LPAM-40-01.5-L-06-2-K-TR
    SAMTEC(申泰)
    SMD,P=1.27mm
    板对板连接器 立贴 针脚数:240Pin 间距:1.27mm 排数:6
LPAM-40-01.5-L-06-2-K-TR 数据手册
F-217 LPAM–20–01.5–L–06–2–K LPAM–20–01.5–L–04–2–K (1.27 mm) .050" LPAM SERIES HIGH-SPEED LOW PROFILE OPEN-PIN-FIELD SPECIFICATIONS Mates with: LPAF For complete specifications and recommended PCB layouts see www.samtec.com?LPAM Insulator Material: Black LCP Terminal Material: Copper Alloy Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.2 A per pin (6 adjacent pins powered) Working Voltage: 250 VAC RoHS Compliant: Yes Lead-Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Rating based on Samtec reference channel. For full SI performance data visit Samtec.com or contact SIG@samtec.com NO. PINS PER ROW 43 4 mm, 4.5 mm and 5 mm stack heights G b p s LEAD STYLE Dual Blade terminal Solder crimp HIGH-SPEED CHANNEL PERFORMANCE LPAM/LPAF @ 5 mm Mated Stack Height LPAM FILE NO. E111594 4, 6 or 8 row standard .050" (1.27 mm) X .050" (1.27 mm) pitch Up to 40 pins per row PLATING OPTION NO. OF ROWS –L – 04 SOLDER TYPE K TR –K =Tape & Reel ALSO AVAILABLE (MOQ Required) • Tin-Lead Solder Charge • Other pins/row and row counts • Other Gold plating options Contact Samtec. –01.0 = (1.0 mm) .039" –10, – 20, – 30, –40 –01.5 (Per Row) = (1.5 mm) .060" = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on solder tail MATED HEIGHT LPAF LPAM MATED HEIGHT B –04 (8.18) .322 (10.72) .422 (13.26) .522 –08 =Six Rows No. of positions x (1.27) .050 + (6.76) .266 (1.27) .050 LPAF LEAD STYLE –03.0 –03.5 = Polyimide film Pick & Place Pad =Eight Rows MATED HEIGHT* LPAM LEAD STYLE – 06 –2 = Lead-Free Solder Crimp – 08 NO. OF ROWS –06 =Four Rows B –01.0 (4.00) .157 (4.50) .177 –01.5 (4.50) .177 (5.00) .197 (1.27) .050 *Processing conditions will affect mated height. (1.27) .050 Note: Patent Pending A (1.32) .052 DIA No. of positions x (1.27) .050 + (3.10) .122 Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. LEAD STYLE A –01.0 (3.68) .145 (4.19) .165 –01.5 – TR
LPAM-40-01.5-L-06-2-K-TR 价格&库存
很抱歉,暂时无法提供与“LPAM-40-01.5-L-06-2-K-TR”相匹配的价格&库存,您可以联系我们找货
