Printview: Female connector; codable; 12-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against
mismating - Item No.: 733-112
in; 100% protected against mismating
Item No.: 733-112
Female connector; codable; 12-pole; pin spacing 2.5 mm / 0.098 in; 100% protected against mismating
Marking
Business data
Supplier
WAGO
Item no.
733-112
GTIN / EAN
4044918294348
Content
1
Order amount
50
Customer item number
Notes
Universal connection for all conductor typesEasy cable pre-assembly and on-unit wiring via vertical and horizontal
CAGE CLAMP® actuationStrain relief plates, factory assembled or in-the-field installation100% protected against
mismatingCoding option available
Technical data
Miscellaneous
No. of poles
12
Pin Spacing
2.5 mm / 0.098 in %
Total number of connection points
12
Total number of potentials
12
Color
light gray
Ratings according to 1
IEC/EN 60664-1
Overvoltage category EN 1
III
WAGO Kontakttechnik GmbH & Co. KG
1
Technical data
Pollution degree (1)
2
Rated voltage EN (1) [V]
160 [V]
Rated surge voltage (1) [kV]
2.5 [kV]
Nominal current [A]
6 [A]
Overvoltage category EN 2
II
Degree of pollution (2)
2
Rated voltage EN (2) [V]
320 [V]
Rated surge voltage (2) [kV]
2.5 [kV]
Nominal current (2) [A]
6 [A]
Overvoltage category EN 3
III
Degree of pollution (3)
3
Rated voltage EN (3) [V]
100 [V]
Rated surge voltage (3) [kV]
2.5 [kV]
Nominal current (3) [A]
6 [A]
Number of individual connection objects at the product
1
Connection technology (1)
CAGE CLAMP®
Solid sizes 1
0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded wires 1
Fine-stranded wires with insulated ferrule 1
0.25 … 0.34 mm² / …
Fine-stranded wires with uninsulated ferrule 1
0.25 … 0.34 mm² / …
Strip length 1
5 … 6 mm / 0.2 … 0.24 in
Material group
I
Insulating material
Polyamide 66 (PA 66)
Flammability rating per UL 94
V0
Limit temperature range
-60 C … 100 C
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
tin-plated
Fire load [MJ]
0.09 [MJ]
Weight [g]
5.2 [g]
Width
32.1 mm / 1.264 in
Height
11.8 mm / 0.465 in
Length
17.1 mm / 0.673 in
2
Images & drawings
3
Address
Hansastr. 27
32423 Minden
Telefon: 0571/887-0
Fax: 0571/887-169
http://www.wago.com
© WAGO Kontakttechnik GmbH & Co. KG
Technische Änderungen und Irrtümer vorbehalten.
4
很抱歉,暂时无法提供与“733-112”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+27.46480
- 50+24.71810
- 100+24.71700
- 国内价格
- 5+145.88964
- 375+140.05396
- 2000+134.21828
- 国内价格
- 1+38.52360
- 10+32.56200
- 30+28.92240
