PTT-104-01-S-D
PTT-104-01-S-D
    SAMTEC(申泰)
    插件,P=2mm
    排针 间距:2mm 2x4P 直插
PTT-104-01-S-D 数据手册
PRESS-FIT HEADERS & SOCKETS (2.00 mm) .0787" PITCH • PTT/PTF SERIES PTT Mates: PTF, ESQT, PTHF, SQW, SQT, SMM PTT - 1 NO. PINS PER ROW - 01 - 02 thru 50 PTF –L SPECIFICATIONS (2.00) .0787 (3.20) .126 –“XXX” = Polarized Position –D = Double Row –T A –S (2.00) .079 –D (4.00) .158 –T (6.00) .236 –Q (8.00) .314 –5 (10.00) .393 –6 (12.00) .472 A OPTION = Single Row ROW OPTION No. of positions x (2.00) .0787 - ROW OPTION –S = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail Mates: PTT, TMMH, TMM, MTMM, MMT, TW, LTMM, ZLTMM Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating: 2.9 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: (2.67 mm) .105" to (3.56 mm) .140" Max Cycles: 100 with 30 µ" (0.76 µm) Au - PLATING OPTION (2.82) .111 = Triple Row –Q = Four Row –5 = Five Row –6 = Six Row (8.03) .316 ALSO AVAILABLE MOQ Required Other Platings PTF - 1 NO. PINS PER ROW 02 thru 50 TOOLING Press-Fit PHT: CAT-PT-PH-1XX-X-X PHF: CAT-PT-PH-1XX-X-B For more information, visit www.samtec.com/tooling - LEAD STYLE - Specify LEAD STYLE from chart PLATING OPTION - –L (6.35) .250 Note: Some lengths, styles and options are non-standard, non-returnable. (2.29) .090 STYLE —01 A (-03) OPTION –“XXX” = Polarized Position (4.00) .158 (2.29) .090 - = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail No. of positions x (2.00) .0787 + (0.30) .012 A (-01) D LEAD STYLE A –01 (6.35) .250 –03 (9.14) .360 (2.00) .0787 STYLE —03 samtec.com?PTT or samtec.com?PTF Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
PTT-104-01-S-D 价格&库存
很抱歉,暂时无法提供与“PTT-104-01-S-D”相匹配的价格&库存,您可以联系我们找货
