SSM-120-L-DV-BE-K-TR
    SAMTEC(申泰)
    CONN_50.8X5.08MM_SM
    .025 SOCKET STRIPS
SSM-120-L-DV-BE-K-TR 数据手册
TIGER CLAW™ SURFACE MOUNT SOCKET 8 G b p s (2.54 mm) .100" PITCH • SSM SERIES SSM Mates: TSW, MTSW, TST, TSS, ZST, ZSS, DW, EW, ZW, TSM, HMTSW, HTSW, TSSH, BST, HTSS, TLW, MTLW SSM - 1 PROCESSING Lead–Free Solderable: Yes –DH Coplanarity: Less than 28 positions (0.15 mm) .006" max* More than 27 positions (0.20 mm) .008" max* –SH, –SV, –DV Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) ALSO AVAILABLE MOQ Required Alignment pin PLATING OPTION 02 thru 36 - –F (–SV, – SH, –DH) (–DV) = Single Row Vertical Pin –DV –L = Double Row Vertical Pin = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –SH = Single Row Horizontal Pin –S = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail  [1RRI3RVLWLRQV –DH = Double Row Horizontal Pin     ROW OPTION –SV = Gold flash on contact, Matte Tin on tail 02 thru 40 SPECIFICATIONS Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SSM/TSW): 5.2 A per pin (2 pins powered) Voltage Rating: 405 VAC / 572 VDC Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: SV/DV = (4.34 mm) .171" to (7.24 mm) .285" or pass-through from top; (5.56 mm) .219" plus board thickness minimum from bottom; SH/DH = (4.34 mm) .171" to (6.35 mm) .250" - NO. PINS PER ROW —SH - OTHER OPTION –“XXX” = Polarized Position (–BE not available) –BE = Bottom Entry (–DV & –SV only) –LC = Locking Clip (–DV & –SV only) Contact Samtec for –DH & –SH –K = (6.50 mm) .256" DIA Polyimide film Pick & Place Pad (2 positions min.) –DV & –SV only –M   = Metal Pick & Place Pad (5 positions min.) –DV only   —DH –P = Plastic Pick & Place Pad (–DV & –SV only) (6 positions min. Contact Samtec for availability on smaller positions)   –TR = Tape & Reel (29 positions max.) –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (29 positions max.)  [1RRI3RVLWLRQV       —SV 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES Notes: Severe Environment Testing qualified; aligns with MIL-DTL-55302. Visit samtec.com/set Some sizes, styles and options are non-standard, non-returnable. F-224  [1RRI3RVLWLRQV       —DV —LC —P —M samtec.com?SSM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SSM-120-L-DV-BE-K-TR 价格&库存
很抱歉,暂时无法提供与“SSM-120-L-DV-BE-K-TR”相匹配的价格&库存,您可以联系我们找货
  • 200+45.31760200+5.89019
