y X 6 14.5 16.9 9.6 6 8 Y X X 10 Y Keying No. X (C) 12 Y 11.2 Series name X 16 Y J-2100 X 20 23.2 Dimensions (mm) A B (C) Keying Y Q’ty/bag 5.0 10.2 17.6 300 5.0 10.2 17.6 300 7.5 12.7 20.1 200 7.5 12.7 20.1 200 10.0 15.2 22.6 200 10.0 15.2 22.6 200 12.5 17.7 25.1 200 12.5 17.7 25.1 200 17.5 22.7 30.1 200 17.5 22.7 30.1 200 22.5 27.7 35.1 150 22.5 27.7 35.1 150 Keying No. Line No. Material B X 5 4 3 2 1 Glass-filled PBT, UL94V-0, black Circuit No. B RoHS2 compliance Panel layout Double-row type D 5 A ±0.1 B ±0.1 C ±0.1 ±0.1 Circuits Dimensions (mm) A B C D 6 8.6 14.8 10.5 15.2 8 8.6 14.8 13.0 17.7 10 8.6 14.8 15.5 20.2 12 8.6 14.8 18.0 22.7 16 8.6 14.8 23.0 27.7 20 8.6 14.8 28.0 32.7 J2000 SERIES/J2100 Header Top entry type (Center locking type) Single-row type A 2.5 3.4 Circuits Keying 3.3 10.5 3 4 X Y X Y Model No. Dimensions (mm) A B B03B-J21SK-GGXR B03B-J21SK-GGYR B04B-J21SK-GGXR B04B-J21SK-GGYR Q’ty/box 5.0 10.2 378 5.0 10.2 378 7.5 12.7 306 7.5 12.7 306 X 3.22 Material and Finish Keying No. 4.48 ±0.3 A±0.05 B Connector outline 2.5 ±0.05 RoHS2 compliance This product displays (LF)(AU) on a label. (10.5) N-φ0.85 +0.05 –0.03 Series name 3.3 ± 0.05 Copper foil land 2-(φ3) 15.5 Through-hole 2-φ2 ±0.05 (B) Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Keying No. J-2100 X 4 3 2 1 Circuit No. PC board layout (viewed from component side) 2.5 Header Side entry type (Center locking type) Single-row type (0.82) • 3 circuits Circuits Keying A 2.5 7 (3.1) (3.3) 3 11.05 4 X Y X Y Model No. S03B-J21SK-GGXR S03B-J21SK-GGYR S04B-J21SK-GGXR S04B-J21SK-GGYR Dimensions (mm) A B Q’ty/box 5.0 10.2 294 5.0 10.2 294 7.5 12.7 238 7.5 12.7 238 Material and Finish X Keying No. B Connector outline Copper foil land (φ3.4) Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF)(AU) on a label. 15.5 7 ±0.05 Through-hole 2 ±0.05 (15.5) Series name J-2100 Keying No. X 3 2 1 +0.05 φ0.85 –0.03 Circuit No. (0.82) 2.5 ±0.05 5 ±0.05 PC board layout (viewed from component side) (0.82) A 7 2.5 11.05 (3.1) (3.3) • 4 circuits X Keying No. B Connector outline Copper foil land 2-(φ3.4) 2.5 ±0.05 A ±0.05 (0.82) +0.05 φ0.85 –0.03 15.5 7 ±0.05 Through-hole 2-2 ±0.05 (15.5) Series name J-2100 Keying No. X 4 3 2 1 Circuit No. PC board layout (viewed from component side) 6 J2000 SERIES/J2100 Header Top entry type (Center locking type) Double-row type 3.4 A 2.5 Line No. Circuits Keying 6 B 3.3 4 4 14.4 A 8 10 X 3.22 Keying No. B A ±0.05 2.5 ±0.05 Series name Connector outline +0.05 –0.03 16 15.5 N-φ0.85 3.3± 0.05 4± 0.05 (14.4) 4.48 ±0.3 (B) Through-hole 2-φ2 J-2100 Copper foil land 2-(φ3) 20 Y X Y X Y X Y X Y X Y X 5 4 3 2 1 ±0.05 B06B-J21DK-GGXR B06B-J21DK-GGYR B08B-J21DK-GGXR B08B-J21DK-GGYR B10B-J21DK-GGXR B10B-J21DK-GGYR B12B-J21DK-GGXR B12B-J21DK-GGYR B16B-J21DK-GGXR B16B-J21DK-GGYR B20B-J21DK-GGXR B20B-J21DK-GGYR Dimensions (mm) A B Q’ty/box 5.0 10.2 252 5.0 10.2 252 7.5 12.7 204 7.5 12.7 204 10.0 15.2 168 10.0 15.2 168 12.5 17.7 144 12.5 17.7 144 17.5 22.7 108 17.5 22.7 108 22.5 27.7 84 22.5 27.7 84 Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Keying No. PC board layout (viewed from component side) 12 X Model No. Circuit No. 2.5 RoHS2 compliance This product displays (LF) (AU) on a label. Header Side entry type (Center locking type) Double-row type 2.5 (7) Circuits Keying A 2.5 (3.1) • 6 circuits (3.3) 6 8 A 4 14.95 10 B Line No. 12 X Keying No. Connector outline 16 B Copper foil land (φ3.4) Keying No. 2.5 ±0.05 X 3 2 1 Circuit No. PC board layout (viewed from component side) • 8, 10, 12, 16, 20 circuits A 2.5 14.95 4 (3.1) (7) A (3.3) 2.5 B Line No. X Keying No. Connector outline 2.5 ±0.05 A ±0.05 (B) PC board layout (viewed from component side) 7 J-2100 17.8 2.5 ±0.05 7 ±0.05 (17.8) Through-hole 2-φ2 ±0.05 φ0.85 +0.05 –0.03 B Series name (0.62) Copper foil land 2-(φ3.4) Keying No. X 5 4 3 2 1 Circuit No. Y X Y X Y X Y X Y X Y Dimensions (mm) A B S06B-J21DK-GGXR S06B-J21DK-GGYR S08B-J21DK-GGXR S08B-J21DK-GGYR S10B-J21DK-GGXR S10B-J21DK-GGYR S12B-J21DK-GGXR S12B-J21DK-GGYR S16B-J21DK-GGXR S16B-J21DK-GGYR S20B-J21DK-GGXR S20B-J21DK-GGYR Q’ty/box 5.0 10.2 252 5.0 10.2 252 7.5 12.7 204 7.5 12.7 204 10.0 15.2 168 10.0 15.2 168 12.5 17.7 144 12.5 17.7 144 17.5 22.7 108 17.5 22.7 108 22.5 27.7 84 22.5 27.7 84 Material and Finish J-2100 17.8 7± 0.05 2.5 ±0.05 5 ±0.05 (B) Series name (0.62) φ0.85 +0.05 –0.03 (17.8) 20 Through-hole φ2 ±0.05 X Model No. Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF) (AU) on a label. J2000 SERIES/J2200 Receptacle housing (Side locking type) Circuits 10 2.5 Line No. 10 Model No. Q’ty/bag X J22DF-10V-KX J22DF-10V-KY 250 Y 250 Material 4 9.35 A 9.75 Keying B Glass-filled PBT, UL94V-0, black RoHS2 compliance 17.8 15.45 Keying No. X Series name J–2 1 2 3 4 5 (26.4) Circuit No. 7 ±±0.05 (17.8) Series name Circuits 2.5 ±0.05 10 Keying Model No. Q’ty/box X S10B-J22DK-GGXR S10B-J22DK-GGYR 120 Y 120 Keying No. X Circuit No. 15 ±0.05 10 ±0.05 2.5 ±0.05 (0.62) 2.5 ±0.05 Header Side entry type (Side locking type) 5 4 3 2 1 J-2200 Connector outline +0.05 10-φ0.85 –0.03 Material and Finish Through-hole 2-φ2 ±0.05 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated Copper foil land 2-(φ3.4) (20.4) RoHS2 compliance This product displays (LF)(AU) on a label. PC board layout (viewed from component side) 20.4 17.8 4 11.65 12.2 B A 2.5 2.5 10 (15) (3.3) (3.1) Line No. (3.23) (7.68) (7) 2.5 8 J2000 SERIES/J2500 Receptacle housing (Module type) • 2 circuits • 4 circuits Line No. Model No. Q’ty/bag — 800 4 — J25MF-02V-K J25MF-04V-K 400 4 11.65 4 (15.75) B A 11.65 Keying 2 Material A B (15.75) 3.5 Line No. Circuits Glass-filled PBT, UL94V-0, black RoHS2 compliance 6.3 15.45 15.45 2.8 6.6 3.1 Tab housing (Panel mounting type) Circuits Keying Series name Circuit No. E ±0.1 12 — D ±0.1 20 — Model No. J25DPM-12V-K J25DPM-20V-K B 6 5 4 3 2 1 J-2500 8.6± 0.1 11.2 2 3 4 5 6 6 3.5 A B 9 9.6 16.9 14.5 4 1 E Q’ty/box 17.5 22.3 29.7 22.6 27.3 96 31.5 36.3 43.7 36.6 41.3 132 Glass-filled PBT, UL94V-0, black RoHS2 compliance (C) Dimensions (mm) D B (C) Material 14.8± 0.1 23.2 Line No. Panel layout A J2000 SERIES/J2300 Receptacle housing (Common type for sensor) Circuits Keying No. 3 Keying Model No. Q’ty/box S1 J23CF-03V-KS1 J23CF-03V-KS2 J23CF-03V-KS3 J23CF-03V-KS4 J23CF-03V-KS5 J23CF-03V-KS6 J23CF-03V-KS7 J23CF-03V-KS8 784 S2 S3 S4 3 S5 15.45 S6 2.75 S7 (2.9) 5.9 S8 784 784 784 784 784 784 784 U–A 9.94 11.14 B Material Glass-filled PBT, UL94V-0, black A 1 RoHS2 compliance 2 Circuit No. Line No. Tab housing assembly Circuits 24 Output 10 Model No. Q’ty/box S1∼S8 P28B-J23DK-GGNR 64 P2 P1 U-A Input Keying Material and Finish Hole for M3 nut Temporary nut holder S8 S7 S6 S5 RoHS2 compliance S4 S3 S2 S1 P2 P1 4.2 J-2300 23.2 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black S1 S2 S3 S4 S5 S6 S7 S8 5.25 5 P (74.2) 67.2 12.24 U-A 14.64 (60.1) 2-φ 3. 5 ¥ Current rating ¥ Circuit composition Wire size Current (A) #20 6.5 #22 5.5 #24 4.0 sensor ② #26 3.0 sensor ③ #28 2.0 Receptacle housing sensor ① sensor ④ sensor ⑤ sensor ⑥ sensor ⑦ ¥ Voltage rating: 250 V AC, DC sensor ⑧ J2300 Connector output ① output ② output ③ output ④ output ⑤ output ⑥ output ⑦ output ⑧ power supply input power supply input 10 J2000 SERIES/J2500 Header Top entry type (Module type) A 3.5 2 3 4 5 6 7 8 9 14.4 B 3.3 4 Model No. 12 — 20 — B12B-J25DK-GGR B20B-J25DK-GGR Dimensions (mm) A B Q’ty/box 17.5 22.3 108 31.5 36.3 72 Material and Finish 1 A Keying 4 Line No. Circuits Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated 10 Circuit No. B 15.5 RoHS2 compliance This product displays (LF) (AU) on a label. J-2500 4± 0.05 10 3.3± 0.05 Series name 9 8 7 6 5 Circuit No. 4 3 2 1 A ±0.05 3.5 ±0.05 +0.05 N-φ0.85 –0.03 Through-hole 2-φ2 ±0.05 Connector outline Copper foil land 2-(φ3) PC board layout (viewed from component side) Header Side entry type (Module type) A 2.5 (7) Circuits Keying Model No. 12 — 20 — S12B-J25DK-GGR S20B-J25DK-GGR Dimensions (mm) A B 2 3 4 5 6 7 8 9 B 10 Circuit No. Line No. B 17.5 22.3 108 31.5 36.3 72 Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated RoHS2 compliance This product displays (LF) (AU) on a label. 17.8 Series name Copper foil land 2-(φ3) J-2500 7 ±0.05 10 9 Connector outline 2.5± 0.05 0.62 Through-hole 2-φ2 ±0.05 3.5 ±0.05 A ±0.05 PC board layout (viewed from component side) 11 Q’ty/box Material and Finish 1 A 14.95 4 3.5 N-φ0.85 +0.05 –0.03 8 7 6 5 4 3 2 Circuit No. 1 J2000 SERIES/J2800 Receptacle housing Circuits A 2.5 Model No. Q’ty/box X J28SF-04V-KX 7.5 20.7 540 Y Under planning — — — 4.6 4 Dimensions (mm) A (B) Keying Material PBT, UL94V-0, black RoHS2 compliance 15.8 Keying No. Circuit No. X 1 2 3 4 16.5 (B) Header Side entry type (Side locking type) (0.62) 4- 0.85 2.5 ± 0.05 R0.5 ±0.05 15.3 X 4 3 2 1 7± 0.05 Circuit No. C +0.05 -0.03 4 2.1± 0.05 Series name 5.55± 0.05 Circuits 18.6± 0.05 7.5± 0.05 Keying Model No. X S04B-J28SK-GGXQ1R Y Under planning Dimensions (mm) A B C Q’ty/box 7.5 18.6 20.5 280 — — — — Material and Finish Tab contact: Copper alloy, nickel-undercoated, selective gold-plated Housing: Glass-filled PBT, UL94V-0, black Reinforcing metal fixture: Copper alloy, nickel-undercoated, selective gold-plated 1 ± 0.05 J-2800 RoHS2 compliance This product displays (LF) on a label. Note: 3rd and 4th pins are sequential pins. 19 Keying No. PC board layout (viewed from component side) Connector outline 7.5 3.2 2.5 A B 3.3 6.1 2.5 (0.62) 7 Tab housing (Free hanging type) Circuits C Keying No. 4 Dimensions (mm) A B C Keying Model No. X J28SFM-04V-KX 7.5 19 12.7 Y Under planning 7.5 19 12.7 Circuit No. Q ty/box X 4 3 2 1 Material PBT, UL94V-0, black Series name RoHS2 compliance J-2800 5.2 6.8 23.2 2.5 A B 12 JFA CONNECTOR/2000 SERIES Model number identification Tab contact Receptacle contact S J2 M - 01 GF - M 1.0 S S J2 F - 01 GF - P 1.0 Form: S...Strip form Form: S…Strip form Series name Series name Kind of terminal: M...Tab contact Kind of terminal: F…Receptacle contact Applicable wire: 002...AWG #28 ∼ #24 01...AWG #24 ∼ #20 21...0.3 to 0.75mm2 Applicable wire: 002…AWG#28 ∼ AWG#24 01…AWG#24 ∼ AWG#20 21...0.3 to 0.75mm2 Surface finish: GF...Nickel-undercoated, 0.38μm selective gold-plated Surface finish: GF...Nickel-undercoated, 0.38μm selective gold-plated Material: M...Copper alloy Material: P…Copper alloy Terminal size Terminal size Sequential identitication: N...Normal, S...Sequential Tab housing Receptacle housing J21 D F - 06 V - K X - L Series name: J21...Center locking type J22...Side locking type J23...Center locking type (for sensor) J25...Module type J28...Side locking type (Thin type) Rows: S...Single-row, D...Double-row, M...Module-row C...For sensor-row Type of connector: F...Receptacle housing No. of circuits: 2, 3, 4, 6, 8, 10, 12, 16, 20 J21 D P M-06 V - K X Series name: J21...Center locking type J22...Side locking type J25...Module type Rows: S...Single-row, D...Double-row Configuration: F...Free hanging, P...Panel mounting Type of connector: M...Tab housing Flammability: UL94V-O Color indication: K...Black, S...Natural (White), PK...Pink Keying: X...X-Keying, Y...Y-Keying, ※...S1 ∼ S8 No. of circuits: 3, 4, 6, 8, 10, 12, 16, 20 Flammability: UL94V-O Color indication: K...Black Key way type: L...Long keying type Blank...Short keying type (6 circuits is long keying type) Header S 04 B - J28 S K - GG X Q1 R PC board mounting direction: B...Top entry type S...Side entry type P...Panel mounting type No. of circuts: 3, 4, 6, 8, 10, 12, 16, 20 Product name: Header Series name: J21...Center locking type J22...Side locking type J23...Center locking type (for sensor) J25...Module type J28...Side locking type (Thin type) Rows: S...Single-row, D...Double-row Color indication: K...Black, S...Natural (White), PK...Pink Surface finish: GG...Nickel-undercoated, 0.38μm selective gold-plated Keying: X...X-Keying, Y...Y-Keying, N...Special keying (S1 ∼ S8) Sequential indication: Q1...Sequential type, Blank...Standard type Packaging form: R...Tray 13 Keying: X...X-Keying, Y...Y-Keying JFA CONNECTOR J2000 SERIES PROTECTOR When applying a current to the connector, the protector prevents foreign substances being inserted into mating part from the wiring side. However it has no function of holding the wire securely. Note: Protector is not approved by UL standards. Standards –––––––––––––––––––––– 2 J50209682 J2000 Series J2100 series for 6 circuits (17.25) No. Model No. Color Q’ty/box 1 J21PF-06SCA J21PF-06SCB Transparent 2,250 Transparent 2,100 2 (10.8) 11.6 Material 2 1 RoHS2 compliance (26.35) J-2100 15.95 Polycarbonate J21DF-06V-K( ) J21DF-06V-K( )- L (8.3) (12.85) Note: ( ) stands for keying No. (15) J2100 series for 8 circuits No. Model No. Color Q’ty/box 1 J21PF-08SCA J21PF-08SCB Transparent 480 Transparent 270 2 (17.25) (10.8) 14.1 2 Material 1 (26.35) J-2100 15.95 Polycarbonate RoHS2 compliance J21DF-08V-K( ) J21DF-08V-K( )-L (10.8) (12.85) (15) 1 Note: ( ) stands for keying No. JFA CONNECTOR J2000 SERIES PROTECTOR J2000 Series No. J2100 series for 10 circuits 1 (17.25) 16.6 (10.8) 2 Model No. Color Q ty/box J21PF-10VKA J21PF-10SCA J21PF-10VKB J21PF-10SCB Black 390 Transparent 390 Black 234 Transparent 234 Model No. Color Q ty/box J21PF-16VKA J21PF-16SCA J21PF-16VKB J21PF-16SCB Black 270 Transparent 270 Black 162 Transparent 162 Model No. Color Q ty/box J21PF-20VKA J21PF-20SCA J21PF-20VKB J21PF-20SCB Black 210 Transparent 210 Black 126 Transparent 126 1 2 (26.35) 15.85 Material Black: Glass-filled PBT Transparent: Polycarbonate RoHS2 compliance J21DF-10V-K( )-L Note: ( ) stands for keying No. (13.3) (12.85) (15) No. J2100 series for 16 circuits 1 (17.25) (10.8) 24.1 2 1 2 Black: Glass-filled PBT Transparent: Polycarbonate (26.35) 15.85 Material J−2100 RoHS2 compliance J21DF-16V-K( )-L Note: ( ) stands for keying No. (20.8) (12.85) (15) No. J2100 series for 20 circuits 1 (17.25) (10.8) 29.1 2 1 2 Black: Glass-filled PBT Transparent: Polycarbonate (26.35) 15.85 Material J−2100 RoHS2 compliance J21DF - 20V-K( )- L Note: ( ) stands for keying No. (25.8) (12.85) (15) J2200 series for 10 circuits No. Model No. Color Q ty/box 1 J22PF-10VK Black 420 Material (26.4) (12.36) 21.54 RoHS2 compliance Note: Two protectors are used. A 1 B (27.64) 17.19 1 J-2200 Glass-filled, PBT X J22DF-10V-K( ) (17.8) (9.35) Note: ( ) stands for keying No. 2
J21DPM-06V-KY 价格&库存
很抱歉,暂时无法提供与“J21DPM-06V-KY”相匹配的价格&库存,您可以联系我们找货
J21DPM-06V-KY
  • 1+62.70172
  • 2+61.12923
  • 4+59.59839
  • 8+58.53618
  • 16+56.14100
库存:80
J21DPM-06V-KY
    库存:1800
    J21DPM-06V-KY
      • 300+4.39850
      库存:1200
