S1SS-10-28-GF-05.00-S
    SAMTEC(申泰)
    PTION: S1SS 1MM CABLE ASSEMBLY
S1SS-10-28-GF-05.00-S 数据手册
TM MICRO (1.00 mm) .0394" PITCH •  SINGLE ROW DISCRETE WIRE SOCKET - SERIES S1SS = Single Row PVC Cable S1SST = Single Row Blue *Teflon™ Fluoropolymer Cable (28 AWG only) - PINS PER ROW –02, –03, –05, –07, –10 –15, –20 –28 - = 28 AWG Color Coded Cable (S1SS only) –L1 ISS1 = Single Row Body –L3 S1SS CABLE COLOR CODING = 30 AWG Color Coded Cable (S1SS only) - –L = Single Ended With Latch = Double Ended Latch down, straight (Pin 1 to Pin 1) –30C Insulator Material: Nylon, White (with latch) Black, LCP (without latch) Contact Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range (S1SS(T)/T1M): -10 °C to +85 °C (PVC) -40 °C to +125 °C (*Teflon™ Fluoropolymer) Current Rating (28 AWG): 2.7 A per pin (1 pin powered) Voltage Rating: 250 VAC/353 VDC Wire: 28 or 30 AWG (Required Callout) = Assembled Length in Inches (45.72 mm) 01.80" min. –30 SPECIFICATIONS OPTION –“XX.XX” = 30 AWG Board Mates: T1M Cable Mates: T1SS(T), T1PS(T) - ASSEMBLED LENGTH = 3 µ" (0.07 µm) Gold on contact and tail –28C (Standard sizes) PLATING OPTION –GF = 28 AWG S1SS(T) SERIES - WIRE GAUGE (4.45) .175 (2.80) .110 No. of positions x (1.00) .03937 + (1.20) .047 No. of positions x (1.00) .03937 + (3.00) .118 (5.00) .197 COLOR 1 2 3 4 5 6 7 8 9 10 ETC BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE BLACK REPEAT –S = Single Ended No Latch –D–NUS = Double Ended No Latch, “N” up, straight –D–NDS = Double Ended No Latch, “N” down, straight *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. Assembled Length ±(3.18) .125 Assembled Length ±(3.18) .125 LATCH (–L) PIN = Double Ended Latch up, straight (Pin 1 to Pin N) Note: Teflon™ Fluoropolymer cable is intended for crimp only. Contact Samtec for solderable cable applications. NO LATCH View complete specifications at: samtec.com?S1SS & samtec.com?S1SST NO. OF POSITIONS - –02, –03, –05, –07, –10, –15, –20 SERIES LATCH (Leave blank for no latch) –L = Positive Latch No. of positions x (1.00) .03937 + (1.20) .047 No. of positions x (1.00) .03937 + (1.20) .047 01 CC09R - PLATING –GF = Contact, Full Reel (25,000 Parts per Reel) = 3 µ" (0.07 µm) Gold contact and tail CC09M = Contact, Mini Reel (5,000 Parts per Reel) No. of positions x (1.00) .03937 + (3.00) .118 No. of positions x (1.00) .03937 + (3.00) .118 - (2.10) .083 (9.01) .355 (3.81) .150 (4.20) .165 LATCH (–L) (5.00) .197 NO LATCH TOOLING Hand Tool: CAT-HT-309-2830-12 Note: Some lengths, styles and options are non-standard, non-returnable. F-224 Clamp for mounting hand tool: CAT-HT-MNT-01 Mini Applicator: CAT-MC-309-2830-XX-01 View complete specifications at: samtec.com?ISS1, samtec.com?CC09R & samtec.com?CC09M samtec.com/MicroMate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
S1SS-10-28-GF-05.00-S 价格&库存
很抱歉,暂时无法提供与“S1SS-10-28-GF-05.00-S”相匹配的价格&库存,您可以联系我们找货
