ERM5-075-02.0-L-DV-TR 数据手册
ERM5–050–05.0–L–DV–K–TR
F-218 (Rev 10OCT17)
ERM5–020–05.0–L–DV–K–TR
ERM5–040–02.0–L–DV–P–TR
(0.50 mm) .0197"
ERM5 SERIES
RUGGED HIGH-SPEED HEADER
Mates with:
ERF5
SPECIFICATIONS
Rugged Edge Rate
contacts for reduced
broadside coupling
20 to 150
I/Os
For complete specifications and
recommended PCB layouts see
www.samtec.com?ERM5
Insulator Material:
Black LCP
Terminal Material:
Phosphor Bronze or BeCu
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating (-DV to -DV):
1.5 A per pin
(2 pins powered)
Current Rating (-DV to -RA):
1.6 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
194 VAC mated with ERF5
RoHS Compliant:
Yes
• Edge Rate®
contacts
• High contact wipe
HIGH-SPEED CHANNEL PERFORMANCE
ERM5/ERF5 @ 7 mm Mated Stack Height
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (010-040)
(0.13 mm) .005" max (050-075)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
ERM5
RECOGNITIONS
28
G b p s
NO. OF POSITIONS
PER ROW
FILE NO. E111594
7 mm, 9 mm, 10 mm, 11 mm
or 12 mm stack height
–02.0
–05.0
–07.0
–02.0
–04.0
–05.0
(7.00) .276
(9.00) .354
(10.00) .394
(9.00) .354
(11.00) .433
(12.00) .472
ERF5 LEAD STYLE
–05.0
Some lengths, styles and
options are non-standard,
non-returnable.
= Plastic Pick & Place Pad
(–02.0 lead style only)
(–010 postions not available)
LEAD
STYLE
A
B
–02.0
(1.94)
.076
(3.94)
.155
(4.94)
.194
(4.84)
.191
(6.84)
.269
(7.84)
.309
–04.0
01
Notes:
Patented
–P
= 5 mm
Body
Height
No. of Positions x
(0.50) .0197 + (6.80) .268
(4.95)
.195
02
–K
= (3.50 mm) .138" DIA
Polyimide Film
Pick & Place Pad
(–04.0 & –05.0
lead style only)
= 4 mm
Body
Height
ERM5
LEAD
STYLE
TR
(Required in callout)
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–04.0
MATED HEIGHT*
ALSO AVAILABLE
PICK &
PLACE PAD
DV
–L
= 2 mm
Body
Height
*Processing conditions will affect mated height.
• Friction Lock
• Weld Tab
• Other platings
Contact Samtec.
PLATING
OPTION
LEAD
STYLE
–010, –020,
–030, –040, –050,
–060, –070, –075
For complete scope of
recognitions see
www.samtec.com/quality
(MOQ Required)
(1.00 mm)
.039"
NOMINAL
WIPE
–05.0
(0.50)
.0197
POWER/SIGNAL
APPLICATION
(2.50)
.098
(1.09)
.043
(1.32)
.052
DIA
A
B
(3.80)
.149
Compatible with
UMPT/UMPS for flexible
two-piece power/signal solutions
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
ERM5-075-02.0-L-DV-TR 价格&库存
很抱歉,暂时无法提供与“ERM5-075-02.0-L-DV-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+59.78880
- 10+51.80760
- 30+46.95840
- 100+42.87600
- 国内价格 香港价格
- 1+83.075251+10.73268
- 10+70.6219510+9.12381
- 25+66.1956825+8.55197
- 50+63.0345350+8.14357
- 100+60.02515100+7.75478
- 国内价格 香港价格
- 375+53.03574375+6.85181
- 750+47.67206750+6.15886
- 1125+47.085891125+6.08313
