HTSW-127-25-S-D-RA
HTSW-127-25-S-D-RA
    SAMTEC(申泰)
    CONN HEADER R/A 54POS 2.54MM
HTSW-127-25-S-D-RA 数据手册
F-218 (Rev 10OCT17) HTSW–116–11–G–S 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT HIGH MATING CYCLES TSW–209–09–F–S–RA HTSW–115–05–L–Q (2.54 mm) .100" THROUGH-HOLE .025" SQ POST HEADER Board Mates: SSW, SSQ, SSM, ESW, ESQ, BCS, BSW, CES, SLW TYPE STRIP Cable Mates: IDSD, IDSS, SMSD, SMSS (2.54 mm) Centers, –1 = .100" All Positions Filled TSW = Standard Strip SPECIFICATIONS For complete specifications see www.samtec.com?TSW or www.samtec.com?HTSW HTSW Insulator Material: TSW: Black Glass Filled Polyester HTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Voltage Rating: 550 VAC mated with SSW; 500 VAC mated with BCS or ESQ; 450 VAC -RA/-RE mated with BCS or SSM 400 VAC mated with CES RoHS Compliant: Yes Lead–Free Solderable: HTSW: Yes TSW: No, Lead Wave Only (2.54) .100 (5.08) .200 02 (2.54) .100 100 01 03 (2.54) (5.02) .100 .198 –D (5.08) (7.56) .200 .298 –T 99 150 (2.54) (7.62) .100 .300 01 03 148 150 (5.08) (7.56) .200 .298 (7.62) .300 –Q ESW SSW SLW SSQ SSM BCS SNT 01 5.2 A 5.7 A 5.2 A 6.3 A 5.2 A 4.6 A 4.3 A –S 01 (5.08) .200 CURRENT RATING (PER PIN) TSW mated with (2.54) .100 (2.48) .098 50 (5.08 mm) Centers, – 2 = .200" Every Other Position Filled (2.54) .100 = Hi-Temp Strip (2.54) .100 x No. of Positions Straight Pin Versions NO. PINS PER ROW PIN CENTERS TSW 148 = .100" (2.54 mm) Center Version HTSW 2 POSITIONS POWERED RightAngle Versions RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 (2.54) .100 x No. of Positions (3.02) .119 (1.78) .070 APPLICATIONS BCS TSW HORIZONTAL ALSO AVAILABLE Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 100 50 (8.12) .320 –S 01 (2.54) .100 (6.10) .240 (1.78) .070 (5.56) .219 (1.78) .070 01 99 03 150 (2.54) .100 (5.08) .200 (8.10) .319 –D 02 thru 25 = .200" (5.08 mm) Center Version –T (1.78) .070 (1.78) .070 (MOQ Required) • Other platings Contact Samtec. (3.09) (1.78) .122 .070 02 01 thru 50 01 148 03 150 (5.08) .200 (8.12) .320 (8.10) .319 –Q (1.78) .070 (1.78) .070 01 TSW HTSW 148 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. TSW–109–10–F–D–RA TSW–114–16–G–S–RE HTSW–120–13–T–D TSW–112–07–G–T TSW, HTSW SERIES PLATING OPTION LEAD STYLE ROW OPTION –S –F –L –G –T –T OTHER SOLUTIONS = Double Row (5.08 mm) .200" row space Straight Pin Versions A B C (3.30) .130 (2.41) .095 (2.54) .100 (5.08) .200 (10.16) .400 (12.70) .500 (15.24) .600 (17.78) .700 (22.86) .900 (8.51) .335 (7.62) .300 (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (23.62) .930 (26.16) 1.030 (31.24) 1.230 (13.46) .530 (2.67) .105 (2.67) .105 – 06 – 07 – 08 – 09 –10 –11 –12 –13 –14 * * * –15 –16 –17 (2.79) .110 (7.87) .310 (2.79) .110 (18.54) .730 (21.08) .830 STYLE * * * * * * * * ▲ (5.84) .230 (8.13) .320 (13.21) .520 (8.13) .320 (15.74) .620 –19 – 20 – 22 – 23 – 24 – 25 – 26 – 28 – 29 – 30 + + (0.64) .025 SQ Post (2.79) .110 – 21 – 27 * Available with – LL (Locking Lead) Option A –18 – 41 – 42 (7.62) .300 (2.92) .115 (5.33) .210 (3.20) .126 (25.40) 1.000 (20.32) .800 (23.11) .910 (18.03) .710 (0.89) .035 (1.27) .050 B = –RA Option with –LL Option Two leads per strip crimped in opposite directions on or near centerline. See charts for available styles. N/A with single row 1 or 2 positions. Recommended hole size (1.02 mm ± 0.03 mm) .040" ± .001" –“XXX” = Polarized Position (Specify “LEAD STYLE” from chart and select –RA or –RE from other options) B C (23.62) .930 (26.16) 1.030 (31.24) 1.230 (36.32) 1.430 (16.00) .630 (11.30) .445 (12.15) .480 (16.00) .630 (11.58) .456 (33.78) 1.330 (28.70) 1.130 (33.78) 1.330 (28.70) 1.130 (9.27) .365 (11.94) .470 (18.29) .720 (20.83) .820 (25.91) 1.020 (30.99) 1.220 (5.84) .230 (8.13) .320 (5.84) .230 (8.13) .320 A (2.29) .090 (7.37) .290 (9.91) .390 (12.45) .490 (14.99) .590 (20.07) .790 (5.08) .200 (25.15) .990 (4.83) .190 (2.54) .100 (22.61) .890 (17.53) .690 (20.32) .800 (15.24) .600 – 08 – 09 –10 –11 (5.84) .230 (6.73) .265 (8.13) .320 SINGLE (– S –RA LEAD STYLE –12 –13 * * * –16 – 21 – 22 – 25 – 27 – 28 – 29 – 30 C (5.84) .230 (8.13) .320 (5.84) .230 (8.13) .320 (5.84) .230 (8.13) .320 DOUBLE (– D) ▲ Except: Style –26 A (0.46) .018 DIA Tail (2.54) .100 LEAD STYLE A B – RA (1.52) .060 (0.64) .025 SQ Tail ▲ Specify -07 for best mate with IDXX Series IDC Cable TRIPLE (–T & – Q) A A (2.29) .090 (7.37) .290 (9.91) .390 (12.45) .490 (14.99) .590 (20.07) .790 (5.08) .200 (2.29) .090 (7.37) .290 (9.91) .390 (12.45) .490 (14.99) .590 – 09 –10 –11 –12 –13 –16 (5.08) .200 – 21 N/A N/A – 22 (4.83) .190 (2.54) .100 (4.83) .190 (2.54) .100 – 27 – 28 (17.53) .690 N/A N/A (15.24) .600 C (4.83) .190 (7.37) .290 (9.91) .390 (12.45) .490 (17.53) .690 (2.54) .100 (22.61) .890 (2.29) .090 (20.07) .790 (14.99) .590 C (5.84) .230 (8.13) .320 (5.84) .230 *Available with – LA (Locking Lead) Option N/A (1.78) .070 B A C (2.54) .100 (2.54) .100 – RE (4.06) .160 (2.54) .100 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –RE LEAD SINGLE STYLE A N/A + Style –41 & –42 available with HTSW only. C –LA –LL = Locking Lead Right-Angle Versions (Specify “LEAD STYLE” from chart) – 05 .025" SQ TERMINAL STRIP (TSW) Requires 4 pin minimum (NA with -T,-Q,-RA or -RE) (1.27) .050 –Q • Elevated Right-angle option • Shunts Contact Samtec IDSS or IDSD STRIP ASSEMBLY LOCKING CLIP PC BOARD = Triple Row = Matte Tin * * * * –NA = Right-angle (using straight body for coplanar mating with SSW-RA series) = Double Row = 10 µ" (0.25 µm) Gold on post, Gold flash on balance = Locking Clip (Styles –08 thru –13 & –22 only) = Right-angle –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –LC – RA or –RE = Single Row = Gold flash on post, Matte Tin on tail STYLE OTHER OPTIONS All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
HTSW-127-25-S-D-RA 价格&库存
很抱歉,暂时无法提供与“HTSW-127-25-S-D-RA”相匹配的价格&库存,您可以联系我们找货
