TSM-1XX-XX-XXX-SV-XX-XXX-XX
REVISION BS
OPTION #3
-P: PICK & PLACE PAD (SEE FIG. 3)
[USE PPP-07](4 POS MINIMUM
OR -02 & -03 POS WITH -TR)
(SEE NOTE 7)
-TR: TAPE & REEL (SEE NOTE 7)
(-02 THRU -22 POS)
No OF POSITIONS
-02 THRU -50
DO NOT
SCALE FROM
THIS PRINT
C
(No OF POS x .100[2.54])
LEAD STYLE
SEE TABLE 1
PLATING SPECIFICATION
-T: MATT TIN CONTACT AND TAIL
-S: SELECTIVE, 30 Au / 50 Ni MIN ON
OPTION #2
CONTACT, MATTE TIN TAIL
-G: GOLD, 10 Au / 50 Ni MIN ON CONTACT,
POLARIZED POSITION: SPECIFY PIN OMITTED
3 Au / 50 Ni MIN ON TAIL
-L: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON
OPTION #1
CONTACT, MATTE TIN ON TAIL
-LC: LOCKING CLIP (SEE FIG. 1)(SEE NOTE 8)
-F: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON
[USE LC-08-TM-02](-02 THRU -36 POS: 2 PER STRIP,
-02 POS: 1 PER STRIP)
-H: HEAVY GOLD, 30 Au / 50 Ni MIN ON
-A: ALIGNMENT PIN (SEE FIG. 2)
CONTACT, 3 Au / 50 Ni MIN ON TAIL
-TL: TIN / LEAD (90/10+/-5%) CONTACT AND TAIL
ROW SPECIFICATION
[LEAD STYLE -01 & -02 ONLY]
-SV: SINGLE VERTICAL (USE TSM-XX-SV-XX)
-STL: SELECTIVE, 30 Au / 50 Ni MIN ON
CONTACT, TIN/LEAD (90/10+/-5%) TAIL
-TM: MATTE TIN CONTACT AND TAIL
-SM: SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-LM: LIGHT SELECTIVE, 10 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-FM: FLASH SELECTIVE, 3 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL
-SS: STRIPE SELECTIVE, 30 Au / 50 Ni MIN ON CONTACT,
MATTE TIN TAIL (SEE NOTE 9)
.000[.00]
.015[.38]
(No OF POS -1) x .100[2.54]
02
.100 2.54 REF
01
5 MAX SWAY
(TYP)
TSM-XX-SV
T-1S6-XX-X-2
2 MAX SWAY
(EITHER DIRECTION)
2 MAX TOE
(TYP)
.025 0.64 SQ REF
(TYP)
C
"F"
(CONTACT AREA)
"B" .008[.20]
(SEE TABLE 1
& NOTE 5)
C
+5°
90° - 0°
.100 2.54 REF
(TYP)
.050±.010 1.27±0.25
(TYP)
C
.006
.099 2.51
NOTES:
IN-PROCESS
LC-08-TM-02
.010 0.25 REF
1. C REPRESENTS A CRITICAL DIMENSION.
(No OF POS
2. COPLANARITY TO BE WITHIN .006[.15].
3. BURR ALLOWANCE: .0015[.038] MAX.
4. MAXIMUM CUT FLASH: .015[.38] MAXIMUM ON TOP & SIDES OF BODY
AND .030[.76] MAXIMUM ON SURFACE MOUNT SIDE OF BODY.
5. POST HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[.13] MAXIMUM.
6. MAXIMUM ALLOWABLE BOW: .002[.05] INCH/INCH AFTER ASSEMBLY.
7. LEADS MAY NOT BE VISIBLE FOR CUSTOMER VISUAL INSPECTION WITH -P
OPTION ON SMALLER POSITIONS PARTS.
8. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION
IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS
MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION.
9. -01 LEAD STYLE ONLY, MATES WITH SSW, SSQ, BCS, SSM, ESW, ESQ.
10. MINIMUM PUSHOUT FORCE: 2LB. [8.90 N]
"B"
-2) x .100[2.54]
C
2 MAX SWAY
(EITHER DIRECTION)
C
.000[.00]
.005[.13]
(SEE TABLE 1
& NOTE 5)
"D" MAX
"E" REF
.056 1.42 REF
FIG 1
TSM-112-02-XXX-SV-LC SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 2.5:1
INSULATOR:
LCP, UL 94 VO
COLOR: BLACK
TERMINAL: PHOS BRONZE
F:\DWG\MISC\MKTG\TSM-1XX-XX-XXX-SV-XX-XXX-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
SINGLE ROW .100 SMT ASSEMBLY
DWG. NO.
BY: DEAN P
8/21/2002
SHEET 1 OF 2
REVISION BS
FIG 3
FIG 4
-P: PICK & PLACE PAD OPTION
4 POSITION MINIMUM
[PLACE PAD ON CENTERLINE AS SHOWN]
TUBE PACKAGING
.400 10.16
REF
"A"
(SEE TABLE 3)
CL
PPP-07
.270 6.86
REF
"C" .010[.25]
NOTES:
1. LOAD PARTS POSITION 1 FIRST IN SAME DIRECTION AS ARROW.
2. NOTE DELETED
3. PACKAGE POSITIONS -04 THRU -36.
4. POLARIZED 4 POSITION PARTS WITHOUT PADS ARE TO BE LAYER PACKAGED
OR PACKAGED IN TAPE AND REEL.
FIG 5
-TR: TAPE & REEL PACKAGNG OPTION
POS 1 (TOWARD
ROUND HOLE)
"A" = (No OF POSITIONS x .100[2.54]) - .400[10.16]
2
FIG 2
-A: ALIGNMENT PIN OPTION
TSM-112-02-X-SV-A SHOWN
[DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1]
USER DIRECTION OF UN-REELING
POCKET NOT DETAILED
SEE TABLE 2
.100 2.54 REF
(No OF POS -2) x .100[2.54] REF
.062 1.57
REF
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: DEAN P
8/21/2002
SHEET 2 OF 2
