MEC5-040-01-L-RA-W1-TR 数据手册
F-218 (Rev 10JAN18)
MEC5–040–01–L–RA–W2
MEC5–050–01–L–DV–W1–K–TR
(0.50 mm) .0197"
MEC5-DV, MEC5-RA SERIES
VERTICAL /RIGHT-ANGLE CARD SOCKET
Mates with:
(1.60 mm) .062" thick card
with standard board
tolerance
POSITIONS
PER ROW
MEC5
CARD
THICKNESS
SPECIFICATIONS
PROCESSING
A
(4.60)
.181
01
(3.00) .118
(0.50) .0197
(5.85)
.230
(10.25)
.404
(1.50)
.059
(0.25) .010
(1.12) .044 DIA
Note: Some sizes, styles and
options are non-standard,
non-returnable.
(0.35)
.014
(0.18)
.007
POSITIONS
PER ROW
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?MEC5-RA
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +125 °C
Current Rating:
1.5 A per pin
(2 pins powered)
Voltage Rating:
125 VAC/175 VDC
RoHS Compliant:
Yes
non-returnable.
CARD
THICKNESS
PLATING
OPTION
–01
–030, –040, –050,
–060, –070, –080
A
B
(1.60)
.063
DIA
01
(0.50)
.0197
(1.65)
.065
D
(3.00)
.118
E
= Weld Tab
Through-hole
= 10 µ" (0.25 µm) Gold on contact,
Matte Tin on tail
(1.58).062
C
–W1
–L
= (1.60 mm)
.062"
thick card
(10.25)
.404
(1.80)
.071 02
WELD
TAB
RA
–W2
= Weld Tab
POSITION
A
B
C
Surface
PER ROW
Mount
(23.38) .920 (17.10) .673
N/A
–30
(28.38) 1.117 (22.10) .870
N/A
–40
(35.88) 1.413 (29.60) 1.165 (15.44) .608
–50
(40.88) 1.609 (34.60) 1.362 (17.94) .706
–60
(45.88) 1.806 (39.60) 1.559 (20.44) .805
–70
(50.88) 2.003 (44.60) 1.756 (22.94) .903
–80
Note: Polarization rib is not present on –030 & -040 postions
PROCESSING
Lead-Free Solderable:
Yes
MEC5-DV
Rating based on Samtec
reference channel.
For full SI performance data
visit Samtec.com or contact
SIG@samtec.com
(0.50)
.020
C
–W1 SHOWN
MEC5
HIGH-SPEED CHANNEL PERFORMANCE
(1.90)
.075
(0.64)
.025
TR
POSITION
A
B
C
PER ROW
(17.10) .673
N/A
(21.63) .852
–30
(22.10) .870
N/A
(26.63) 1.048
–40
(29.60) 1.165 (15.48) .609 (34.13) 1.344
–50
(34.60) 1.362 (17.98) .708 (39.13) 1.541
–60
(39.60) 1.559 (20.48) .806 (44.13) 1.737
–70
(44.60) 1.756 (22.98) .905 (49.13) 1.934
–80
(49.60) 1.953 (25.48) 1.003 (54.13) 2.131
–90
–100 (54.60) 2.150 (27.98) 1.102 (59.13) 2.328
(1.50) .059
B
K
= 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail
No. of Positions x (0.50) .0197 + (10.38) .409
(1.80)
.071 02
W1
–L
= (1.60 mm)
.062"
thick card
–030, –040,
–050, –060, –070,
–080, –090, –100
Yes
Mates with:
with standard board
tolerance
DV
–01
www.samtec.com?MEC5-DV
Insulator Material:
Black LCP
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
-55 °C to +125 °C
Current Rating:
1.5 A per pin
(2 pins powered)
Voltage Rating:
125 VAC/175 VDC
RoHS Compliant:
Yes
PLATING
OPTION
F
–W2 SHOWN
(1.25)
.049
(11.38)
.448
(13.53) .532
POSITION
PER ROW
–30
–40
–50
(0.60)
–60
.024
–70
–80
D
E
F
N/A
N/A
(13.50) .531
(16.00) .630
(18.50) 728
(21.00) 2.003
(14.50) .571
(19.50) .768
(27.00) 1.063
(32.00) 1.260
(37.00) 1.457
(42.00) 1.654
(18.16) .715
(23.16) .912
(30.66) 1.207
(35.66) 1.404
(40.66) 1.601
(45.66) 1.798
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
MEC5-040-01-L-RA-W1-TR 价格&库存
很抱歉,暂时无法提供与“MEC5-040-01-L-RA-W1-TR”相匹配的价格&库存,您可以联系我们找货
