IP5-08-05.0-S-S-1-L-TR
    SAMTEC(申泰)
    4.00 MM ISORATE 50 OHM HIGH-ISO
IP5-08-05.0-S-S-1-L-TR 数据手册
F-221 WEB IP5–04–01–L–S–RA1–TR IP5–08–05.0–L–S–1–TR IP5–04–05.0–L–S–1–TR (4.00 mm) .1575" IP5, IP5-RA SERIES 50 W HIGH ISOLATION RF PLUGS SPECIFICATIONS IP5 For complete specifications and recommended PCB layouts see www.samtec.com?IP5 Shell Material: Copper Alloy Insulator Material: Black LCP Contact Material: Copper Alloy Dielectric Material: Black LCP Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (Vertical): Signals: 2.36 A per pin (2 adjacent pins powered) Grounds: 4.4 A per pin (2 adjacent pins powered) Operating Temp Range: -55 °C to +125 °C Dielectric Withstanding Voltage: IP5 = 600 VAC IP5-RA = 190 VAC Working Voltage: IP5 = 200 VAC IP5-RA = 190 VAC RoHS Compliant: Yes Mates with: IJ5, IJ5C NO. OF PLUGS A –01 (8.33) .328 (12.32) .485 (20.32) .800 (28.32) 1.115 (36.32) 1.430 –02 –04 –06 –08 PLUGS PER ROW 05.0 –01, –02, –04, –06, –08 PLATING ROW OPTION –L = Single Row TAIL XR –L –TR –1 –S = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on tail OPTION = (1.60 mm) .062" board thickness –D = Double Row (Not available with –01) –FR = Full Reel Tape & Reel (must order max. quantity per reel; Contact Samtec for quantity breaks) A (8.53) .336 = Tape & Reel = Cable Latch (Single Row only) (12.52) .493 (4.00) .1575 (1.52) .060 (9.09) .358 (1.52) .060 PROCESSING –S (4.00).1575 –D Lead–Free Solderable: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality IP5 Mates with: IJ5, IJ5C FILE NO. E111594 PLUGS PER ROW 01 –02, –04, –06, –08 A B (23.64) .931 (21.27) .838 (20.32) .800 (31.64) 1.246 (29.27) 1.153 (28.32) 1.115 (39.64) 1.561 (37.27) 1.468 (36.32) 1.430 (8.92) .351 (1.52) .060 IP5 B –RA1 SHOWN C (15.64) .616 (13.27) .523 (12.32) .485 (14.72) .580 (12.52) .493 C (4.00) .1575 10 mm = (1.60 mm) .062" board thickness = 10 µ" (0.25 µm) Gold on contact area, Matte Tin on grounds, tails & weld tabs NO. OF PLUGS –02 –04 –06 –08 IJ5 –RA1 –L A APPLICATION TAIL OPTION S PLATING (8.34) .328 (9.72) .383 XR OPTION –TR (Leave blank for no Cable Latch) = Tape & Reel –L = Cable Latch –FR = Full Reel Tape & Reel (must order max. quantity per reel; Contact Samtec for quantity breaks) (0.64) .025 (4.76) .188 WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IP5-08-05.0-S-S-1-L-TR 价格&库存
很抱歉,暂时无法提供与“IP5-08-05.0-S-S-1-L-TR”相匹配的价格&库存,您可以联系我们找货
    • 1+288.95400
    • 150+115.30080
    • 450+111.44520
    • 1050+109.54440
