Data sheet | Item number: 2001-408
Push-in type jumper bar; insulated; 8-way; Nominal current 18 A; light gray
www.wago.com/2001-408
Color:
Data
Electrical data
Ratings per IEC/EN 60664-1
Rated voltage (III / 3)
800 V
Rated current
18 A
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/5
Approvals Ex
Rated current (Ex e II)
16 A
Geometrical Data
Width
32.3 mm / 1.272 inch
Height
19 mm / 0.748 inch
Depth
4.1 mm / 0.161 inch
Material Data
Color
light gray
Fire load
0.024 MJ
Weight
3 g
Commercial data
Product Group
22 (TOPJOB S)
Packaging type
bag
Country of origin
DE
GTIN
4055143699334
Customs Tariff No.
85366990990
Downloads
Documentation
Bid Text
2001-408
Apr 27, 2017
doc
24.1 kB
Download
Feb 19, 2019
xml
2.6 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
doc - Datei
2001-408
X81 - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models
2001-408
Subject
to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 2/5
2D/3D Models 2001-408
URL
Download
CAE data
EPLAN Data Portal 2001-408
Download
WSCAD Universe 2001-408
Download
Installation Notes
Jumpered
The push-in type jumper bar system is based
on the common plug and socket principle.
Each terminal block is spring-loaded with a
double socket and a resilient CrNi steel
spring. The jumper contact material is pure
electrolytic copper, which allows for an
extremely small design capable of carrying
the full-rated current of the terminal block.
Ground terminal blocks can also be
commoned using the same jumper system.
Custom jumpers are created by breaking
and removing jumper contacts (2000, 2001,
2002, 2004 Series).
Removing a push-in type jumper bar.
Insert the operating tool between the jumper
and and partition wall of the dual jumper
slots, then lift up the jumper.
Place the operating tool in the center of
jumpers up to five contacts (see above), or
alternately on both sides for jumpers with
more than five contacts.
Jumpered
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/5
Custom push-in type jumper bars are
created by breaking off jumper contacts.
Marking a push-in type jumper bar using a
felt-tip pen.
500 V
300 V
Jumpered
Stepping down via push-in type jumper bar.
Commoning via closed terminal side with
end plate allows jumpering over two crosssection sizes, e.g., from 16 mm² (6 AWG) to
6 mm² (10 AWG) or from 6 mm² (10 AWG) to
2.5 mm² (14 AWG) (see illustration above).
Commoning via open terminal side with end
plate allows jumpering over two crosssection sizes for 16 mm² (6 AWG) and
10 mm² (8 AWG) and one cross-section size
for 6/4/2.5 mm² (10/12/14 AWG). An
example: from 16 mm² (6 AWG) to 6 mm² (10
AWG) (see illustration above) or from 10 mm²
(8 AWG) to 4 mm² (12 AWG).
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 4/5
Note:
The total current of the outgoing circuits
shall not exceed the nominal current of the
step-down jumper/push-in type jumper bar.
Product family
TOPJOB® S
TOPJOB® S: In various industrial applications and modern building installations, WAGO's wide and versatile range of railmount terminal blocks provides more than just reliable electrical connections.
Show all products from the family
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/5
很抱歉,暂时无法提供与“2001-408”相匹配的价格&库存,您可以联系我们找货
